Platform: Rockchip
OS: Android 6.0 Kernel: 3.10.92 现象: AudioService中把音量设置到最小,理论上speaker应该听不到声音,但是依然还有。 分析: 这时对应的curve是 const VolumeCurvePoint Gains::sSpeakerVoiceVolumeCurve[Volume::VOLCNT] = { {1, -24.0f}, {33, -16.0f}, {66, -8.0f}, {100, 0.0f} }; 当audio service设置index为最小(index = 1)时, float Gains::volIndexToDb(Volume::device_category deviceCategory, const StreamDescriptor& streamDesc, int indexInUi) { ..... //volId计算出来是0 int volIdx = (nbSteps * (indexInUi - streamDesc.getVolumeIndexMin())) / (streamDesc.getVolumeIndexMax() - streamDesc.getVolumeIndexMin()); //curve[Volume::VOLKNEE1].mIndex为0,因此不会返回VOLUME_MIN_DB if (volIdx < curve[Volume::VOLMIN].mIndex) { // out of bounds return VOLUME_MIN_DB; } else if (volIdx < curve[Volume::VOLKNEE1].mIndex) { //实际上是跑进这里来了 segment = 0; } else if (volIdx < curve[Volume::VOLKNEE2].mIndex) { segment = 1; } else if (volIdx <= curve[Volume::VOLMAX].mIndex) { segment = 2; } else { return 0.0f; } ...... } 解决方法: kris@:~/rk3288/frameworks/av/services/audiopolicy/enginedefault$ g df diff --git a/services/audiopolicy/enginedefault/src/Gains.cpp b/services/audiopolicy/enginedefault/src/Gains.cpp index df853db..49555aa 100644 --- a/services/audiopolicy/enginedefault/src/Gains.cpp +++ b/services/audiopolicy/enginedefault/src/Gains.cpp @@ -95,7 +95,7 @@ Gains::sDefaultVoiceVolumeCurve[Volume::VOLCNT] = { const VolumeCurvePoint Gains::sSpeakerVoiceVolumeCurve[Volume::VOLCNT] = { - {0, -24.0f}, {33, -16.0f}, {66, -8.0f}, {100, 0.0f} + {1, -24.0f}, {33, -16.0f}, {66, -8.0f}, {100, 0.0f} }; |
134 浏览 0 评论
1441 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1072 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1651 浏览 1 评论
789 浏览 0 评论
GMT+8, 2025-3-4 16:48 , Processed in 0.742067 second(s), Total 69, Slave 54 queries .
