kerneldriversgpudrmbridgeanalogixanalogix_dp_core.c static void analogix_dp_init_training(struct analogix_dp_device *dp, enum link_lane_count_type max_lane, int max_rate) { /* * MACRO_RST must be applied after the PLL_LOCK to avoid * the DP inter pair skew issue for at least 10 us */ analogix_dp_reset_macro(dp); /* Initialize by reading RX's DPCD */ analogix_dp_get_max_rx_bandwidth(dp, &dp->link_train.link_rate); analogix_dp_get_max_rx_lane_count(dp, &dp->link_train.lane_count); if ((dp->link_train.link_rate != DP_LINK_BW_1_62) && (dp->link_train.link_rate != DP_LINK_BW_2_7) && (dp->link_train.link_rate != DP_LINK_BW_5_4)) { dev_err(dp->dev, "Rx Max Link Rate is abnormal :%x !n", dp->link_train.link_rate); dp->link_train.link_rate = DP_LINK_BW_1_62; } + dp->link_train.link_rate = DP_LINK_BW_1_62; if (dp->link_train.lane_count == 0) { dev_err(dp->dev, "Rx Max Lane count is abnormal :%x !n", |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
678 浏览 0 评论
920 浏览 1 评论
814 浏览 1 评论
2030 浏览 1 评论
3275 浏览 1 评论
GMT+8, 2024-12-24 08:35 , Processed in 0.881144 second(s), Total 72, Slave 56 queries .
