0.dts190x1080 -- diff.git1.build.prop 中添加的
构图属性 下面: persist.sy***uffer.main=1920x600@60 2.hardware/hwcomposer/hwcomposer 合入下面修改: diff/hwcomposer .cpp b/hwcomposer.cpp 索引 0fd2177..3ad13a9 100755 --- a/hwcomposer.cpp +++ b/hwcomposer.cpp @@ -3498,8 +3498,10 @@ static int hwc_get_display_configs(struct hwc_composer_device_1 *dev, char framebuffer_size[PROPERTY_VALUE_MAX]; uint32_t width = 0, height = 0, vrefresh = 0; + if (display == HWC_DISPLAY_PRIMARY) property_get("persist.sys.framebuffer.main", framebuffer_size, "use_baseparameter"); - + else if (显示 == HWC_DISPLAY_EXTERNAL) + property_get("persist.sys.framebuffer.aux", framebuffer_size, "use_baseparameter"); /* * 如果未设置 framebuffer_size,则通过 libin 从 baseparameter 获取它 */ @@ -2298,7 +2301,8 @@ static int hwc_prepare(hwc_composer_device_1_t *dev, size_t num_displays, hd->rel_yres = mode.v_display(); hd->v_total = mode.v_total(); hd->w_scale = (float)mode.h_display() / hd->framebuffer_width; - hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + //hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + hd->h_scale = 1.0; int fbSize = hd->framebuffer_width * hd->framebuffer_height; //获取显示平面大小 std::vector @@ -3638,7 +3647,8 @@ static int hwc_set_active_config(struct hwc_composer_device_1 *dev, int display, return -ENOENT; } hd->w_scale = (float)mode.h_display() / hd->framebuffer_width; - hd ->h_scale = (float)mode.v_display() / hd->framebuffer_height; + //hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + hd->h_scale = 1.0; c- >set_current_mode(mode); ctx->drm.UpdateDisplayRoute(); |
482 浏览 0 评论
1529 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1087 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1752 浏览 1 评论
856 浏览 0 评论
GMT+8, 2025-3-7 01:55 , Processed in 0.951823 second(s), Total 40, Slave 34 queries .
