添加编译包
添加quectel-CM app OK3399-linux-source$ ls app/quectel-CM build.sh ethtool-copy.h main.c MPQCTL.h MPQMUX.h QMIThread.c quectel-CM quectel-qmi-proxy udhcpc.c util.h default.script GobiNetCM.c Makefile MPQMI.h NOTICE QMIThread.h quectel-mbim-proxy quectel-qmi-proxy.c udhcpc_netlink.c device.c libmnl mbim-cm.c MPQMUX.c qmap_bridge_mode.c QmiWwanCM.c quectel-mbim-proxy.c ReleaseNote.txt util.c 在buildroot中添加配置文件 添加编译依赖 diff --git a/buildroot/package/forlinx/Config.in b/buildroot/package/forlinx/Config.in index 59ad65d1d..0761d52e2 100644 --- a/buildroot/package/forlinx/Config.in +++ b/buildroot/package/forlinx/Config.in @@ -4,6 +4,7 @@ menuconfig BR2_PACKAGE_FORLINX if BR2_PACKAGE_FORLINX +source "package/forlinx/quectel-CM/Config.in" source "package/forlinx/quectelCM/Config.in" source "package/forlinx/matrix-browser/Config.in" source "package/forlinx/forlinx-qt/Config.in" 添加配置文件和编译文件 buildroot/package/forlinx/quectel-CM/Config.in config BR2_PACKAGE_QUECTEL_CM bool "QUECTEL-CM" help EC20 tool quectel-CM buildroot/package/forlinx/quectel-CM/quectel-CM.mk QUECTEL_CM_VERSION = 1.0 QUECTEL_CM_SITE = $(TOPDIR)/../app/quectel-CM QUECTEL_CM_SITE_METHOD = local QUECTEL_CM_LICENSE = Apache V2.0 QUECTEL_CM_LICENSE_FILES = NOTICE define QUECTEL_CM_BUILD_CMDS $(TARGET_MAKE_ENV) $(MAKE) -C $(@D) CC=$(TARGET_CC) endef define QUECTEL_CM_INSTALL_TARGET_CMDS $(INSTALL) -D -m 0755 $(@D)/quectel-CM $(TARGET_DIR)/usr/bin/quectel-CM endef $(eval $(generic-package)) 需要注意的是配置文件中的config BR2_PACKAGE_QUECTEL_CM要和编译文件里的配置字段要匹配: (*_QUECTEL_CM 对应 QUECTEL_CM_*) 在buildroot配置文件中添加app的编译选项 diff --git a/buildroot/configs/rockchip_rk3399_defconfig b/buildroot/configs/rockchip_rk3399_defconfig index aebc92727..19c23513b 100644 --- a/buildroot/configs/rockchip_rk3399_defconfig +++ b/buildroot/configs/rockchip_rk3399_defconfig @@ -539,6 +539,7 @@ BR2_PACKAGE_LIBV4L_RKMPP=y # BR2_PACKAGE_RK_WEBUI is not set BR2_PACKAGE_CHROMIUM=y BR2_PACKAGE_FORLINX=y +BR2_PACKAGE_QUECTEL_CM=y BR2_PACKAGE_QUECTELCM=y BR2_PACKAGE_MATRIX_BROWSER=y BR2_PACKAGE_FORLINX_QT=y 编译后查看编译结果: OK3399-linux-source$ find buildroot/ -name "quectel-CM" buildroot/package/forlinx/quectel-CM buildroot/output/rockchip_rk3399/build/quectel-CM-1.0/quectel-CM buildroot/output/rockchip_rk3399/target/usr/bin/quectel-CM OK3399-linux-source$ ls buildroot/output/rockchip_rk3399/build/quectel-CM-1.0/ -a . device.c main.c MPQMI.h qmap_bridge_mode.c quectel-CM quectel-qmi-proxy .stamp_configured udhcpc_netlink.c .. ethtool-copy.h Makefile MPQMUX.c QMIThread.c quectel-CM-1.0.tar quectel-qmi-proxy.c .stamp_rsynced util.c build.sh GobiNetCM.c mbim-cm.c MPQMUX.h QMIThread.h quectel-mbim-proxy ReleaseNote.txt .stamp_target_installed util.h default.script libmnl MPQCTL.h NOTICE QmiWwanCM.c quectel-mbim-proxy.c .stamp_built udhcpc.c .stamp_built 表示该源码已经被编译过 .stamp_configured 表示该源码已经被配置过 .stamp_rsynced 目测表示该源码已经被同步 .stamp_target_installed 表示该源码编译结果已经被安装,安装目录一般是target目录 还有几个类似的文件 .stamp_downloaded 表示该源码已经被下载过,如果没有此文件会重新进行下载 .stamp_patched 表示此文件已经打过补丁 .stamp_extracted 表示此文件已经被压缩过,一般该目录下会有个压缩包 重新编译 修改了buildroot中的内容后需要重新编译,如果编译过的某个package目录下有上面的这几个文件,该包就不会进行重新编译。 如果需要重新编译这个package,可以删除这几个文件,或者某个文件,使得某几个编译步骤重新执行。 e.g. rm buildroot/output/rockchip_rk3399/build/libnspr-4.17/.stamp_* 不过实际过程中可能会有编译不过的情况出现,这个时候可以从其他路径下面拷贝需要的.stamp文件,这样就可以编译通过了。 或者可以执行make clean命令,清除output路径下的全部内容,不过重新编译的耗时会很长。 |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
979 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1104 浏览 0 评论
503 浏览 0 评论
473 浏览 0 评论
777 浏览 0 评论
GMT+8, 2025-2-24 01:38 , Processed in 0.486383 second(s), Total 40, Slave 34 queries .
