扫一扫,分享给好友
引导logo的横屏
和boot logo 显示的bmp图片同名是u-mp图片的同名logo :最后如果要保留中的一张 图片,可以只要,一张就只有一张。 内核后需要在android根 目录下执行。/mkimage.sh则重新打包写入boot.img。打包后烧录效果rockdev下面的boot.img,即可查看。若烧录内核下 的boot.img,设备无法正常引导。/ 引导动画屏 设备修改 BOOTSH_UTDOWN_ANIMATION_RINGING ?=真 制作资源图片横屏/引导动画.zip 复制到设备的引导/引导动画/bootshutdown /bootanimation(源码路径), 编译结束后会复制到out下odm/media中,烧写zip可以在 Android应用层显示横屏 devicerockchiprk3326BoardConfig.mk中增加修改SF_PRIMARY_DISPLAY_ORIENTATION := 90 搜索SF_PRIMARY_DISPLAY_ORIENTATION的文件,根据项目名称修改位置 ./rockchip/common/device.mk:ifneq ($(filter 90 180 270, $(strip $(SF_PRIMARY_DISPLAY_ORIENTATION))), ) . mk:ro.surface_flinger.primary_display_orientation=ORIENTATION_$(SF_PRIMARY_DISPLAY_ORIENTATION) ./rockchip/common/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION ?= 0 ./rockchip/rk3368/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3326/BoardConfig. :SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3126c/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3399/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3368a/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION 交换 xy 坐标实现旋转 gtp_x2y:x、y交换方向 镜像:x方向坐标gtp_y_reverse :方向不镜像 kerneldriversinputtouchscreengt9xx_changegt9xx.c @@ -2656,9 +2656,13 @@ static int goodix_ts_probe(struct i2c_client *client, const struct i2c_device_id m89or101 = FALSE; bgt911 = TRUE; - gtp_change_x2y = FALSE; - gtp_x_reverse = TRUE; - gtp_y_reverse = TRUE; + //gtp_change_x2y = FALSE; + //gtp_x_reverse = TRUE; + //gtp_y_reverse = TRUE; + + gtp_change_x2y = TRUE; + gtp_x_reverse = TRUE; + gtp_y_reverse = FALSE; /*if (val == 89) { m89or101 = TRUE; RecoveryUI 横屏 旋转 = GRRotation::LEFT; 270 旋转 = GRRotation::DOWN; 180 转 = GRRotation::RIGHT; 90 可启动恢复minuigraphics.cpp int gr_init() { ..... gr_backend = backend.release(); int overscan_percent = android::base::GetIntProperty("ro.minui.overscan_percent", 0); overscan_offset_x = gr_draw->width * overscan_percent / 100; overscan_offset_y = gr_draw->height * overscan_percent / 100; gr_flip(); gr_flip(); if (!gr_draw) { printf("gr_init: gr_draw 在 gr_flipn 之后变为 nullptr"); 返回-1; } std::string rotation_str = android::base::GetProperty("ro.minui.default_rotation", "ROTATION_NONE"); 如果 (rotation_str == " gr_rotate(GRRotation::RIGHT); } else if (rotation_str == "ROTATION_DOWN") { gr_rotate(GRRotation::DOWN); } else if (rotation_str == "ROTATION_LEFT") { gr_rotate(GRRotation::LEFT); } else { // "ROTATION_NONE" 或未知字符串 gr_rotate(GRRotation::NONE); } 旋转 = GRRotation::RIGHT; //cczheng add rotation = 1 for recoveryUI Landscape |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
2531 浏览 0 评论
2818 浏览 1 评论
2308 浏览 1 评论
3639 浏览 1 评论
4390 浏览 1 评论
GMT+8, 2025-1-24 19:25 , Processed in 0.604360 second(s), Total 39, Slave 34 queries .
