Android7.1][引导修改视频为MP4格式更新
--git a/device/rockchip/common/BoardConfig.m b/device/rockchip/common/BoardConfig.mk index3457a30..448245 100755 --- a/device/rockchip/common/BoardConfig.mk +++ b/device/rockchip/common/BoardConfig.mk @@ -300,7 +300,7 @@ BOARD_HAVE_DONGLE ?= true BOOT_SHUTDOWN_ANIMATION_RINGING ?= true #for boot video enable -BOOT_VIDEO_ENABLE ?= false +BOOT_VIDEO_ENABLE ?= true #for pms 多线程扫描 BOARD_ENABLE_PMS_MULTI_THREAD_SCAN ?= false diff --git a/device/rockchip/common/bootvideo/bootvideo.mk b/device/rockchip/common/bootvideo/bootvideo.mk 索引 9b9c8d3..afac264 100755 --- a/device/rockchip/common/bootvideo/bootvideo.mk +++ b/device/rockchip/common/bootvideo/bootvideo.mk @@ -1,11 +1,11 @@ CUR_PATH := device/rockchip /common/bootvideo -HAVE_BOOT_VIDEO := $(shell test -f $(CUR_PATH)/bootanimation.ts && echo yes) +HAVE_BOOT_VIDEO := $(shell test -f $(CUR_PATH)/bootanimation.mp4 && echo yes) ifeq ( $(HAVE_BOOT_VIDEO), 是的) -PRODUCT_COPY_FILES += $(CUR_PATH)/bootanimation.ts:system/media/bootanimation.ts +PRODUCT_COPY_FILES += $(CUR_PATH)/bootanimation.mp4:system/media/bootanimation.mp4 endif PRODUCT_PROPERTY_OVERRIDES + = - persist.sys.bootvideo.enable=true + ## persist.sys.bootvideo.enable=true persist.sys.bootvideo.showtime=-2 diff --git a/frameworks/base/cmds/bootanimation/BootAnimation.cpp b/frameworks/base/cmds/bootanimation/BootAnimation.cpp 索引 24c8fa4..18220e7 100755 --- a /frameworks/base/cmds/bootanimation/BootAnimation.cpp +++ b/frameworks/base/cmds/bootanimation/BootAnimation.cpp @@ -70,7 +70,7 @@ static const char SYSTEM_SHUTDOWNANIMATION_FILE[] = "/system /media/shutdownanima static const char SYSTEM_ENCRYPTED_BOOTANIMATION_FILE[] = "/system/media/bootanimation-encrypted.zip"; //支持开机视频 static const char DATA_BOOTVIDEO_FILE[] = "/data/local/bootanimation.ts"; -static const char SYSTEM_BOOTVIDEO_FILE[] = "/system/media/bootanimation.ts"; +static const char SYSTEM_BOOTVIDEO_FILE[] = "/system/media/bootanimation.mp4"; 静态 const char SYSTEM_DATA_DIR_PATH[] = "/data/system"; 静态 const char SYSTEM_TIME_DIR_NAME[] = "时间"; 静态 const char SYSTEM_TIME_DIR_PATH[] = "/data/system/time"; @@ -366,7 +366,7 @@ status_t BootAnimation::readyToRun() { } else if (access(DATA_BOOTVIDEO_FILE, R_OK) == 0){ mVideoFile = (char*)DATA_BOOTVIDEO_FILE; } - property_get("persist.sys.bootvideo.enable",decrypt, "false"); + property_get("persist.sys.bootvideo.enable",decrypt, "true"); 字符值[PROPERTY_VALUE_MAX]; property_get("坚持。 if(mVideoFile != NULL && !strcmp(decrypt, "true") &&(atoi(value)!=0)) { @@ -482,7 +482,7 @@ void BootAnimation::checkExit() { property_get( EXIT_PROP_NAME,值,“0”); int exitnow = atoi(值); //添加开机视频功能 -property_get("persist.sys.bootvideo.enable",value, "false"); + property_get("persist.sys.bootvideo.enable",value, "true"); const nsecs_t realBootanimaTime = systemTime()-mStartbootanimaTime; if (exitnow) { //添加开机视频功能 |
436 浏览 0 评论
1477 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1077 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1701 浏览 1 评论
816 浏览 0 评论
GMT+8, 2025-3-6 11:49 , Processed in 0.585360 second(s), Total 70, Slave 54 queries .
