在android source 文件夹中找文件 find ./ -name build.prop
find ./ -name build.prop ./out_20200312/target/product/rk3399s/obj/ETC/system_build_prop_intermediates/build.prop ./out_20200312/target/product/rk3399s/system/build.prop ./out/target/product/rk3399s/obj/ETC/system_build_prop_intermediates/build.prop ./out/target/product/rk3399s/system/build.prop ./out/target/product/rk3399_test/obj/ETC/system_build_prop_intermediates/build.prop ./out/target/product/rk3399_test/system/build.prop ./vendor/rockchip/common/tools/log_capture/crashlog/tests/res/system/build.prop 在文件./out/target/product/rk3399_test/system/build.prop中修改可调整默认旋转方向 ro.sf.hwrotation=0 这里可以90、180、270 (1)打包make snod, (2) 后面./mkimage.sh , (3) 在烧写真机中 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
626 浏览 0 评论
887 浏览 1 评论
784 浏览 1 评论
1997 浏览 1 评论
3242 浏览 1 评论
GMT+8, 2024-12-24 04:11 , Processed in 0.584808 second(s), Total 72, Slave 56 queries .
