一、git下载九鼎SDK
在ubuntu16中,通过: git clone https://gitlab.com/9tripod/x3288_linux_new.git git clone https://gitlab.com/9tripod/x3399_linux_new.git 获取自己开发板的SDK到Ubuntu中,获得根目录x3399_linux_new。 二、安装所需的软件包: 1、 sudo apt-get update 2、 sudo apt-get install git gnupg flex bison gperf libsdl1.2-dev libwxgtk3.0-dev build-essential zip curl zlib1g-dev gcc-multilib g++-multilib genromfs libc6-dev-i386 libncurses5-dev x11proto-core-dev libx11-dev ccache libgl1-mesa-dev libxml2-utils xsltproc unzip gperf l***-core lib32z1-dev lib32ncurses5-dev lzop liblz4-tool proot libssl1.0.0 libssl-dev genext2fs 三、安装 kernel 及 u-boot 编译需要依赖的软件包 apt-get install git-core gnupg flex bison gperf build-essential zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32ncurses5-dev x11proto-core-dev libx11-dev lib32z1-dev ccache libgl1-mesa-dev libxml2-utils xsltproc unzip device-tree-compiler 四、安装文件系统需要依赖的软件包 apt-get install lib32stdc++-4.9-dev lib32z1 五、安装 Buildroot 编译需要依赖的软件包 apt-get install libfile-which-perl sed make binutils gcc g++ bash patch gzip bzip2 perl tar cpio python unzip rsync file bc libmpc3 git repo texinfo pkg-config cmake tree 六、编译uboot 在x3399_linux_new目录下执行 ./mk.sh -u 编译uboot后的打印: --------pack uboot.img-------- load addr is 0x200000! pack input /test/doc/x3399/x3399_linux_new/u-boot/u-boot.bin pack file size: 955619 crc = 0xf23a6d50 pack uboot.img success! pack uboot okay! Input: /test/doc/x3399/x3399_linux_new/u-boot/u-boot.bin --------pack loader-------- out:rk3399_loader_v1.23.119.bin fix opt:rk3399_loader_v1.23.119.bin merge success(rk3399_loader_v1.23.119.bin) /test/doc/x3399/x3399_linux_new/u-boot pack loader okay! Input: /test/doc/x3399/x3399_linux_new/rkbin/RKBOOT/RK3399MINIALL.ini --------pack trust.img-------- out:trust.img merge success(trust.img) /test/doc/x3399/x3399_linux_new/u-boot pack trust okay! Input: /test/doc/x3399/x3399_linux_new/rkbin/RKTRUST/RK3399TRUST.ini ‘/test/doc/x3399/x3399_linux_new/u-boot/rk3399_loader_v1.23.119.bin’ -> ‘/test/doc/x3399/x3399_linux_new/output/MiniLoaderAll.bin’ ‘/test/doc/x3399/x3399_linux_new/u-boot/uboot.img’ -> ‘/test/doc/x3399/x3399_linux_new/output/uboot.img’ ‘/test/doc/x3399/x3399_linux_new/u-boot/trust.img’ -> ‘/test/doc/x3399/x3399_linux_new/output/trust.img’ 七、编译kernel x3399_linux_new目录下执行./mk.sh -k 编译kernel后的打印: Pack to resource.img successed! Image: resource.img (with x3399-linux.dtb logo.bmp logo_kernel.bmp) is ready Image: boot.img (with Image resource.img) is ready Image: zboot.img (with Image.lz4 resource.img) is ready ‘/test/doc/x3399/x3399_linux_new/kernel/boot.img’ -> ‘/test/doc/x3399/x3399_linux_new/output/boot.img’ 7.1 单独编译内核的命令: x3399_linux_new/kernel/ make ARCH=arm64 x3399_linux_defconfig CROSS_COMPILE=aarch64-linux-gnu- make ARCH=arm64 x3399-linux.img CROSS_COMPILE=aarch64-linux-gnu- -j4 x3399_linux_new/ cp -v kernel/boot.img output/boot.img 最后的boot.img就是烧写用的镜像 7.2 命令解析 make ARCH=arm64 x3399-linux.img CROSS_COMPILE=aarch64-linux-gnu- -j4 这句指令进行的操作由x3399_linux_new/kernel/arch/arm64/Makefile决定的: make x3399-linux.img == make rockchip/x3399-linux.dtb kernel.img//两个make命令 //1 make rockchip/x3399-linux.dts//得到 x3399-linux.dtb scripts/mkkrnlimg arch/arm64/boot/Image kernel.img//Image打包为kernel.img //2 scripts/resource_tool /arch/arm64/boot/dts/rockchip/x3399-linux.dtb//打包设备树和图片等 生成resource.img //3 scripts/mkbootimg --kernel arch/arm64/boot/Image --ramdisk ramdisk.img --second resource.img -o boot.img//打包三个镜像为boot.img 八、编译recovery x3399_linux_new目录下执行./mk.sh -r 九、编译文件系统 x3399_linux_new目录下执行 ./mk.sh -b 十、整体一起编译 x3399_linux_new目录下执行./mk.sh -a 会编译出以上所有镜像。 十一、打包成统一镜像 x3399_linux_new目录下执行./mk.sh -U update-linux.img 为整个 QT 系统升级文件的单一映像,包括了 uboot,内核,文件系统等。 注意,生成 update-linux.img 的先决条件是已经成功编译了 uboot,内核和 linux 文件系统,缺一不可。 十二、各镜像含义 MiniLoaderAll.bin:uboot 镜像文件,复制自 uboot 生成的“loader.bin”文件。 parameter.txt: 分区文件 uboot.img:uboot 镜像文件,由 uboot 编译得到的 bin 文件打包得到。 trust.img:uboot 镜像文件,同样由 rk 提供的 bin 文件打包得到,uboot.img 和MiniLoaderAll.bin 以及 trust.img 的生成打包过程,有兴趣可通过研究编译脚本理解其原理。 misc.img:分区镜像,负责启动模式切换和急救模式的参数传递。 recovery.img:急救模式映像。 boot.img:内核镜像文件,将内核 Image 文件和 resource.img 打包得到,这一点和 Android的 boot.img 不同。 rootfs.img:文件系统分区镜像,对应 rootfs 分区,这里可烧写 SDK 编译得到的 Linux系统,也可烧写 Ubuntu 或 debian 文件系统等。 oem.img:用于给厂家使用,存放厂家的 APP 或数据。只读。oem 的生成可参考编译脚本,生成的源目录见 SDK 源码的 device/rockchip/oem/目录。 userdata.img:存放用户数据,用户可将需要的文件放置到 device/rockchip/userdata/目录下,然后打包烧写。在板子启动的系统中,此分区占用剩余的空间。 十三、程序下载 对于烧写过boot各个镜像的开发板,可以单独下载某一part的镜像。 13.1 进入loader模式 板子开机状态下,按住VOL+按键不松手,再按一下RESET键,等到瑞芯微开发工具提示“发现一个LOADER设备”,松开VOL+。 13.2 设备分区表 点击“设备分区表”,可获取板子EMMC存储镜像地址信息,也就是分区信息。 13.3 烧写 点击路径后面那一列,选择你需要烧写的镜像,点击“执行”,会下载镜像到对应地址中。烧写完成会自动重启。 |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 15:00 , Processed in 0.497161 second(s), Total 42, Slave 36 queries .
