1.实验目的
熟悉基于Linux操作系统下的触摸屏设备驱动移植配置过程。 2.实验平台 华清远见开发环境,FS-MP1A平台; 3.实验目的 熟悉基于Linux操作系统下的块设备驱动移植配置过程。 4.实验步骤
linux@ubuntu:$ source /opt/st/stm32mp1/3.1-openstlinux-5.4-dunfell-mp1-20-06-24/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi 过程与5寸触摸屏移植过程相同,如果步骤重复请跳过。
修改arch/arm/boot/dts/stm32mp157a-fsmp1a-rgb070.dts文件,在文件末尾增加如下内容: &i2c2 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c2_pins_a>; pinctrl-1 = <&i2c2_pins_sleep_a>; i2c-scl-rising-time-ns = <100>; i2c-scl-falling-time-ns = <7>; status = "okay"; /delete-property/dmas; /delete-property/dma-names; touchscreen@5d { compatible = "goodix,gt911"; reg = <0x5d>; irq-gpios = <&gpiog 7 (GPIO_ACTIVE_HIGH | GPIO_PULL_UP)>; reset-gpios = <&gpiog 8 GPIO_ACTIVE_HIGH>; interrupt-parent = <&gpiog>; interrupts = <7 IRQ_TYPE_EDGE_FALLING>; status = "okay"; // touchscreen-inverted-x; touchscreen-inverted-y; touchscreen-swapped-x-y; }; };
由于内核源码默认配置以及支持sii902x,本节列出主要选项,如下: linux@ubuntu:$ make menuconfig Device Drivers ---> Graphics support ---> <*> Direct Rendering Manager (XFree86 4.1.0 and higher DRI support) ---> <*> DRM Support for STMicroelectronics SoC Series Display Interface Bridges ---> <*> Silicon Image sii902x RGB/HDMI bridge
linux@ubuntu:$ make -j4 uImage dtbs LOADADDR=0xC2000040
将编译好的设备树和内核镜像拷贝到/tftpboot目录下,通过tftp引导内核,设备连接七寸屏,重启设备后查看/dev会多出event0的信息,这是点击屏幕会的到反馈。 root@fsmp1a:# ls /dev/input |
3316 浏览 9 评论
2995 浏览 16 评论
3494 浏览 1 评论
9060 浏览 16 评论
4088 浏览 18 评论
1180浏览 3评论
605浏览 2评论
599浏览 2评论
2335浏览 2评论
1896浏览 2评论
GMT+8, 2024-12-24 01:46 , Processed in 1.154581 second(s), Total 79, Slave 60 queries .
