Platform: RK3288 OS: Android 7.1.2 Kernel: v4.4.143 问题: HDMI输出给个别电视机时,电视机无声音 分析步骤: 1、用以下命令测试HDMI是否有输出 tinyplay 44.1k_2ch_16b_1k_15s.wav -D 0 -d 1 -c 2 -b 16 -r 44100 指令播放附件wav文件 结论:该命令HDMI有声音输出 2、打开音频相关的日志输出并提供Logcat日志给RK diff --git a/tinyalsa_hal/alsa_route.c b/tinyalsa_hal/alsa_route.c index f28f3a6..b550b91 100755 --- a/tinyalsa_hal/alsa_route.c +++ b/tinyalsa_hal/alsa_route.c @@ -43,7 +43,7 @@ #define LOG_TAG "alsa_route" -//#define LOG_NDEBUG 0 +#define LOG_NDEBUG 0 #include #include diff --git a/tinyalsa_hal/audio_hw.c b/tinyalsa_hal/audio_hw.c index a7445ba..18164f2 100755 --- a/tinyalsa_hal/audio_hw.c +++ b/tinyalsa_hal/audio_hw.c @@ -70,7 +70,7 @@ * @date 2015-08-24 */ -//#define LOG_NDEBUG 0 +#define LOG_NDEBUG 0 #define LOG_TAG "AudioHardwareTiny" #include "alsa_audio.h" @@ -854,7 +854,7 @@ static int start_output_stream(struct stream_out *out) int ret = 0; int card = (int)SND_OUT_SOUND_CARD_UNKNOWN; - ALOGD("%s device: %x",__FUNCTION__, out->device); + ALOGD("%s out->device=0x%x,out->pcm_device=0x%d n",__FUNCTION__,out->device,out->pcm_device); if (out == adev->outputs[OUTPUT_HDMI_MULTI]) { force_non_hdmi_out_standby(adev); } else if (adev->outputs[OUTPUT_HDMI_MULTI] && !adev->outputs[OUTPUT_HDMI_MULTI]->standby) { 3、根据RK的方法修改如下 diff --git a/tinyalsa_hal/audio_hw.c b/tinyalsa_hal/audio_hw.c index 0a35b80..f091c97 100755 --- a/tinyalsa_hal/audio_hw.c +++ b/tinyalsa_hal/audio_hw.c @@ -644,7 +644,7 @@ static int start_output_stream(struct stream_out *out) } #endif #endif - out->pcm[PCM_CARD_HDMI] = pcm_open(PCM_CARD_HDMI, out->pcm_device, + out->pcm[PCM_CARD_HDMI] = pcm_open(0, 1, PCM_OUT | PCM_MONOTONIC, &out->config); if (out->pcm[PCM_CARD_HDMI] && !pcm_is_ready(out->pcm[PCM_CARD_HDMI])) { 原理: 1、查找头文件audio_hw.h对PCM_CARD_HDMI的声明如下 #ifdef BOX_HAL int PCM_CARD = 0; int PCM_CARD_HDMI = 0; int PCM_CARD_SPDIF = 1; #else int PCM_CARD = 0; int PCM_CARD_HDMI = 1; int PCM_CARD_SPDIF = 2; #endif 如上代码对pcm设备进行了选配,根据Android.mk文件选配。 2、调试:获取当前声卡的编号 cat /proc/asound/cards |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
626 浏览 0 评论
887 浏览 1 评论
784 浏览 1 评论
1997 浏览 1 评论
3242 浏览 1 评论
GMT+8, 2024-12-23 23:55 , Processed in 0.532391 second(s), Total 72, Slave 56 queries .
