删除无用APk
系统备份、cts测试相关、系统壁纸备份 build/make/target/product/base_system.mk @@ -41,7 +41,6 @@ PRODUCT_PACKAGES += ashmemd atrace audioserver - BackupRestoreConfirmation bcc blank_screen blkid @@ -59,8 +58,6 @@ PRODUCT_PACKAGES += ContactsProvider content crash_dump - CtsShimPrebuilt - CtsShimPrivPrebuilt debuggerd device_config dmctl @@ -261,7 +258,6 @@ PRODUCT_PACKAGES += viewcompiler voip-common vold - WallpaperBackup watchdogd wificond wifi-service @@ -373,7 +369,6 @@ PRODUCT_PACKAGES_DEBUG := # The set of packages whose code can be loaded by the system server. PRODUCT_SYSTEM_SERVER_APPS += SettingsProvider - WallpaperBackup 浏览器、日历、联系人、邮箱、Android键盘、初始化相关、快速搜索框 build/make/target/product/handheld_product.mk @@ -22,18 +22,11 @@ $(call inherit-product, $(SRC_TARGET_DIR)/product/media_product.mk) # /product packages PRODUCT_PACKAGES += - Browser2 - Calendar Camera2 - Contacts DeskClock Gallery2 - LatinIME Launcher3QuickStep - OneTimeInitializer Provision - QuickSearchBox Settings SettingsIntelligence StorageManager 基本互动屏保、书签数据库、日历数据库、文件管理器、安卓彩蛋、短信管理服务、音乐音效控制、NFC、OSU帐号登录、代理配置、运营商对话框、系统跟踪、用户字典数据库 build/make/target/product/handheld_system.mk @@ -32,45 +32,31 @@ $(call inherit-product-if-exists, frameworks/base/data/keyboards/keyboards.mk) $(call inherit-product-if-exists, frameworks/webview/chromium/chromium.mk) PRODUCT_PACKAGES += - BasicDreams BlockedNumberProvider Bluetooth BluetoothMidiService - BookmarkProvider BuiltInPrintService - CalendarProvider cameraserver CaptivePortalLogin CertInstaller clatd clatd.conf - DocumentsUI DownloadProviderUi - EasterEgg ExternalStorageProvider FusedLocation InputDevices KeyChain librs_jni ManagedProvisioning - MmsService MtpDocumentsProvider - MusicFX - NfcNci - OsuLogin - PacProcessor PrintRecommendationService PrintSpooler ProxyHandler screenrecord - SecureElement SharedStorageBackup - SimAppDialog Telecom TelephonyProvider TeleService - Traceur - UserDictionaryProvider VpnDialogs 壁纸选择器 build/make/target/product/mainline.mk @@ -32,6 +32,5 @@ PRODUCT_PROPERTY_OVERRIDES += PRODUCT_PACKAGES += PhotoTable - WallpaperPicker 客制化书签主页 build/make/target/product/mainline_system.mk @@ -30,7 +30,6 @@ PRODUCT_PACKAGES += # Applications PRODUCT_PACKAGES += LiveWallpapersPicker - PartnerBookmarksProvider PresencePolling RcsService SafetyRegulatoryInfo HTML查看器 build/make/target/product/media_system.mk @@ -29,7 +29,6 @@ PRODUCT_PACKAGES += drmserver ethernet-service fsck.f2fs - HTMLViewer libfilterpack_imageproc libwebviewchromium_loader libwebviewchromium_plat_support 计算器、音乐 device/rockchip/common/device.mk @@ -60,8 +60,8 @@ endif PRODUCT_AAPT_CONFIG ?= normal large xlarge hdpi xhdpi xxhdpi PRODUCT_AAPT_PREF_CONFIG ?= xhdpi -PRODUCT_PACKAGES += - ExactCalculator +# PRODUCT_PACKAGES += +# ExactCalculator ######################################################## # Kernel @@ -1063,7 +1063,6 @@ else # tablet SoundRecorder ifneq ($(strip $(BUILD_WITH_GOOGLE_GMS_EXPRESS)),true) PRODUCT_PACKAGES += - Music WallpaperPicker endif # tablet without GMS-Express endif device.mk 中包含了一些RK定制apk,通过 $(call inherit-product-if-exists, vendor/rockchip/common/device-vendor.mk) 引入编译,这个看你编译后设备上运行的apk,找到对应mk进行裁剪 4K视频播放器、街景测试、设备测试 vendor/rockchip/common/apps/apps.mk @@ -45,8 +45,8 @@ PRODUCT_PACKAGES += Rk3grVideoPlayer else ifneq ($(strip $(TARGET_BOARD_PLATFORM_PRODUCT)), box) -PRODUCT_PACKAGES += - Rk4kVideoPlayer +# PRODUCT_PACKAGES += +# Rk4kVideoPlayer endif endif endif @@ -63,20 +63,20 @@ endif endif -ifeq ($(strip $(BOARD_HAS_STRESSTEST_APP)), true) - PRODUCT_PACKAGES += - StressTest +# ifeq ($(strip $(BOARD_HAS_STRESSTEST_APP)), true) +# PRODUCT_PACKAGES += +# StressTest -ifneq ($(filter atv box, $(strip $(TARGET_BOARD_PLATFORM_PRODUCT))), ) -PRODUCT_PACKAGES += - RKDeviceTest +# ifneq ($(filter atv box, $(strip $(TARGET_BOARD_PLATFORM_PRODUCT))), ) +# PRODUCT_PACKAGES += +# RKDeviceTest -else -PRODUCT_PACKAGES += - DeviceTest +# else +# PRODUCT_PACKAGES += +# DeviceTest -endif -endif +# endif +# endif 删除无用字体 字体相关介绍可参考 Android系统字体加载流程 Android 系统字体 10.0 和之前低版本还是有些差异的,可以查看编译 out 目录下 systemfonts 中所编译的字体文件 注释 frameworks/base/data/fonts/fonts.xml 中成对字体组 注释 external/noto-fonts/Android.mk 中不需要编译字体文件 .ttf .otf 字库文件说明 可到 字客网 进行详细查询 |
思源宋体
NotoSerif-Regular.ttf NotoSerif-Bold.ttf NotoSerif-Italic.ttf NotoSerif-BoldItalic.ttf 阿德拉姆文 NotoSansAdlam-Regular.ttf 阿霍姆文 NotoSansAhom-Regular.otf 安那托利亚象形文字拉丁文 NotoSansAnatolianHieroglyphs-Regular.otf NotoSansAvestan-Regular.ttf 巴厘文 NotoSansBalinese-Regular.ttf NotoSansBamum-Regular.ttf 巴萨瓦赫文 NotoSansBassaVah-Regular.otf 巴塔克文 NotoSansBatak-Regular.ttf 拉丁文 孟加拉文 NotoSansBengali-Bold.otf NotoSansBengali-Medium.otf NotoSansBengali-Regular.otf 孟加拉文 NotoSansBengaliUI-Bold.otf NotoSansBengaliUI-Medium.otf NotoSansBengaliUI-Regular.otf NotoSansBhaiksuki-Regular.otf 拉丁文 NotoSansBrahmi-Regular.ttf 爪哇文 NotoSansBuginese-Regular.ttf 布希德文 NotoSansBuhid-Regular.ttf 加拿大土著统一音节文字 NotoSansCanadianAboriginal-Regular.ttf 卡里亚文 NotoSansCarian-Regular.ttf 孟加拉文缅甸文 NotoSansChakma-Regular.otf 占文 NotoSansCham-Bold.ttf NotoSansCham-Regular.ttf 切罗基文 NotoSansCherokee-Regular.ttf 希腊文 NotoSansCoptic-Regular.ttf 苏美尔-阿卡德楔形文字 NotoSansCuneiform-Regular.ttf 塞浦路斯文 NotoSansCypriot-Regular.ttf 德塞莱特文 NotoSansDeseret-Regular.ttf 古埃及象形文字 NotoSansEgyptianHieroglyphs-Regular.ttf 爱尔巴桑文 NotoSansElbasan-Regular.otf 埃塞俄比亚文 NotoSansEthiopic-Bold.ttf NotoSansEthiopic-Regular.ttf 格拉哥里文 NotoSansGlagolitic-Regular.ttf NotoSansGothic-Regular.ttf NotoSansGujarati-Bold.ttf NotoSansGujarati-Regular.ttf NotoSansGujaratiUI-Bold.ttf NotoSansGujaratiUI-Regular.ttf NotoSansGurmukhi-Bold.ttf NotoSansGurmukhi-Regular.ttf NotoSansGurmukhiUI-Bold.ttf NotoSansGurmukhiUI-Regular.ttf NotoSansHanunoo-Regular.ttf NotoSansHatran-Regular.otf NotoSansImperialAramaic-Regular.ttf NotoSansInscriptionalPahlavi-Regular.ttf NotoSansInscriptionalParthian-Regular.ttf NotoSansJavanese-Regular.ttf NotoSansKaithi-Regular.ttf NotoSansKannada-Bold.ttf NotoSansKannada-Regular.ttf NotoSansKannadaUI-Bold.ttf NotoSansKannadaUI-Regular.ttf NotoSansKayahLi-Regular.ttf NotoSansKharoshthi-Regular.ttf NotoSansKhmerUI-Bold.ttf NotoSansKhmerUI-Regular.ttf NotoSansLao-Bold.ttf NotoSansLao-Regular.ttf NotoSansLaoUI-Bold.ttf NotoSansLaoUI-Regular.ttf NotoSansLepcha-Regular.ttf NotoSansLimbu-Regular.ttf NotoSansLinearA-Regular.otf NotoSansLinearB-Regular.ttf NotoSansLisu-Regular.ttf NotoSansLycian-Regular.ttf NotoSansLydian-Regular.ttf NotoSansMalayalam-Bold.otf NotoSansMalayalam-Medium.otf NotoSansMalayalam-Regular.otf NotoSansMalayalamUI-Bold.otf NotoSansMalayalamUI-Medium.otf NotoSansMalayalamUI-Regular.otf NotoSansMandaic-Regular.ttf NotoSansManichaean-Regular.otf NotoSansMarchen-Regular.otf NotoSansMeeteiMayek-Regular.ttf NotoSansMeroitic-Regular.otf NotoSansMiao-Regular.otf NotoSansMongolian-Regular.ttf NotoSansMro-Regular.otf NotoSansMultani-Regular.otf NotoSansMyanmar-Bold-ZawDecode.ttf NotoSansMyanmar-Regular-ZawDecode.ttf NotoSansMyanmarUI-Bold-ZawDecode.ttf NotoSansMyanmarUI-Regular-ZawDecode.ttf NotoSansNabataean-Regular.otf NotoSansNewa-Regular.otf NotoSansNewTaiLue-Regular.ttf NotoSansNKo-Regular.ttf NotoSansOgham-Regular.ttf NotoSansOlChiki-Regular.ttf NotoSansOldItalic-Regular.ttf NotoSansOldNorthArabian-Regular.otf NotoSansOldPermic-Regular.otf NotoSansOldPersian-Regular.ttf NotoSansOldSouthArabian-Regular.ttf NotoSansOldTurkic-Regular.ttf NotoSansOriya-Bold.ttf NotoSansOriya-Regular.ttf NotoSansOriyaUI-Bold.ttf NotoSansOriyaUI-Regular.ttf NotoSansOsage-Regular.ttf NotoSansOsmanya-Regular.ttf NotoSansPahawhHmong-Regular.otf NotoSansPalmyrene-Regular.otf NotoSansPauCinHau-Regular.otf NotoSansPhagsPa-Regular.ttf NotoSansPhoenician-Regular.ttf NotoSansRejang-Regular.ttf NotoSansRunic-Regular.ttf NotoSansSamaritan-Regular.ttf NotoSansSaurashtra-Regular.ttf NotoSansSharada-Regular.otf NotoSansShavian-Regular.ttf NotoSansSinhala-Bold.otf NotoSansSinhala-Medium.otf NotoSansSinhala-Regular.otf NotoSansSinhalaUI-Bold.otf NotoSansSinhalaUI-Medium.otf NotoSansSinhalaUI-Regular.otf NotoSansSoraSompeng-Regular.otf NotoSansSundanese-Regular.ttf NotoSansSylotiNagri-Regular.ttf NotoSansSyriacEastern-Regular.ttf NotoSansSyriacEstrangela-Regular.ttf NotoSansSyriacWestern-Regular.ttf NotoSansTagalog-Regular.ttf NotoSansTagbanwa-Regular.ttf NotoSansTaiLe-Regular.ttf NotoSansTaiTham-Regular.ttf NotoSansTaiViet-Regular.ttf NotoSansTamil-Bold.otf NotoSansTamil-Medium.otf NotoSansTamil-Regular.otf NotoSansTamilUI-Bold.otf NotoSansTamilUI-Medium.otf NotoSansTamilUI-Regular.otf NotoSansTelugu-Bold.ttf NotoSansTelugu-Regular.ttf NotoSansTeluguUI-Bold.ttf NotoSansTeluguUI-Regular.ttf NotoSansThaana-Bold.ttf NotoSansThaana-Regular.ttf NotoSansTibetan-Bold.ttf NotoSansTibetan-Regular.ttf NotoSansTifinagh-Regular.ttf NotoSansUgaritic-Regular.ttf NotoSansVai-Regular.ttf NotoSansYi-Regular.ttf NotoNaskhArabic-Regular.ttf NotoNaskhArabic-Bold.ttf NotoNaskhArabicUI-Regular.ttf NotoNaskhArabicUI-Bold.ttf NotoSansArmenian-Regular.otf NotoSansArmenian-Bold.otf NotoSansArmenian-Medium.otf NotoSansDevanagari-Regular.otf NotoSansDevanagari-Bold.otf NotoSansDevanagari-Medium.otf NotoSansDevanagariUI-Regular.otf NotoSansDevanagariUI-Bold.otf NotoSansDevanagariUI-Medium.otf NotoSansGeorgian-Regular.otf NotoSansGeorgian-Bold.otf NotoSansGeorgian-Medium.otf NotoSansHebrew-Regular.ttf NotoSansHebrew-Bold.ttf NotoSansSymbols-Regular-Subsetted.ttf NotoSansSymbols-Regular-Subsetted2.ttf NotoSansThai-Regular.ttf NotoSansThai-Bold.ttf NotoSansThaiUI-Regular.ttf NotoSansThaiUI-Bold.ttf NotoSerifArmenian-Bold.otf NotoSerifArmenian-Regular.otf NotoSerifBengali-Bold.ttf NotoSerifBengali-Regular.ttf NotoSerifDevanagari-Bold.ttf NotoSerifDevanagari-Regular.ttf NotoSerifEthiopic-Bold.otf NotoSerifEthiopic-Regular.otf NotoSerifGeorgian-Bold.otf NotoSerifGeorgian-Regular.otf NotoSerifGujarati-Bold.ttf NotoSerifGujarati-Regular.ttf NotoSerifGurmukhi-Bold.otf NotoSerifGurmukhi-Regular.otf NotoSerifHebrew-Bold.ttf NotoSerifHebrew-Regular.ttf NotoSerifKannada-Bold.ttf NotoSerifKannada-Regular.ttf NotoSerifKhmer-Bold.otf NotoSerifKhmer-Regular.otf NotoSerifLao-Bold.ttf NotoSerifLao-Regular.ttf NotoSerifMalayalam-Bold.ttf NotoSerifMalayalam-Regular.ttf NotoSerifMyanmar-Bold.otf NotoSerifMyanmar-Regular.otf NotoSerifSinhala-Bold.otf NotoSerifSinhala-Regular.otf NotoSerifTamil-Bold.otf NotoSerifTamil-Regular.otf NotoSerifTelugu-Bold.ttf NotoSerifTelugu-Regular.ttf NotoSerifThai-Bold.ttf NotoSerifThai-Regular.ttf 删除无用语言包 frameworks/base/core/res/res/values/locale_config.xml 删除其中不需要语音列表,注意以为一组,这里只保留了中文相关 这样修改后只是系统设置中系统–语音和输入法–语音–添加语音列表中只展示中文相关, 对应的资源文件并未删除依旧打包到了 system.img 中,依旧占用系统空间。接下来继续删除 frameworks/base/core/res/res/ 多余的资源文件夹,和刚刚的 locale_config.xml 保留对应 |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 12:22 , Processed in 0.389981 second(s), Total 39, Slave 34 queries .
