1 用#把路径为/packages/apps/Dialer/Android.mk的文件屏蔽掉此编译规则 wangxd@build-server-100:~/work/dsy/rk3288-Android-7.0/packages/apps/Dialer((4095f56...))$ git diff diff --git a/Android.mk b/Android.mk old mode 100644 new mode 100755 index 975d396..23a87ab --- a/Android.mk +++ b/Android.mk @@ -1,73 +1,73 @@ -LOCAL_PATH:= $(call my-dir) -include $(CLEAR_VARS) - -LOCAL_MODULE_TAGS := optional - -incallui_dir := InCallUI -contacts_common_dir := ../ContactsCommon -phone_common_dir := ../PhoneCommon - -ifeq ($(TARGET_BUILD_APPS),) -support_library_root_dir := frameworks/support -else -support_library_root_dir := prebuilts/sdk/current/support -endif - -src_dirs := src - $(incallui_dir)/src - $(contacts_common_dir)/src - $(phone_common_dir)/src - -res_dirs := res - $(incallui_dir)/res - $(contacts_common_dir)/res - $(contacts_common_dir)/icons/res - $(phone_common_dir)/res - -src_dirs += - src-N - $(incallui_dir)/src-N - $(contacts_common_dir)/src-N - $(phone_common_dir)/src-N - -LOCAL_SRC_FILES := $(call all-java-files-under, $(src_dirs)) -LOCAL_RESOURCE_DIR := $(addprefix $(LOCAL_PATH)/, $(res_dirs)) - $(support_library_root_dir)/v7/cardview/res - $(support_library_root_dir)/v7/recyclerview/res - $(support_library_root_dir)/v7/appcompat/res - $(support_library_root_dir)/design/res - -LOCAL_AAPT_FLAGS := - --auto-add-overlay - --extra-packages android.support.v7.appcompat - --extra-packages android.support.v7.cardview - --extra-packages android.support.v7.recyclerview - --extra-packages android.support.design - --extra-packages com.android.incallui - --extra-packages com.android.contacts.common - --extra-packages com.android.phone.common - -LOCAL_STATIC_JAVA_LIBRARIES := - android-common - android-support-v13 - android-support-v4 - android-support-v7-appcompat - android-support-v7-cardview - android-support-v7-recyclerview - android-support-design - com.android.vcard - guava - libphonenumber - -LOCAL_PACKAGE_NAME := Dialer -LOCAL_CERTIFICATE := shared -LOCAL_PRIVILEGED_MODULE := true - -LOCAL_PROGUARD_FLAG_FILES := proguard.flags $(incallui_dir)/proguard.flags - -LOCAL_SDK_VERSION := current - -include $(BUILD_PACKAGE) - -# Use the following include to make our test apk. -include $(call all-makefiles-under,$(LOCAL_PATH)) +#LOCAL_PATH:= $(call my-dir) +#include $(CLEAR_VARS) +# +#LOCAL_MODULE_TAGS := optional +# +#incallui_dir := InCallUI +#contacts_common_dir := ../ContactsCommon +#phone_common_dir := ../PhoneCommon +# +#ifeq ($(TARGET_BUILD_APPS),) +#support_library_root_dir := frameworks/support +#else +#support_library_root_dir := prebuilts/sdk/current/support +#endif +# +#src_dirs := src +# $(incallui_dir)/src +# $(contacts_common_dir)/src +# $(phone_common_dir)/src +# +#res_dirs := res +# $(incallui_dir)/res +# $(contacts_common_dir)/res +# $(contacts_common_dir)/icons/res +# $(phone_common_dir)/res +# +#src_dirs += +# src-N +# $(incallui_dir)/src-N +# $(contacts_common_dir)/src-N +# $(phone_common_dir)/src-N +# +#LOCAL_SRC_FILES := $(call all-java-files-under, $(src_dirs)) +#LOCAL_RESOURCE_DIR := $(addprefix $(LOCAL_PATH)/, $(res_dirs)) +# $(support_library_root_dir)/v7/cardview/res +# $(support_library_root_dir)/v7/recyclerview/res +# $(support_library_root_dir)/v7/appcompat/res +# $(support_library_root_dir)/design/res +# +#LOCAL_AAPT_FLAGS := +# --auto-add-overlay +# --extra-packages android.support.v7.appcompat +# --extra-packages android.support.v7.cardview +# --extra-packages android.support.v7.recyclerview +# --extra-packages android.support.design +# --extra-packages com.android.incallui +# --extra-packages com.android.contacts.common +# --extra-packages com.android.phone.common +# +# +#LOCAL_STATIC_JAVA_LIBRARIES := +# android-common +# android-support-v13 +# android-support-v4 +# android-support-v7-appcompat +# android-support-v7-cardview +# android-support-v7-recyclerview +# android-support-design +# com.android.vcard +# guava +# libphonenumber +# +#LOCAL_PACKAGE_NAME := Dialer +#LOCAL_CERTIFICATE := shared +#LOCAL_PRIVILEGED_MODULE := true +# +#LOCAL_PROGUARD_FLAG_FILES := proguard.flags $(incallui_dir)/proguard.flags +# +#LOCAL_SDK_VERSION := current +# +#include $(BUILD_PACKAGE) +# +## Use the following include to make our test apk. +#include $(call all-makefiles-under,$(LOCAL_PATH)) **2 用#把路径为/packages/apps/ContactsAndroid.mk的文件也要屏蔽掉此编译规则 ** wangxd@build-server-100:~/work/dsy/rk3288-Android-7.0/packages/apps/Contacts((15922c5...))$ git diff diff --git a/Android.mk b/Android.mk old mode 100644 new mode 100755 index f0fdce2..52e45fd --- a/Android.mk +++ b/Android.mk @@ -1,52 +1,52 @@ -LOCAL_PATH:= $(call my-dir) -include $(CLEAR_VARS) - -LOCAL_MODULE_TAGS := optional - -contacts_common_dir := ../ContactsCommon -phone_common_dir := ../PhoneCommon - -ifeq ($(TARGET_BUILD_APPS),) -support_library_root_dir := frameworks/support -else -support_library_root_dir := prebuilts/sdk/current/support -endif - -src_dirs := src $(contacts_common_dir)/src $(phone_common_dir)/src -res_dirs := res res-aosp $(contacts_common_dir)/res $(contacts_common_dir)/icons/res $(phone_com -asset_dirs := $(contacts_common_dir)/assets - -LOCAL_SRC_FILES := $(call all-java-files-under, $(src_dirs)) -LOCAL_RESOURCE_DIR := $(addprefix $(LOCAL_PATH)/, $(res_dirs)) - $(support_library_root_dir)/v7/cardview/res -LOCAL_ASSET_DIR := $(addprefix $(LOCAL_PATH)/, $(asset_dirs)) - -LOCAL_AAPT_FLAGS := - --auto-add-overlay - --extra-packages com.android.contacts.common - --extra-packages com.android.phone.common - --extra-packages android.support.v7.cardview - -LOCAL_STATIC_JAVA_LIBRARIES := - com.android.vcard - android-common - guava - android-support-v13 - android-support-v7-cardview - android-support-v7-palette - android-support-v4 - libphonenumber - -LOCAL_PACKAGE_NAME := Contacts -LOCAL_CERTIFICATE := shared -LOCAL_PRIVILEGED_MODULE := true - -LOCAL_PROGUARD_FLAG_FILES := proguard.flags - -LOCAL_SDK_VERSION := current -LOCAL_MIN_SDK_VERSION := 21 - -include $(BUILD_PACKAGE) - -# Use the folloing include to make our test apk. -include $(call all-makefiles-under,$(LOCAL_PATH)) +#LOCAL_PATH:= $(call my-dir) +#include $(CLEAR_VARS) +# +#LOCAL_MODULE_TAGS := optional +# +#contacts_common_dir := ../ContactsCommon +#phone_common_dir := ../PhoneCommon +# +#ifeq ($(TARGET_BUILD_APPS),) +#support_library_root_dir := frameworks/support +#else +#support_library_root_dir := prebuilts/sdk/current/support +#endif +# +#src_dirs := src $(contacts_common_dir)/src $(phone_common_dir)/src +#res_dirs := res res-aosp $(contacts_common_dir)/res $(contacts_common_dir)/icons/res $(phone_co +#asset_dirs := $(contacts_common_dir)/assets +# +#LOCAL_SRC_FILES := $(call all-java-files-under, $(src_dirs)) +#LOCAL_RESOURCE_DIR := $(addprefix $(LOCAL_PATH)/, $(res_dirs)) +# $(support_library_root_dir)/v7/cardview/res +#LOCAL_ASSET_DIR := $(addprefix $(LOCAL_PATH)/, $(asset_dirs)) +# +#LOCAL_AAPT_FLAGS := +# --auto-add-overlay +# --extra-packages com.android.contacts.common +# --extra-packages com.android.phone.common +# --extra-packages android.support.v7.cardview +# +#LOCAL_STATIC_JAVA_LIBRARIES := +# com.android.vcard +# android-common +# guava +# android-support-v13 +# android-support-v7-cardview +# android-support-v7-palette +# android-support-v4 +# libphonenumber +# +#LOCAL_PACKAGE_NAME := Contacts +#LOCAL_CERTIFICATE := shared +#LOCAL_PRIVILEGED_MODULE := true +# +#LOCAL_PROGUARD_FLAG_FILES := proguard.flags +# +#LOCAL_SDK_VERSION := current +#LOCAL_MIN_SDK_VERSION := 21 +# +#include $(BUILD_PACKAGE) +# +## Use the folloing include to make our test apk. +#include $(call all-makefiles-under,$(LOCAL_PATH)) |
1672 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3437 浏览 0 评论
2301 浏览 1 评论
3521 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3793 浏览 1 评论
GMT+8, 2024-9-22 05:35 , Processed in 0.518666 second(s), Total 72, Slave 56 queries .
