原理图
经原理图可知由芯片将EDP转成VGA-out 第一步:万用表测量和设置电源位使芯片供电正常 第二步:添加DTS-EDP部分(将HDMI关闭) 路径: kernelarcharm64bootdtsrockchiprk3568-evb.dtsi edp_panel: edp-panel { compatible = "simple-panel"; status = "okay"; //disabled or okay // power-supply = <&vcc3v3_lcd_edp>; enable-gpios = <&gpio0 RK_PC4 GPIO_ACTIVE_HIGH>; prepare-delay-ms = <201>; enable-delay-ms = <201>; backlight = <&backlight>; display-timings { native-mode = <&timing0>; timing0: timing0 { clock-frequency = <140000000>; hactive = <1920>; vactive = <1080>; hfront-porch = <80>; hsync-len = <20>; hback-porch = <80>; vfront-porch = <12>; vsync-len = <24>; vback-porch = <12>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <0>; }; }; ports { panel_in_edp: endpoint { remote-endpoint = <&edp_out_panel>; }; }; }; }; &edp { status = "okay"; //disabled or okay hpd-gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>; force-hpd; ports { edp_out: port@1 { reg = <1>; #address-cells = <1>; #size-cells = <0>; edp_out_panel: endpoint@0 { reg = <0>; remote-endpoint = <&panel_in_edp>; }; }; }; }; &route_edp { status = "okay"; //disabled or okay connect = <&vp0_out_edp>; }; &edp_phy { status = "okay"; //disabled or okay }; &edp_in_vp0 { status = "disabled"; //disabled or okay }; &edp_in_vp1 { status = "disabled"; }; //这里并未用到 vcc3v3_lcd_edp: vcc3v3-lcd-edp { compatible = "regulator-fixed"; gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>; enable-active-high; regulator-name = "vcc3v3_lcd_edp"; regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; [tr]NAMEGPIOGPIO_ACTIVE[/tr]
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1763 浏览 0 评论
2222 浏览 1 评论
1895 浏览 1 评论
3230 浏览 1 评论
4074 浏览 1 评论
GMT+8, 2025-1-13 09:58 , Processed in 0.495378 second(s), Total 42, Slave 36 queries .
