扫一扫,分享给好友
修改默认时区语言
文件路径 device/rockchip/rk356x/device.mk 在 PRODUCT_PROPERTY_OVERRIDES下增加以下内容 persist.sys.language=zh persist.sys.country=CN persist.sys.localevar= "" persist.sys.timezone=Asia/Shanghai ro.product.locale.language=zh ro.product.locale.region=CN 修改导航栏、状态栏 导航栏路径 frameworks/base/packages/SystemUI/src/com/android/systemui/statu***ar/phone/NavigationBarFragment.java 修改函数为 prepareNavigationBarView,在函数最后加上 volumeAddButton.setVisibility(View.GONE); volumeSubButton.setVisibility(View.GONE); screenshotButton.setVisibility(View.GONE); poweroffButton.setVisibility(View.GONE); rotationButton.setVisibility(View.GONE); hideBarButton.setVisibility(View.GONE); 状态栏路径 frameworks/base/core/res/res/values/dimens.xml 修改status_bar_height_portrait的值为0dp 修改安装应用的权限 文件路径 frameworks/base/services/core/java/com/android/server/pm/permission/PermissionManagerService.java 函数 private void restorePermissionState(@NonNull AndroidPackage pkg, boolean replace, @Nullable String packageOfInterest, @Nullable PermissionCallback callback) 部分代码修改为: if (bp.isNormal()) { // For all apps normal permissions are install time ones. grant = GRANT_INSTALL; } else if (bp.isRuntime()) { if (origPermissions.hasInstallPermission(bp.getName()) || upgradedActivityRecognitionPermission != null) { // Before Q we represented some runtime permissions as install permissions, // in Q we cannot do this anymore. Hence upgrade them all. grant = GRANT_UPGRADE; } else { // For modern apps keep runtime permissions unchanged. // grant = GRANT_RUNTIME; grant = GRANT_INSTALL; } } else if (bp.isSignature()) { // For all apps signature permissions are install time ones. allowedSig = grantSignaturePermission(perm, pkg, ps, bp, origPermissions); if (allowedSig) { grant = GRANT_INSTALL; } grant = GRANT_INSTALL; } |
482 浏览 0 评论
1529 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1087 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1752 浏览 1 评论
856 浏览 0 评论
GMT+8, 2025-3-7 00:47 , Processed in 0.361806 second(s), Total 39, Slave 34 queries .
