因为HDMI I2S & CODEC I2S 在芯片内部都是同一个I2S,
因此CODEC有声音时候,也有声音通过I2S 发送到HDMI, 这样取消掉HDMI Audio 检测即可实现HDMI &codec 喇叭同时输出。 diff --git a/services/java/com/android/server/WiredAccessoryManager.java b/services/java/com/android/server/WiredAccessoryManager.java index c8d3510..2fb231e 100644 --- a/services/java/com/android/server/WiredAccessoryManager.java +++ b/services/java/com/android/server/WiredAccessoryManager.java @@ -374,7 +374,7 @@ final class WiredAccessoryManager implements WiredAccessoryCallbacks { // // If the kernel does not have an "hdmi_audio" switch, just fall back on the older // "hdmi" switch instead. - uei = new UEventInfo(NAME_HDMI_AUDIO, BIT_HDMI_AUDIO, 0); +/* uei = new UEventInfo(NAME_HDMI_AUDIO, BIT_HDMI_AUDIO, 0); if (uei.checkSwitchExists()) { retVal.add(uei); } else { @@ -385,7 +385,7 @@ final class WiredAccessoryManager implements WiredAccessoryCallbacks { Slog.w(TAG, "This kernel does not have HDMI audio support"); } } - +*/ return retVal; } |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 12:25 , Processed in 0.345264 second(s), Total 38, Slave 33 queries .
