Platform: Rockchip
OS: Android 6.0 Kernel: 3.10.92 ,这里看一下它的移除过程是怎样的,当选择界面的FORGET时,会触发以下流程调用。 onForget -> forget -> mWifiManager.forget -> WiFiSettings.java //参数为当前选择forget的config的netid sAsyncChannel.sendMessage -> 异步通道发送给WifiStateMachine,cmd是FORGET_NETWORK processMessage -> WifiStateMachine.java //当前处于ConnectedState,调用父类的父类ConnectModeState mWifiConfigStore.getWifiConfiguration //根据netid得到对应的config mWifiConfigStore.canModifyNetwork //检查调用者是否有权限remove network mWifiConfigStore.forgetNetwork -> removeConfigAndSendBroadcastIfNeeded -> //执行清理操作 mConfiguredNetworks.remove //从ConfiguredNetworks中移除 mScanDetailCaches.remove sendConfiguredNetworksChangedBroadcast //发广播wifi状态变化: WifiManager.CONFIGURED_NETWORKS_CHANGED_ACTION mWifiNative.removeNetwork -> doBooleanCommand //通知WPAS移除network,命令是"REMOVE_NETWORK " + netId,这和用wpa_cli客户端的方法是一样的 mWifiNative.saveConfig -> doBooleanCommand //通知WPAS更新配置文件wpa_supplicant.conf handleEvent WifiMonitor.java -> WPAS移除完毕之后会发DISCONNECTED事件过来,由WifiMonitor负责接收 handleNetworkStateChange -> notifyNetworkStateChange -> mStateMachine.sendMessage -> //NETWORK_DISCONNECTION_EVENT, 发给WifiStateMachine processMessage -> //ConnectedState dispatchEvent -> 接着WifiMonitor又收到WPAS发来的STATE_CHANGE事件 handleSupplicantStateChange -> notifySupplicantStateChange -> // mStateMachine.sendMessage -> //SUPPLICANT_STATE_CHANGE_EVENT processMessage -> //当前处于ConnectedState,调用父类的父类ConnectModeState handleNetworkDisconnect -> stopRssiMonitoringOffload -> //通知HAL stop rssi mWifiNative.stopRssiMonitoring -> stopRssiMonitoringNative -> android_net_wifi_stop_rssi_monitoring_native -> hal_fn.wifi_stop_rssi_monitoring clearCurrentConfigBSSID -> //清理bssid clearConfigBSSID stopDhcp -> //关dchp,之前有分析过startdhcp的 handlePostDhcpSetup mDhcpStateMachine.sendMessage //DhcpStateMachine.CMD_STOP_DHCP processMessage -> //DhcpBoundState processMessage -> //DhcpHaveAddressState的父类DhcpState transitionTo(mStoppedState) -> exit -> //DhcpHaveAddressState setIpAddress -> mNMService.setInterfaceConfig //通知netd设置ip mNwService.clearInterfaceAddresses mNwService.disableIpv6 setNetworkDetailedState //这部分和ConnectionService有关,打算后面再细讲 mNetworkAgent.sendNetworkInfo sendNetworkStateChangeBroadcast //广播WifiManager.NETWORK_STATE_CHANGED_ACTION transitionTo(mDisconnectedState) -> exit -> //ConnectedState setScanAlarm //关闭周期性scan enter -> //DisconnectedState startScan //断开连接后进入定期扫描 |
1645 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3414 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3792 浏览 1 评论
GMT+8, 2024-9-21 15:25 , Processed in 0.661779 second(s), Total 72, Slave 56 queries .
