二,mipi csi phy与imx291
同样的还是直接贴出bound函数 static int rockchip_mipidphy_notifier_bound(struct v4l2_async_notifier *notifier, struct v4l2_subdev *sd, struct v4l2_async_subdev *asd) { struct mipidphy_priv *priv = container_of(notifier, struct mipidphy_priv, notifier); struct sensor_async_subdev *s_asd = container_of(asd, struct sensor_async_subdev, asd); struct mipidphy_sensor *sensor; unsigned int pad, ret; if (priv->num_sensors == ARRAY_SIZE(priv->sensors)) return -EBUSY; sensor = &priv->sensors[priv->num_sensors++]; sensor->lanes = s_asd->lanes; sensor->mbus = s_asd->mbus; /* * 这里的sd是imx291的subdev */ sensor->sd = sd; dev_info(priv->dev, "match %s:bus type %dn", sd->name, s_asd->mbus.type); /* * imx291只有一个source pad */ for (pad = 0; pad < sensor->sd->entity.num_pads; pad++) if (sensor->sd->entity.pads[pad].flags & MEDIA_PAD_FL_SOURCE) break; if (pad == sensor->sd->entity.num_pads) { dev_err(priv->dev, "failed to find src pad for %sn", sensor->sd->name); return -ENXIO; } /* * 下面的函数看下面文章,有具体分析,代入当前条件分析 * 基于RV1126平台imx291分析 --- media部件连接 二 * */ ret = media_create_pad_link( &sensor->sd->entity, pad, &priv->sd.entity, MIPI_DPHY_RX_PAD_SINK, priv->num_sensors != 1 ? 0 : MEDIA_LNK_FL_ENABLED); if (ret) { dev_err(priv->dev, "failed to create link for %sn", sensor->sd->name); return ret; } return 0; } 最后的连接情况如下: |
1713 浏览 0 评论
627 浏览 0 评论
Onenet云网关方案应用--基于米尔瑞芯微RK3576开发板
1195 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】Redis最新8.0.2版本源码安装及性能测试
1953 浏览 0 评论
2091 浏览 0 评论
GMT+8, 2025-7-16 03:38 , Processed in 0.563100 second(s), Total 69, Slave 54 queries .
