1、首先定位播放音频文件大概位置 2、确认播放音频为 WirelessChargingStarted.ogg 3、根据WirelessChargingStarted名称关键字找到frameworksbaseservicescorejavacomandroidserverpowerNotifier.java 4、修改 diff --git a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml index 3083f55..2b4c759 100755 --- a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml +++ b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml @@ -66,7 +66,8 @@ + diff --git a/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java b/frameworks/base/packages/SettingsProvider/src/com/android/pr oviders/settings/DatabaseHelper.java index f6b3d06..ed1e338 100755 --- a/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java +++ b/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java @@ -2548,6 +2548,11 @@ class DatabaseHelper extends SQLiteOpenHelper { loadIntegerSetting(stmt, Settings.Secure.SLEEP_TIMEOUT, R.integer.def_sleep_timeout); @@ -2676,6 +2681,8 @@ class DatabaseHelper extends SQLiteOpenHelper { R.string.def_trusted_sound); loadIntegerSetting(stmt, Settings.Global.POWER_SOUNDS_ENABLED, R.integer.def_power_sounds_enabled); + loadIntegerSetting(stmt, Settings.Global.CHARGING_SOUNDS_ENABLED, + R.integer.def_charging_sounds_enabled); loadStringSetting(stmt, Settings.Global.LOW_BATTERY_SOUND, R.string.def_low_battery_sound); loadIntegerSetting(stmt, Settings.Global.DOCK_SOUNDS_ENABLED, |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
3059 浏览 0 评论
3010 浏览 1 评论
2490 浏览 1 评论
3829 浏览 1 评论
4567 浏览 1 评论
GMT+8, 2025-1-31 10:10 , Processed in 0.384083 second(s), Total 39, Slave 34 queries .
