默认数据分区的文件系统为f2fs,建议不带电池的产品可以将数据分区的文件系统ext4改为,可以异常删除电后数据丢失的标识。方法如下:
device/rockchip/common$ git diff diff --git a/scripts/fstab_tools/fstab.in b/scripts/fstab_tools/fstab.in index 6e78b00..a658332 100755 --- a/scripts/fstab_tools/fstab.in +++ b/scripts/fstab_tools/fstab.in # For pcie ssd /devices/platform/*.pcie* auto vfat defaults voldmanaged=pcie:auto /dev/block/zram0 none swap defaults zramsize=50% # For sdmmc /devices/platform/${_sdmmc_device}/mmc_host* auto auto defaults voldmanaged=sdcard1:auto # Full disk encryption has less effect on rk3326, so default to enable this. -/dev/block/by-name/userdata /data f2fs noatime,nosuid,nodev,discard,reserve_root=32768,resgid=1065 latemount,wait,check,fileencryption=aes-256-xts:aes-256- cts:v2+inlinecrypt_optimized,quota,formattable,reservedsize=128M,checkpoint=fs +#/dev/block/by-name/userdata /data f2fs noatime,nosuid,nodev,discard,reserve_root=32768,resgid=1065 latemount,wait,check,fileencryption=aes-256-xts:aes-256- cts:v2+inlinecrypt_optimized,quota,formattable,reservedsize=128M,checkpoint=fs # for ext4 -#/dev/block/by-name/userdata /data ext4 discard,noatime,nosuid,nodev,noauto_da_alloc,data=ordered,user_xattr,barrier=1 latemount,wait,formattable,check,fileencryption=software,quota,reservedsize=128M ,checkpoint=block +/dev/block/by-name/userdata /data ext4 discard,noatime,nosuid,nodev,noauto_da_alloc,data=ordered,user_xattr,barrier=1 latemount,wait,formattable,check,fileencryption=software,quota,reservedsize=128M ,checkpoint=block device/rockchip/rk356x$ git diff diff --git a/rk3566_r/recovery.fstab b/rk3566_r/recovery.fstab index 7532217..cf789ac 100755 --- a/rk3566_r/recovery.fstab +++ b/rk3566_r/recovery.fstab @@ -7,7 +7,7 @@ /dev/block/by-name/odm /odm ext4 defaults defaults /dev/block/by-name/cache /cache ext4 defaults defaults /dev/block/by-name/metadata /metadata ext4 defaults defaults -/dev/block/by-name/userdata /data f2fs defaults defaults +/dev/block/by-name/userdata /data ext4 defaults defaults /dev/block/by-name/cust /cust ext4 defaults defaults /dev/block/by-name/custom /custom ext4 defaults defaults /dev/block/by-name/radical_update /radical_update ext4 defaults defaults |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1005 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1184 浏览 0 评论
522 浏览 0 评论
485 浏览 0 评论
777 浏览 0 评论
GMT+8, 2025-2-24 06:25 , Processed in 0.858120 second(s), Total 72, Slave 56 queries .
