开机logo横屏
U-boot logo 显示的两张图片是 kernel 根目录下的 logo.bmp 和 logo_kernel.bmp,如果 需要更换,用同名的**横屏 bmp **替换掉,重新编译 kernel 附:不一定要两张图片,可以只要一张,如果只有一张就保留 logo.bmp 这一张即可。 注:Android10.0的kernel.img和resource.img包含在boot.img中,更新编译kernel后需要在android根目 录下执行./mkimage.sh重新打包boot.img。打包后烧写rockdev下面的boot.img,即可查看效果。若烧录 kernel 文件夹下 的 boot.img,则设备无法正常开机。 开机动画横屏 修改 device/rockchip/common/BoardConfig.mk 中配置 BOOT_SHUTDOWN_ANIMATION_RINGING ?= true 制作资源图片均为横屏的开机动画,将开机动画.zip 复制到 device/rockchip/common/bootshutdown/bootanimation.zip (源码路径), 编译结束后会拷贝到 out 目录下 odm/media 中,烧写即可 Android 应用层显示横屏 devicerockchiprk3326BoardConfig.mk 中增加修改 SF_PRIMARY_DISPLAY_ORIENTATION := 90 搜索 SF_PRIMARY_DISPLAY_ORIENTATION 对应的文件,根据项目名称修改对应位置 ./rockchip/common/device.mk:ifneq ($(filter 90 180 270, $(strip $(SF_PRIMARY_DISPLAY_ORIENTATION))), ) ./rockchip/common/device.mk: ro.surface_flinger.primary_display_orientation=ORIENTATION_$(SF_PRIMARY_DISPLAY_ORIENTATION) ./rockchip/common/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION ?= 0 ./rockchip/rk3368/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3326/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3126c/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3399/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 ./rockchip/rk3368a/BoardConfig.mk:SF_PRIMARY_DISPLAY_ORIENTATION := 0 TP坐标,交换 x y 坐标实现旋转 gtp_change_x2y:x、y交换方向 gtp_x_reverse:x 方向坐标镜像 gtp_y_reverse:y 方向不镜像 kerneldriversinputtouchscreengt9xxgt9xx.c @@ -2656,9 +2656,13 @@ static int goodix_ts_probe(struct i2c_client *client, const struct i2c_device_id m89or101 = FALSE; bgt911 = TRUE; - gtp_change_x2y = FALSE; - gtp_x_reverse = TRUE; - gtp_y_reverse = TRUE; + //gtp_change_x2y = FALSE; + //gtp_x_reverse = TRUE; + //gtp_y_reverse = TRUE; + + gtp_change_x2y = TRUE; + gtp_x_reverse = TRUE; + gtp_y_reverse = FALSE; /*if (val == 89) { m89or101 = TRUE; RecoveryUI 横屏 rotation = GRRotation::LEFT; 270 rotation = GRRotation::DOWN; 180 rotation = GRRotation::RIGHT; 90 bootablerecoveryminuigraphics.cpp int gr_init() { ..... gr_backend = backend.release(); int overscan_percent = android::base::GetIntProperty("ro.minui.overscan_percent", 0); overscan_offset_x = gr_draw->width * overscan_percent / 100; overscan_offset_y = gr_draw->height * overscan_percent / 100; gr_flip(); gr_flip(); if (!gr_draw) { printf("gr_init: gr_draw becomes nullptr after gr_flipn"); return -1; } std::string rotation_str = android::base::GetProperty("ro.minui.default_rotation", "ROTATION_NONE"); if (rotation_str == "ROTATION_RIGHT") { gr_rotate(GRRotation::RIGHT); } else if (rotation_str == "ROTATION_DOWN") { gr_rotate(GRRotation::DOWN); } else if (rotation_str == "ROTATION_LEFT") { gr_rotate(GRRotation::LEFT); } else { // "ROTATION_NONE" or unknown string gr_rotate(GRRotation::NONE); } rotation = GRRotation::RIGHT; //cczheng add rotation = 1 for recoveryUI landscape |
迅为RK3588开发板实时系统编译-Preemption系统/ Xenomai系统编译-实时系统测试-Preemption测试
547 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】开发板基础体验:大模型和推流测试
412 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】Debian系统安装和性能测试
680 浏览 0 评论
533 浏览 0 评论
1587 浏览 3 评论
GMT+8, 2025-3-13 06:32 , Processed in 0.484955 second(s), Total 42, Slave 36 queries .
