#include
sfr P4 = 0xC0; //reg52.h 头文件里没有P4口的定义,如果要使用,需要自己添加 ***it R1 = P3^0; //定义矩阵键盘的行 ***it R2 = P3^1; ***it R3 = P3^2; ***it R4 = P3^3; ***it C1 = P4^4; //定义矩阵键盘的列 ***it C2 = P4^2; ***it C3 = P3^5; ***it C4 = P3^4; unsigned char count = 0; //计数 unsigned char code SEG_code[18] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8, 0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e, 0xbf,0x7f}; //定义共阳数码管段码内容:0~F,—,. void Delay_keys() //延时去抖动 { unsigned char i = 108,j = 145; while(--i) { while(--j); } } void Select_HC138(unsigned char n) { switch(n) { case 5: P2 = (P2 & 0x1f) | 0xa0; break; case 6: P2 = (P2 & 0x1f) | 0xc0; break; case 7: P2 = (P2 & 0x1f) | 0xe0; break; } } void Show_tube(unsigned char value) { Select_HC138(6); P0 = 0x01; Select_HC138(7); P0 = value; } void Scan_keys() { C1 = C2 = C3 = C4 = 1; if(C1 == 0) { Delay_keys(); if(C1 == 0) { Show_tube(SEG_code[count+0]); } while(C1 == 0); } else if(C2 == 0) { Delay_keys(); if(C2 == 0) { Show_tube(SEG_code[count+1]); } while(C2 == 0); } else if(C3 == 0) { Delay_keys(); if(C3 == 0) { Show_tube(SEG_code[count+2]); } while(C3 == 0); } else if(C4 == 0) { Delay_keys(); if(C4 == 0) { Show_tube(SEG_code[count+3]); } while(C4 == 0); } } void main() { Select_HC138(5); P0 = 0x00; //关闭蜂鸣器和继电器 P3 = 0x0fe; //R1 = 0; while(1) { Scan_keys(); //x是要循环左移的目标数据,y是变量x的位数,z是期望循环左移的位数:x = (x >> (y-z)) | (x << z); P3 = (P3 >> 7)| (P3 << 1); //将0循环左移一位,依次将R2、R3、R4置为0 count += 4; if(count > 12) { P3 = 0xfe; count = 0; } } } |
3410 浏览 0 评论
3383 浏览 9 评论
3069 浏览 16 评论
3558 浏览 1 评论
9202 浏览 16 评论
1319浏览 3评论
678浏览 2评论
673浏览 2评论
2423浏览 2评论
1986浏览 2评论
GMT+8, 2025-3-6 12:42 , Processed in 1.186257 second(s), Total 78, Slave 59 queries .
