基于单片机拖尾式多模式流水灯系统仿真设计,一共七种模式,三十六个led灯。模式一:红绿蓝拖尾;模式二:红 外帘入拖尾;模式三:绿 内帘出拖尾;模式四:蓝 外帘入拖尾;模式五:红绿蓝拖尾;模式六:红蓝 内帘出拖尾;模式七:红绿蓝 内帘出拖尾
/******************************************************************************** *- 拖尾式流水灯 ********************************************************************************/ #include #include #define uchar unsigned char #define uint unsigned int char code SST516[3] _at_ 0x003b; ***it key1 = P3 ^ 2; ***it LED = P3 ^ 7; bit flagA = 0; bit flagB = 0; bit flagC = 0; bit flagD = 0; bit flagE = 0; bit flagF = 0; bit flagG = 0; uchar i, j, q; uchar MODE = 0; /************************红绿蓝拖尾*********************/ uchar code dip1_P0[] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x1F, 0x0F, 0x07, 0x03, 0x01, 0x03, 0x07, 0x0F, 0x1F, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF, }; uchar code dip1_P1[] = { 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0x7D, 0x3D, 0x7D, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFF, 0xFB, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xF3, 0xFB, 0xFF, |
3188 浏览 9 评论
2878 浏览 16 评论
3383 浏览 1 评论
8815 浏览 16 评论
3979 浏览 18 评论
9613浏览 3评论
984浏览 3评论
503浏览 2评论
506浏览 2评论
2228浏览 2评论
GMT+8, 2024-9-21 13:28 , Processed in 1.164246 second(s), Total 80, Slave 61 queries .
