一、编译apk源码后,点击OUTPUT IMAGE,apk闪退 未依赖libcompute_color-jni.so库和libsave_baseparameter_util.so库 解决办法 进入apk源码jni文件夹,mm -B编译生成so库 二、调节好参数后OUTPUT IMAGE fail 这种情况是没找到baseparameter分区,路径/dev/block/platform/ff0f0000.dwmmc/by-name/baseparameter 解决办法 1.确定在/device/rockchip/rk3288/init.rk3288.rc中添加了baseparameter分区信息 # baseparameter chown system system /dev/block/by-name/baseparameter chmod 0660 /dev/block/by-name/baseparameter chown system system /dev/block/platform/ff0f0000.dwmmc/by-name/baseparameter chmod 0660 /dev/block/platform/ff0f0000.dwmmc/by-name/baseparameter chown system system /dev/block/mmcblk1p4 chmod 0660 /dev/block/mmcblk1p4 2.修改/device/rockchip/rk3288/parameter.txt中的CMDLINE 我修改了之后,发现这个parameter.txt是拷贝过来的,拷贝路径是/device/rockchip/common/BoardConfig.mk,具体如下: ifeq ($(strip $(BOARD_BASEPARAMETER_SUPPORT)), true) TARGET_RECOVERY_OVERSCAN_PERCENT := 2 TARGET_BASE_PARAMETER_IMAGE ?= device/rockchip/common/baseparameter/baseparameter_fb1080.img PRODUCT_PACKAGES += saveBaseParameter ifeq ($(strip $(TARGET_BOARD_PLATFORM)),rk3399) LOCAL_POST_PROCESS_COMMAND :=$(shell cp -a device/rockchip/common/parameter_have_baseparameter.txt device/rockchip/rk3399/rk3399_all/parameter.txt) TARGET_BASE_PARAMETER_IMAGE := device/rockchip/common/baseparameter/baseparameter_fb1080_3399_all.img endif ifeq ($(strip $(TARGET_BOARD_PLATFORM)),rk3288) LOCAL_POST_PROCESS_COMMAND :=$(shell cp -a device/rockchip/common/parameter_have_baseparameter_3288.txt device/rockchip/rk3288/parameter.txt) endif else # use the parameter in device/rockchip/rk3399/rk3399_all/ # ifeq ($(strip $(TARGET_BOARD_PLATFORM)),rk3399) # LOCAL_POST_PROCESS_COMMAND :=$(shell cp -a device/rockchip/common/parameter_no_baseparameter.txt device/rockchip/rk3399/rk3399_all/parameter.txt) # endif ifeq ($(strip $(TARGET_BOARD_PLATFORM)),rk3288) LOCAL_POST_PROCESS_COMMAND :=$(shell cp -a device/rockchip/common/parameter_no_baseparameter_3288.txt device/rockchip/rk3288/parameter.txt) endif endif 3.修改/device/rockchip/rk3288/recovery.emmc.fstab,增加信息 /dev/block/platform/ff0f0000.dwmmc/by-name/baseparameter /baseparameter emmc defaults defaults 4.生成节点文件后,要给定/dev/block/platform/ff0f0000.dwmmc/by-name/baseparameter可执行权限,/device/rockchip/common/ueventd.rockchip.rc #for baseparameter function /dev/block/platform/ff0f0000.dwmmc/by-name/baseparameter 0660 system system 最后点击OUTPUT IMAGE,成功生成/sdcard/baseparameter.img 三、将该baseparameter.img打包到升级固件中 /device/rockchip/common/BoardConfig.mk /device/rockchip/rk3288/BoardConfig.mk TARGET_BASE_PARAMETER_IMAGE := device/rockchip/common/baseparameter/baseparameter_fb1080.img 将sdcard/baseparameter.img生成的固件替换成该目录相应文件名,全编译打包就行了 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
808 浏览 0 评论
1024 浏览 1 评论
887 浏览 1 评论
2113 浏览 1 评论
3373 浏览 1 评论
GMT+8, 2024-12-26 02:34 , Processed in 0.579344 second(s), Total 70, Slave 54 queries .
