1.说明 Lontium LT8631UX HDMI2.0 / 1.4开关具有符合HDMI2.0 / 1.4规格的3:1开关,最大6Gbps高速数据速率,自适应均衡RX输入和预加重TX输出,以支持长电缆应用,板上没有XTAL以节省BOM成本。 LT8631UX HDMI2.0 / 1.4开关自动检测电缆损耗,并自适应优化均衡设置。它支持RX终端电阻校准,以进一步改善信号完整性。 LT8631UX支持符合HDMI2.0 / 1.4规范的DDC / SCDC。集成的DDC和HPD交换机进一步降低了系统制造成本,并简化了系统板上的布线。此封装为QFN64。它的工作温度范围为−40°C至+ 85°C。 2.功能 •3输入,1输出HDMI / DVIlinks •兼容HDMI 1.4 / 2.0 / DVI 1.0 •支持最高6Gbps的数据速率 •RX侧ODT和管理电路 •集成的HPD开关,DDC开关和+ 5V电源指示器开关,大大降低了成本并简化了制造过程 •信号源/接收器连接检测,可实现灵活的系统管理 •支持I2C控制 •低抖动添加 •5V耐压DDC接口 •无需外部晶体 •自适应均衡 •SCDC监视器 3.应用 •用于高级电视机(HDTV)的前面板缓冲器 •独立切换台 •多输入显示 •投影仪 1. Description The Lontium LT8631UX HDMI2.0/1.4 Switch features a 3:1 switch compliant to HDMI2.0/1.4 specification, max 6Gbps high speed data rate, adaptive equalization RX input and pre-emphasized TX output to support long cable application, no XTAL on board to save BOM cost . LT8631UX HDMI2.0/1.4 Switch automatically detectsthe cable loss, and adaptively optimize the equalization setting. It supports RX termination resistor calibration to further improve signal integrity. LT8631UX support DDC/SCDC compliant to HDMI2.0/1.4 specification. The integrated DDC and HPD switches further lower the cost of system manufacture, and simplify the routing on the system board.This package is QFN64. It operate from −40°C to +85°C. 2. Features • 3 inputs, 1output HDMI/DVIlinks • HDMI 1.4/2.0/DVI 1.0compliant • Supports data rates up to 6Gbps • RX side ODTs and management circuitry • Integrated HPD switch, DDC switch, and +5V Power indicator switch, greatly lowering the cost and simplifying the manufacturing process • Source/Sink connection detection for flexible system management • I2C control supported • Low added jitter • 5V-tolerant DDC interfaces • No external crystal is needed • Adaptive equalization • SCDC monitor 3. Application • Front panel buffer for advanced television (HDTV) sets • Standalone switcher • Multiple input displays • Projectors • A/V receivers 1一般说明 LT8631UX是3端口HDMI/DVI交换机,可将多个HDMI/DVI源设备连接到高清电视(HDTV)。基于ClearEdge™ 威廉希尔官方网站 方面,它符合HDMI 2.0/DVI 1.0规范。LT8631UX是一种的高速交换机,它为制造商提供了一种经济高效的方法,可以为其HDTV添加额外的HDMI/DVI端口。多个HDMI/DVI端口允许消费者将各种HDMI/DVI源连接到他们的HDTV。 LT8631UX是一个三对一(3:1)开关,非常适合用于HDTV和a/V接收器的后面板,允许消费者连接多个HDMI/DVI设备,如高清DVD播放器、机顶盒和游戏机。LT8631UX交换机从三个接收器端口选择一个HDMI/DVI信号,并生成完全兼容的HDMI//DVI音频/视频输出,以及完全符合HDMI/DVI规范的DDC和HPD切换。 该芯片还集成了RX侧芯片终端(ODT),并采用了ODT管理电路,以实现经济高效的系统设计和增强的性能。集成的DDC和HPD交换机进一步降低了系统制造成本,并简化了主板上的布线。 2特征 •3个输入,1个输出HDMI/DVI链路 •符合HDMI 2.0/DVI 1.0 •支持高达3.4Gbps的数据速率 •支持深颜色 •接收侧ODT和管理电路 •集成HPD开关、DDC开关和+5V电源指示开关,大大降低了成本,简化了制造过程 •源/接收器连接检测,以实现灵活的系统管理 •支持I2C控制 •低附加抖动 •单个3.3V电源 •5V容差DDC接口 •根据JESD22-a114-B,HPD、DDC、数据/时钟通道ESD保护等级达到3A级。 三。应用 •用于电视(HDTV)的前面板缓冲器 •独立交换机 •多输入显示 •投影仪 •A/V接收器 如需获取更多产品资料PDF,电路图或样品,威廉希尔官方网站
疑问(原厂威廉希尔官方网站
支持)欢迎随时与我们取得联系!!QQ:1124763084
你正在撰写讨论
2186 浏览 2 评论
RK3588 HDMI in 接入设备如何获取HDMI in 传入的音频?
2581 浏览 1 评论
24461 浏览 1 评论
【KV260威廉希尔官方网站 分享】宿主机构建Gstreamer
1315 浏览 0 评论
硬创大赛项目专访 | 田奕鑫:专注细分领域创新,我们和行业巨头“化敌为友”
94749 浏览 1 评论
GMT+8, 2025-2-4 00:59 , Processed in 0.350254 second(s), Total 32, Slave 25 queries .
