读取CPU温度
cat /sys/class/thermal/thermal_zone0/temp 或者 cat /sys/class/thermal/thermal_zone1/temp 显示:74333,代表 74.333 度 查看rv1126 NPU cat /sys/devices/platform/ffbc0000.npu/devfreq/ffbc0000.npu/cur_freq 查看rv1126 CPU频率 cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq //查看当前运行CPU频率 cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq //查看软件上最后一次设置的CPU频率 cat /sys/devices/system/cpu/cpufreq/policy0/scaling_available_frequencies //查看支持的CPU频率 echo performance > /sys/devices/system/cpu/cpufreq/policy0/scaling_governo //使能CPU性能模式,跑最高频 echo 1008000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed //设置CPU频率 附录 cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq //查看当前运行CPU频率 cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq //查看软件上最后一次设置的CPU频率 cat /sys/devices/system/cpu/cpufreq/policy0/scaling_available_frequencies //查看支持的CPU频率 echo performance > /sys/devices/system/cpu/cpufreq/policy0/scaling_governo //使能CPU性能模式,跑最高频 echo 1008000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed //设置CPU频率 查询 NPU 驱动版本: dmesg | grep -i galcore 查询 rknn_server 版本: strings /usr/bin/rknn_server | grep build 查询 librknn_runtime 版本: strings /usr/lib/librknn_runtime.so | grep version |
1815 浏览 0 评论
703 浏览 0 评论
1193 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】自行转换大模型失败,搞一个语音小智玩玩吧.
491 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】使用rkllm运行DeepSeek的服务模式体验
897 浏览 0 评论
GMT+8, 2025-4-8 01:27 , Processed in 0.510853 second(s), Total 39, Slave 34 queries .
