1 找到 在要编译的rk3288-evb-android-rk808-edp.dts
加入以下mipi dts配置: /dts-v1/; #include "rk3288-evb.dtsi" #include "rk3288-android.dtsi" #include #include #include 。。。。。。。。 // added for mipi dsi start <<< &dsi0 { status = "okay"; rockchip,lane-rate = <420>; panel: panel { status = "okay"; compatible = "simple-panel-dsi"; reg = <0>; backlight = ; //由于我们项目中有两个1V8和3V3的使能引脚,所以要配置 3v3_gpio = ;//3v3使能引脚 enable = ; //1V8使能引脚 reset = ;//复位引脚 dsi,flags = ; dsi,format = ; bus-format = ; dsi,lanes = <4>; //dsi,channel = <1>; reset-delay-ms = <30>; init-delay-ms = <120>; enable-delay-ms = <30>; prepare-delay-ms = <30>; unprepare-delay-ms = <30>; panel-init-sequence = [ //此部分初始化命令一定要正确,此部分命令可找fae要 15 00 02 E0 00 //15:表示DCS 命 令 的 类 型,其长度等于2, // 00:表示 发送完该命令以后需要延时的时间,单位为 ms //02:表示命令 payload 的长度 //E0 00 表示实际发送的 payload命令 其中 E0代表要发送的寄存器地址,00代表往0xe0写入的数据 15 00 02 E1 93 15 00 02 E2 65 15 00 02 E3 F8 15 00 02 E0 00 15 00 02 70 02 15 00 02 71 23 15 00 02 72 06 15 00 02 80 03 15 00 02 E6 02 15 00 02 E7 02 15 00 02 E0 01 15 00 02 00 00 15 00 02 01 A0 15 00 02 03 00 15 00 02 04 A0 15 00 02 17 00 15 00 02 18 B1 15 00 02 19 00 15 00 02 1A 00 15 00 02 1B B1 15 00 02 1C 00 15 00 02 1F 3E 15 00 02 20 2D 15 00 02 21 2D 15 00 02 22 0E 15 00 02 37 19 15 00 02 38 05 15 00 02 39 08 15 00 02 3A 12 15 00 02 3C 78 15 00 02 3E 80 15 00 02 3F 80 15 00 02 40 06 15 00 02 41 A0 //15 00 02 4A 35 // test mode on 15 00 02 55 0F 15 00 02 56 01 15 00 02 57 69 15 00 02 58 0A 15 00 02 59 0A 15 00 02 5A 28 15 00 02 5B 19 15 00 02 5D 7C 15 00 02 5E 5E 15 00 02 5F 4E 15 00 02 60 41 15 00 02 61 3F 15 00 02 62 31 15 00 02 63 37 15 00 02 64 23 15 00 02 65 3E 15 00 02 66 3F 15 00 02 67 40 15 00 02 68 5E 15 00 02 69 4F 15 00 02 6A 57 15 00 02 6B 4B 15 00 02 6C 49 15 00 02 6D 2F 15 00 02 6E 03 15 00 02 6F 00 15 00 02 70 7C 15 00 02 71 5E 15 00 02 72 4E 15 00 02 73 41 15 00 02 74 3F 15 00 02 75 31 15 00 02 76 37 15 00 02 77 23 15 00 02 78 3E 15 00 02 79 3F 15 00 02 7A 40 15 00 02 7B 5E 15 00 02 7C 4F 15 00 02 7D 57 15 00 02 7E 4B 15 00 02 7F 49 15 00 02 80 2F 15 00 02 81 03 15 00 02 82 00 15 00 02 E0 02 15 00 02 00 47 15 00 02 01 47 15 00 02 02 45 15 00 02 03 45 15 00 02 04 4B 15 00 02 05 4B 15 00 02 06 49 15 00 02 07 49 15 00 02 08 41 15 00 02 09 1F 15 00 02 0A 1F 15 00 02 0B 1F 15 00 02 0C 1F 15 00 02 0D 1F 15 00 02 0E 1F 15 00 02 0F 43 15 00 02 10 1F 15 00 02 11 1F 15 00 02 12 1F 15 00 02 13 1F 15 00 02 14 1F 15 00 02 15 1F 15 00 02 16 46 15 00 02 17 46 15 00 02 18 44 15 00 02 19 44 15 00 02 1A 4A 15 00 02 1B 4A 15 00 02 1C 48 15 00 02 1D 48 15 00 02 1E 40 15 00 02 1F 1F 15 00 02 20 1F 15 00 02 21 1F 15 00 02 22 1F 15 00 02 23 1F 15 00 02 24 1F 15 00 02 25 42 15 00 02 26 1F 15 00 02 27 1F 15 00 02 28 1F 15 00 02 29 1F 15 00 02 2A 1F 15 00 02 2B 1F 15 00 02 58 10 15 00 02 59 00 15 00 02 5A 00 15 00 02 5B 30 15 00 02 5C 03 15 00 02 5D 30 15 00 02 5E 01 15 00 02 5F 02 15 00 02 60 30 15 00 02 61 01 15 00 02 62 02 15 00 02 63 04 15 00 02 64 7F 15 00 02 65 05 15 00 02 66 12 15 00 02 67 73 15 00 02 68 05 15 00 02 69 04 15 00 02 6A 7F 15 00 02 6B 09 15 00 02 6C 00 15 00 02 6D 04 15 00 02 6E 04 15 00 02 6F 88 15 00 02 70 00 15 00 02 71 00 15 00 02 72 06 15 00 02 73 7B 15 00 02 74 00 15 00 02 75 3C 15 00 02 76 00 15 00 02 77 0D 15 00 02 78 2C 15 00 02 79 00 15 00 02 7A 00 15 00 02 7B 00 15 00 02 7C 00 15 00 02 7D 03 15 00 02 7E 7B 15 00 02 E0 01 15 00 02 0E 01 15 00 02 E0 03 15 00 02 98 2F 15 00 02 E0 04 15 00 02 2B 2B 15 00 02 2E 44 15 00 02 09 10 15 00 02 2D 03 15 00 02 E0 00 05 78 01 11 05 32 01 29 //05:表示DCS 命 令 的 类 型,其长度等于1,还有一个39表示这是一个 DCS 长包命令,payload 长度大于 2。 ]; panel-exit-sequence = [ 05 16 01 28 05 78 01 10 ]; display-timings { native-mode = ; timing0: timing0 { clock-frequency = <67000000>; hactive = <800>; vactive = <1280>; hback-porch = <10>; hfront-porch = <42>; hsync-len = <20>; vback-porch = <4>; vfront-porch = <8>; vsync-len = <4>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <0>; }; }; }; }; &route_dsi0 { status = "okay"; }; &dsi0_in_vopb { status = "okay"; }; &dsi0_in_vopl { status = "disabled"; }; // added mipi dsi end 。。。。。。。。。。。。。。 注:由原理图可以知道1v8使能引脚是GPIO5_B5(gpio5 13)和3v3使能引脚是GPIO0_B5(gpio0 13), reset引脚是GPIO7_A4(gpio7 4) 在驱动中增加3v3使能引脚的配置,注意3v3使能引脚是低电平有效 diff --git a/drivers/gpu/drm/panel/panel-simple.c b/drivers/gpu/drm/panel/panel-simple.c old mode 100644 new mode 100755 index daf891c..adbdc7d --- a/drivers/gpu/drm/panel/panel-simple.c +++ b/drivers/gpu/drm/panel/panel-simple.c //增加3v3gpio @@ -114,6 +114,7 @@ struct panel_simple { struct gpio_desc *enable_gpio; struct gpio_desc *reset_gpio; + struct gpio_desc *vdd3_3_gpio; int cmd_type; struct gpio_desc *spi_sdi_gpio; //掉电时序 3v3使能引脚是低电平有效,空闲电平是高电平 @@ -603,6 +611,8 @@ static int panel_simple_unprepare(struct drm_panel *panel) if (p->enable_gpio) gpiod_direction_output(p->enable_gpio, 0); + if (p->vdd3_3_gpio) + gpiod_direction_output(p->vdd3_3_gpio, 1); panel_simple_regulator_disable(panel); //上电时序 3v3使能引脚是低电平有效,空闲电平是高电平 @@ -630,6 +641,8 @@ static int panel_simple_prepare(struct drm_panel *panel) if (p->enable_gpio) gpiod_direction_output(p->enable_gpio, 1); + if (p->vdd3_3_gpio) + gpiod_direction_output(p->vdd3_3_gpio, 0); if (p->desc && p->desc->delay.prepare) msleep(p->desc->delay.prepare); return -ENOMEM; //3v3_gpio的dts @@ -799,6 +818,12 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc) dev_err(dev, "failed to request enable GPIO: %dn", err); return err; } + panel->vdd3_3_gpio = devm_gpiod_get_optional(dev, "3v3_gpio", 0); + if (IS_ERR(panel->vdd3_3_gpio)) { + err = PTR_ERR(panel->vdd3_3_gpio); + dev_err(dev, "failed to request vdd3_3_gpio GPIO: %dn", err); + return err; + } panel->reset_gpio = devm_gpiod_get_optional(dev, "reset", 0); if (IS_ERR(panel->reset_gpio)) { //关机函数,3v3使能引脚是低电平有效,空闲电平是高电平 @@ -935,6 +963,8 @@ static void panel_simple_shutdown(struct device *dev) if (panel->enable_gpio) gpiod_direction_output(panel->enable_gpio, 0); + if (panel->vdd3_3_gpio) + gpiod_direction_output(panel->vdd3_3_gpio, 1); panel_simple_regulator_disable(&panel->base); } 2.编译kernel,烧写固件,绑定mipi成功会有以下log出现 Line 618: [ 0.923158] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_dsi_ops) Line 619: [ 0.923170] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 在rk3288.dtsi中可以知道mipi地址是 ff960000 。。。。。。。。 dsi0: dsi@ff960000 { compatible = "rockchip,rk3288-mipi-dsi", "snps,dw-mipi-dsi"; reg = <0x0 0xff960000 0x0 0x4000>; interrupts = ; clocks = , ; clock-names = "ref", "pclk"; resets = ; reset-names = "apb"; power-domains = ; rockchip,grf = ; #address-cells = <1>; #size-cells = <0>; status = "disabled"; ports { #address-cells = <1>; #size-cells = <0>; dsi0_in: port { #address-cells = <1>; #size-cells = <0>; dsi0_in_vopb: endpoint@0 { reg = <0>; remote-endpoint = ; }; dsi0_in_vopl: endpoint@1 { reg = <1>; remote-endpoint = ; }; }; }; }; |
1250 浏览 0 评论
617 浏览 0 评论
1109 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】自行转换大模型失败,搞一个语音小智玩玩吧.
486 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】使用rkllm运行DeepSeek的服务模式体验
892 浏览 0 评论
GMT+8, 2025-4-6 06:01 , Processed in 0.450793 second(s), Total 42, Slave 36 queries .
