1. 简介
思考一下,bringup 一款 Soc 的最小操作包括哪些?
完成上面 4 个步骤后,就有机会启动系统进入命令行终端了。 接下来需要完善什么?
本文会顺着上述思路,快速地浏览一下 NanoPC-T4 这块单板的设备树里 Soc 基础设施。 2. 查看 Soc 框图 点击查看大图 rk3399 大致包括 7 个部分:
阅读设备树时,Soc 框图可以协助我们确定好每个节点的定位和功能。 3. 确定 dts 文件关系 dts 文件关系图: 点击查看大图 rk3399-nanopi4-rev00.dts 和 rk3399-nanopi4-common.dtsi 用于描述板级信息; rk3399.dtsi 等剩下的文件用于描述 Soc 信息; 4. 汇总完整的 dts 节点 完整的 dts 节点图: 点击查看大图 5. 查看 Soc 基础设施 5.1 cpus 节点 cpus { #address-cells = <2>; #size-cells = <0>; cpu-map { cluster0 { core0 { cpu = <&cpu_l0>; }; ... core3 { cpu = <&cpu_l3>; }; }; cluster1 { core0 { cpu = <&cpu_b0>; }; core1 { cpu = <&cpu_b1>; }; }; }; cpu_l0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; ... }; ... cpu_b0: cpu@100 { device_type = "cpu"; compatible = "arm,cortex-a72", "arm,armv8"; }; ... } 简单说明:
相关代码:
相关文档:
相关接口:
5.2 clock controller 节点 /arch/arm64/boot/dts/rockchip/rk3399.dtsi cru: clock-controller@ff760000 { compatible = "rockchip,rk3399-cru"; reg = <0x0 0xff760000 0x0 0x1000>; #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = ...; assigned-clock-rates = ...; }; /arch/arm64/boot/dts/rockchip/rk3399.dtsi pmucru: pmu-clock-controller@ff750000 { compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>; #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = ...; assigned-clock-rates = ...; }; 简单说明:
相关文档:
相关代码:
相关接口:
5.3 interrupt controller 节点 gic: interrupt-controller@fee00000 { compatible = "arm,gic-v3"; ... its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; #interrupt-cells = <4>; ... interrupt-controller; ... }; ppi-partitions { ppi_cluster0: interrupt-partition-0 { affinity = <&cpu_l0 &cpu_l1 &cpu_l2 &cpu_l3>; }; ppi_cluster1: interrupt-partition-1 { affinity = <&cpu_b0 &cpu_b1>; }; }; }; 简单说明:
相关代码:
相关文档:
相关接口:
5.4 pin controller 节点 pinctrl: pinctrl { compatible = "rockchip,rk3399-pinctrl"; ... // 4 x gpio controller gpio0: gpio0@ff720000 { compatible = "rockchip,gpio-bank"; ... }; ... // lots of pin configuration nodes ... i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = <1 15 RK_FUNC_2 &pcfg_pull_none>, <1 16 RK_FUNC_2 &pcfg_pull_none>; }; }; ... } 简单说明:
相关代码:
相关文档:
相关接口: $ tree /sys/kernel/debug/pinctrl /sys/kernel/debug/pinctrl ├── pinctrl-devices ├── pinctrl-handles ├── pinctrl-maps └── pinctrl-rockchip-pinctrl ├── gpio-ranges ├── pinconf-config ├── pinconf-groups ├── pinconf-pins ├── pingroups ├── pinmux-functions ├── pinmux-pins └── pins 5.5 gpio controller 节点 gpio0: gpio0@ff720000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff720000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO0_PMU>; interrupts = gpio-controller; #gpio-cells = <0x2>; interrupt-controller; #interrupt-cells = <0x2>; }; ... gpio4: gpio4@ff790000 { compatible = "rockchip,gpio-bank"; ... }; 简单说明:
相关代码:
相关文档:
相关接口:
5.6 efuse 节点 efuse0: efuse@ff690000 { compatible = "rockchip,rk3399-efuse"; ... /* Data cells */ specification_serial_number: specification-serial-number@6 { reg = <0x06 0x1>; bits = <0 5>; }; cpu_id: cpu-id@7 { reg = <0x07 0x10>; }; ... }; 简单说明:
相关代码:
相关文档:
相关接口:
5.7 cpuinfo 节点 cpuinfo { compatible = "rockchip,cpuinfo"; nvmem-cells = <&cpu_id>; nvmem-cell-names = "id"; }; 简单说明:
相关代码:
相关文档:
6. 相关参考
1362 浏览 0 评论
630 浏览 0 评论
1122 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】自行转换大模型失败,搞一个语音小智玩玩吧.
486 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】使用rkllm运行DeepSeek的服务模式体验
893 浏览 0 评论
GMT+8, 2025-4-6 19:16 , Processed in 0.753742 second(s), Total 72, Slave 56 queries .
