Platform: Rockchip
OS: Android 7.1.2 Kernel: 3.10 需求: 通过在相关的kernel文件中建立文件节点,使adroid端app能直接与相关驱动文件交互,完成特定的驱动行为 实现: 第一步:实现驱动文件中建立文件节点 static ssize_t test_read_status(struct device* cd, struct device_attribute* attr,char *buf) { printk(KERN_EMERG "line:%d,%s is calledn", __LINE__, __FUNCTION__); return 0; } static ssize_t test_write_status(struct device* cd, struct device_attribute *attr,const char* buf, size_t len){ int id; //int dir = 1; sscanf(buf, "%d", &id); printk(KERN_ERR "test_write_status id=%dn",id); return len; } static DEVICE_ATTR(test, S_IRUGO | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH| S_IWOTH, test_read_status, test_write_status); static int test_create_sysfs(struct i2c_client *client) { int err; struct device *dev = &(client->dev); printk(KERN_EMERG "line:%d,%s is calledn", __LINE__, __FUNCTION__); err = device_create_file(dev, &dev_attr_test); return err; } 第二步:在app中操作文件节点 private static final String SYS_FILE = "/sys/devices/20072000.i2c/i2c-0/0-0010/test"; private static final File mFile = new File(SYS_FILE); public void Write2File(File file,String mode) { Log.d(TAG,"Write2File,write mode = "+mode); if((file == null) || (!file.exists()) || (mode == null)) return ; try { FileOutputStream fout = new FileOutputStream(file); PrintWriter pWriter = new PrintWriter(fout); pWriter.println(mode); pWriter.flush(); pWriter.close(); fout.close(); } catch(IOException re) { Log.d(TAG,"write error:"+re); return; } } public void test(){ Write2File(mFile, "1"); } |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
626 浏览 0 评论
887 浏览 1 评论
784 浏览 1 评论
1997 浏览 1 评论
3242 浏览 1 评论
GMT+8, 2024-12-23 18:54 , Processed in 0.473865 second(s), Total 40, Slave 34 queries .
