0.dts中配置1920x1080的分辨率 1.build.prop添加下面属性: persist.sys.framebuffer.main=1920x600@60 2.hardware/rockchip/hwcomposer合入下面修改: diff --git a/hwcomposer.cpp b/hwcomposer.cpp index 0fd2177..3ad13a9 100755 --- a/hwcomposer.cpp +++ b/hwcomposer.cpp @@ -3498,8 +3498,10 @@ static int hwc_get_display_configs(struct hwc_composer_device_1 *dev, char framebuffer_size[PROPERTY_VALUE_MAX]; uint32_t width = 0, height = 0 , vrefresh = 0 ; + if (display == HWC_DISPLAY_PRIMARY) property_get("persist.sys.framebuffer.main", framebuffer_size, "use_baseparameter"); - + else if(display == HWC_DISPLAY_EXTERNAL) + property_get("persist.sys.framebuffer.aux", framebuffer_size, "use_baseparameter"); /* * if unset framebuffer_size, get it from baseparameter , by libin */ @@ -2298,7 +2301,8 @@ static int hwc_prepare(hwc_composer_device_1_t *dev, size_t num_displays, hd->rel_yres = mode.v_display(); hd->v_total = mode.v_total(); hd->w_scale = (float)mode.h_display() / hd->framebuffer_width; - hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + //hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + hd->h_scale = 1.0; int fbSize = hd->framebuffer_width * hd->framebuffer_height; //get plane size for display std::vector @@ -3638,7 +3647,8 @@ static int hwc_set_active_config(struct hwc_composer_device_1 *dev, int display, return -ENOENT; } hd->w_scale = (float)mode.h_display() / hd->framebuffer_width; - hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + //hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + hd->h_scale = 1.0; c->set_current_mode(mode); ctx->drm.UpdateDisplayRoute(); |
2136 浏览 0 评论
956 浏览 0 评论
1413 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】自行转换大模型失败,搞一个语音小智玩玩吧.
503 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】使用rkllm运行DeepSeek的服务模式体验
968 浏览 0 评论
GMT+8, 2025-4-10 03:36 , Processed in 0.397722 second(s), Total 41, Slave 35 queries .
