开发板:天启(t-firefly)AIO-3399J
配件: MIPI摄像头OV13850 USB摄像头:罗技(Logitech)C930c高清网络摄像头 1080P视频通话 往上拉: Camera Remember photo locations? Tag your photos and videos withe the locations where they're taken. NEXT 往右拉: 拍照/录像的分辨率: Resolution & quality Settings Camera Back camera photo (4:3) 12.8 megapixels Front camera photo (4:3) 0.3 megapixels Video Back camera video SD 480p Front camera video SD 480p 打开前后摄像头切换 后摄像头→前摄像头 前摄像头效果 前摄像头→后摄像头 后摄像头→前摄像头 Back camera video SD 480p QVGA QCIF Front camera video SD 480p QVGA QCIF 如果上电开机的时候没有插入USB摄像头,你会只发现到后置摄像头: Video Back camera video SD 480p 根据全志R18平台的修改经验,只修改这个文件就可以做到1080p录像!^_ Z:projrk3399_Android10.0devicerockchiprk3399media_profiles_default.xml Settings Camera Back camera photo (4:3) 12.8 megapixels Video Back camera video HD 1080p Back camera video HD 1080p HD 720P SD 480p 后置摄像头OV13850的分辨率列表! Back camera photo (4:3) 12.8 megapixels (4:3) 3.3 megapixels (4:3) 1.2 megapixels (16:9) 2.1 megapixels (16:9) 0.9 megapixels G: 5固件 4-Android10.0 系统PublicAIO-3399J_Android10_HDMI_210331AIO-3399J_Android10_HDMI_210331.7z 预编译的是480p 后置摄像头视频 SD 480p QVGA QCIF 取消 很容易知道,插入USB摄像头就多了两个video设备节点: /dev/video10 /dev/video11 Microsoft Windows [版本 10.0.18363.1500] (c) 2019 Microsoft Corporation。保留所有权利。 C:UsersDELL>adb shell rk3399_firefly_aio_lvds:/ $ cd /dev rk3399_firefly_aio_lvds:/dev $ rk3399_firefly_aio_lvds:/dev $ ls -l v* crw-rw---- 1 media camera 81, 12 2013-01-18 08:50 v4l-subdev0 crw-rw---- 1 media camera 81, 13 2013-01-18 08:50 v4l-subdev1 crw-rw---- 1 media camera 81, 14 2013-01-18 08:50 v4l-subdev2 crw-rw---- 1 media camera 81, 15 2013-01-18 08:50 v4l-subdev3 crw-rw---- 1 media camera 81, 16 2013-01-18 08:50 v4l-subdev4 crw-rw---- 1 media camera 81, 17 2013-01-18 08:50 v4l-subdev5 crw-rw-r-- 1 bluetooth net_bt 10, 50 2013-01-18 08:50 vendor_storage crw-rw---- 1 media camera 81, 0 2013-01-18 08:50 video0 crw-rw---- 1 media camera 81, 1 2013-01-18 08:50 video1 crw-rw---- 1 media camera 81, 10 2013-01-18 08:50 video10 crw-rw---- 1 media camera 81, 11 2013-01-18 08:50 video11 crw-rw---- 1 media camera 81, 2 2013-01-18 08:50 video2 crw-rw---- 1 media camera 81, 3 2013-01-18 08:50 video3 crw-rw---- 1 media camera 81, 4 2013-01-18 08:50 video4 crw-rw---- 1 media camera 81, 5 2013-01-18 08:50 video5 crw-rw---- 1 media camera 81, 6 2013-01-18 08:50 video6 crw-rw---- 1 media camera 81, 7 2013-01-18 08:50 video7 crw-rw---- 1 media camera 81, 8 2013-01-18 08:50 video8 crw-rw---- 1 media camera 81, 9 2013-01-18 08:50 video9 crw-rw-rw- 1 root root 10, 47 2013-01-18 08:50 vmdrm0 crw-rw-rw- 1 root root 10, 56 2013-01-18 08:50 vndbinder rk3399_firefly_aio_lvds:/dev $ rk3399_firefly_aio_lvds:/dev $ 图片 图片 启动完成之后再插入摄像头会报错: console:/ $ console:/ $ console:/ $ console:/ $ console:/ $ console:/ $ [ 45.437502] u*** 5-1: new high-speed USB device number 2 using xhci-hcd [ 45.644693] u*** 5-1: New USB device found, idVendor=046d, idProduct=0891, bcdDevice= 0.19 [ 45.644779] u*** 5-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1 [ 45.644802] u*** 5-1: Product: 罗技高清网络摄像机 C930c [ 45.644824] u*** 5-1: SerialNumber: 237EBCCE [ 45.675017] uvcvideo: Found UVC 1.00 device 罗技高清网络摄像机 C930c (046d:0891) [ 45.684324] uvcvideo 5-1:1.0: Entity type for entity Processing 3 was not initialized! [ 45.684403] uvcvideo 5-1:1.0: Entity type for entity Extension 6 was not initialized! [ 45.684431] uvcvideo 5-1:1.0: Entity type for entity Extension 8 was not initialized! [ 45.684457] uvcvideo 5-1:1.0: Entity type for entity Extension 9 was not initialized! [ 45.684483] uvcvideo 5-1:1.0: Entity type for entity Extension 10 was not initialized! [ 45.684508] uvcvideo 5-1:1.0: Entity type for entity Extension 11 was not initialized! [ 45.684538] uvcvideo 5-1:1.0: Entity type for entity Extension 12 was not initialized! [ 45.684601] uvcvideo 5-1:1.0: Entity type for entity Extension 13 was not initialized! [ 45.684660] uvcvideo 5-1:1.0: Entity type for entity Camera 1 was not initialized! [ 45.686892] input: 罗技高清网络摄像机 C93 as /devices/platform/u***@fe900000/fe900000.dwc3/xhci-hcd.0.auto/u***5/5-1/5-1:1.0/input/input4 [ 45.697465] type=1400 audit(1619588870.988:105): avc: denied { getattr } for ino=24051 scontext=u:r:hal_memtrack_default:s0 tcontext=u:object_r:debugfs:s0 tclass=file permissive=1 [ 45.697596] type=1400 audit(1619588878.301:106): avc: denied { read } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.697909] type=1400 audit(1619588878.301:106): avc: denied { read } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.697979] type=1400 audit(1619588878.301:107): avc: denied { open } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.698568] type=1400 audit(1619588878.301:107): avc: denied { open } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.698667] type=1400 audit(1619588878.301:108): avc: denied { getattr } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.698938] type=1400 audit(1619588878.301:108): avc: denied { getattr } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.699037] type=1400 audit(1619588878.301:109): avc: denied { map } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.966691] audit: audit_lost=11 audit_rate_limit=5 audit_backlog_limit=64 [ 45.966725] audit: rate limit exceeded [ 45.966744] type=1400 audit(1619588878.301:109): avc: denied { map } for ino=20474 scontext=u:r:hal_camera_default:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1 [ 45.966788] type=1400 audit(1619588878.571:110): avc: denied { read } for ino=20398 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1 console:/ $ console:/ $ |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
2352 浏览 0 评论
2753 浏览 1 评论
2239 浏览 1 评论
3573 浏览 1 评论
4332 浏览 1 评论
GMT+8, 2025-1-23 02:00 , Processed in 0.812515 second(s), Total 72, Slave 56 queries .
