最近在rk平台上调试一款32寸的LVDS,屏是1920*1080分辨率,双路8bit RGB888 格式的屏,在rk3288-evb-android-rk808-lvds.dts下面的lvds修改如下,编译烧录进去屏幕一直循环播放红绿蓝图片。
请大侠们分析分析,屏的规格关键信息如下。。 &lvds_panel { status = "okay"; ; //backlight = <&backlight>; bus-format = power-supply = <&vcc_lcd>; delay,disable = <10>; enable-gpios = <&gpio7 4 GPIO_ACTIVE_HIGH>; //rockchip,data-mapping = "jeida"; rockchip,data-mapping = "vesa"; rockchip,data-width = <24>; rockchip,output = "duallvds"; display-timings { native-mode = <&timing0>; timing0: timing0 { clock-frequency = <148000000>; hactive = <1920>; /* Horizontal display area thd 1024 DCLK */ vactive = <1080>; /* Vertical display area tvd 600 H */ hback-porch = <48>; /* HS Width +Back Porch 160 160 160 DCLK (Thw+ thbp)*/ hfront-porch = <60>; /* HS front porch thfp 16 160 216 DCLK */ vback-porch = <8>; /* VS front porch tvfp 1 12 127 H */ vfront-porch = <33>; /* VS Width+Back Porch 23 23 23 H (Tvw+ tvbp) */ hsync-len = <32>; /* HS Pulse Width thw 1 - 140 DCLK */ vsync-len = <4>; /* VS Pulse Width tvw 1 - 20 H */ hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <0>; }; }; }; |
364 浏览 0 评论
484 浏览 0 评论
从性能到成本,深度剖析 RK3588 与 RK3576 怎么选
423 浏览 0 评论
RK3588 原厂设计资料首次公开(规格书+原理图+设计说明+DDR参考),速抢
1846 浏览 0 评论
1096 浏览 0 评论
GMT+8, 2025-2-13 15:36 , Processed in 0.714586 second(s), Total 42, Slave 36 queries .
