PCB做出来了
原理图: PCB layout: 进度慢,没辙,课程压力太大了(作者菜) PCB版本的改进了按键检测机制:添加了外部中断 下面是代码: #include #include #include "U8glib.h" //#include #define DHTpin 4 //自己按需求修改 #define Red_led 8 #define key_1 2 #define key_2 3 #define relay 5 U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);// 初始化i2c接口 SimpleDHT11 dht11(DHTpin);//初始化DHT11对象 String tmp; String hmp; String KHS = "60";//显示阈值 int KH=60; //实际阈值 void draw_hello(void) { u8g.setFont(u8g_font_unifont); u8g.drawStr( 0, 22, "Hello Baby!"); } void draw_data(void) { //具体显示屏显示内容 u8g.setFont(u8g_font_unifont);//设置字体 u8g.drawStr( 0, 16, tmp.c_str());//写入字符串 u8g.drawStr( 0, 32, hmp.c_str()); u8g.drawStr( 15, 48, KHS.c_str()); } void setup() { // put your setup code here, to run once: /*GPIO初始化*/ pinMode(Red_led,OUTPUT); //pinMode(8, OUTPUT);//不知道干啥的 pinMode(key_1,INPUT); pinMode(key_2,INPUT); pinMode(relay,OUTPUT); attachInterrupt( digitalPinToInterrupt(key_1), KEY1DOWN, CHANGE); attachInterrupt( digitalPinToInterrupt(key_2), KEY2DOWN, CHANGE); /*串口初始化*/ Serial.begin(115200); draw_hello(); delay(1500); /*Here is nothing!!*/ /*这是一个空行*/ // flip screen, if required // u8g.setRot180(); // set SPI backup if required //u8g.setHardwareBackup(u8g_backup_avr_spi); // assign default color value if ( u8g.getMode() == U8G_MODE_R3G3B2 ) { u8g.setColorIndex(255); // white } else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) { u8g.setColorIndex(3); // max intensity } else if ( u8g.getMode() == U8G_MODE_BW ) { u8g.setColorIndex(1); // pixel on } else if ( u8g.getMode() == U8G_MODE_HICOLOR ) { u8g.setHiColorByRGB(255,255,255); } } void loop() { /*led指示灯闪烁*/ digitalWrite(Red_led,HIGH); delay(500); digitalWrite(Red_led,LOW); delay(500); //draw_hello(); //delay(1200); /*DHT11读取并串口打印显示*/ byte temperature = 0; byte humidity = 0; byte humidity_last = 0; int err = SimpleDHTErrSuccess; if ((err = dht11.read(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) { Serial.print("Read DHT11 failed, err="); Serial.println(err);delay(1000); return; } humidity_last = humidity; //字符串拼接 tmp += String("Temperature:"); tmp += String(temperature); tmp += String("*C"); hmp += String("Humidity: "); hmp += String(humidity); hmp += String("RH%"); Serial.print((int)temperature); Serial.print(" *C, "); Serial.print((int)humidity); Serial.println(" H"); if(humidity digitalWrite(relay,HIGH); //digitalWrite(A0,LOW); Serial.println("Warnning!"); } if(humidity>=KH){ //digitalWrite(A0,HIGH); digitalWrite(relay,LOW); } /*oled显示屏显示程序*/ u8g.firstPage(); do { if(humidity != humidity_last){ u8g.drawStr( 0, 16, tmp.c_str()); u8g.drawStr( 0, 32, " "); delay(1000); } draw_data(); } while( u8g.nextPage() ); } void KEY1DOWN(){ KH++; KHS=String(KH); } void KEY2DOWN(){ KH--; KHS=String(KH); } |
3479 浏览 0 评论
3420 浏览 9 评论
3100 浏览 16 评论
3586 浏览 1 评论
9277 浏览 16 评论
1442浏览 3评论
710浏览 2评论
717浏览 2评论
2512浏览 2评论
2028浏览 2评论
GMT+8, 2025-4-2 05:41 , Processed in 1.353038 second(s), Total 79, Slave 59 queries .
