有两个步骤
1、脚本添加 device/rockchip/common/init.rockchip.rc中添加: service my_start_service /system/bin/sh /system/bin/my_start_service.sh user root disabled oneshot on property:sys.boot_completed=1 Start my_start_service device/rockchip/rk3399下创建my_start_service.sh device/rockchip/rk3399/rk3399.mk中添加脚本拷贝: PRODUCT_COPY_FILES += device/rockchip/rk3399/my_start_service.sh:system/bin/my_start_service.sh 2、Selinux域添加domain 只有第一步会报错: Init: service my_start_service does not have a SELinux domain defined 添加并定义my_start_service的te文件: device/rockchip/common/sepolicy下添加my_start_service.te: type my_start_service,domain,mlstrustedsubject; type my_start_service_exec,exec_type,file_type; init_demon_domain(my_start_service) device/rockchip/common/sepolicy/file_contexts中定义start.sh的安全上下文: /system/bin/start.sh u:object_r:my_start_service_exec:s0 3、仍然报错SELinux domain defined 以上操作后还是报错: Init: service my_start_service does not have a SELinux domain defined 根据查阅发现,在service后面还需加上seclabel: service my_start_service /system/bin/sh /system/bin/my_start_service.sh user root disabled onshot seclabel u:r:my_start_service:s0 在启动Service前将seclabel设置为seclabel. 主要用于在rootfs上启动的service,比如ueventd, adbd。在系统分区上运行的service使其有自己的SELinux安全策略,如果不设置,默认使用init的安全策略。 4、添加my_start_service.te文件 devicerockchipcommonsepolicymy_start_service.te type my_start_service,domain,mlstrustedsubject; type my_start_service_exec,exec_type,file_type; init_daemon_domain(my_start_service) allow my_start_service shell_exec:file { getattr read }; allow my_start_service system_file:file { execute_no_trans}; allow my_start_service toolbox_exec:file { getattr execute read open execute_no_trans }; allow my_start_service rootfs:lnk_file { getattr }; allow my_start_service net_data_file:file { read open getattr }; allow my_start_service my_start_service:netlink_route_socket { create setopt bind getattr write nlmsg_write read }; allow my_start_service my_start_service:rawip_socket { create getopt setopt }; allow my_start_service my_start_service:capability { net_admin net_raw }; allow my_start_service my_start_service:udp_socket { create ioctl }; allow my_start_service proc:file { read open getattr }; allow my_start_service netd_socket:sock_file { write }; allow my_start_service netd:unix_stream_socket { connectto }; allow my_start_service proc_net:file { write open }; allow my_start_service shell_exec:file { entrypoint }; allow my_start_service property_socket:sock_file { write }; allow my_start_service net_radio_prop:property_service{ set }; allow my_start_service init:unix_stream_socket { connectto }; allow my_start_service net_data_file:dir { search}; allow rild net_radio_prop:property_service { set }; allow rild pppoe_data_file:dir { search write add_name }; allow rild pppoe_data_file:file { write open getattr create }; allow rild toolbox_exec:file { execute read open execute_no_trans getattr}; allow rild system_prop:property_service { set }; allow rild net_radio_prop:property_service { set }; #添加规则 如 allow my_start_service net_data_file:dir { search}; 权限:search 服务:my_start_service 源文件:net_data_file 目标文件:dir my_start_service.sh #!/system/bin/sh setprop net.ppp0.dns1 8.8.8.8 setprop net.ppp0.dns2 8.8.4.4 ip rule add from all lookup main pref 9999 ifconfig eth0 down ifconfig eth0 up busybox ifconfig eth0 192.168.43.1 ndc netd 5003 tether start 192.168.43.2 192.168.43.254 ndc netd 7 nat enable eth0 ppp0 2 10.6.194.114/24 echo 1 >/proc/sys/net/ipv4/ip_forward iptables -t nat -I PREROUTING -i eth0 -p udp --dport 53 -j DNAT --to-destination 8.8.8.8 service my_start_service /system/bin/sh /system/bin/my_start_service.sh user root disabled oneshot on property:sys.boot_completed=1 Start my_start_service |
【幸狐Omni3576边缘计算套件试用体验】Debian系统安装和性能测试
432 浏览 0 评论
498 浏览 0 评论
1557 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1097 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1802 浏览 1 评论
GMT+8, 2025-3-9 13:29 , Processed in 0.711763 second(s), Total 70, Slave 54 queries .
