&dsi {
status = "okay"; panel@0 { compatible = "sitronix,st7703", "simple-panel-dsi"; panel-init-sequence = [ 05 fa 01 11 39 00 04 b9 f1 12 83 39 00 1c ba 33 81 05 f9 0e 0e 00 00 00 00 00 00 00 00 44 25 00 91 0a 00 00 02 4f 01 00 00 37 15 00 02 b8 25 39 00 04 bf 02 11 00 39 00 0b b3 0c 10 0a 50 03 ff 00 00 00 00 39 00 0a c0 73 73 50 50 00 00 08 70 00 15 00 02 bc 46 15 00 02 cc 0b 15 00 02 b4 80 39 00 04 b2 c8 12 30 39 00 0f e3 07 07 0b 0b 03 0b 00 00 00 00 ff 00 c0 10 39 00 0d c1 53 00 1e 1e 77 e1 cc dd 67 77 33 33 39 00 07 c6 00 00 ff ff 01 ff 39 00 03 b5 09 09 39 00 03 b6 87 95 39 00 40 e9 c2 10 05 05 10 05 a0 12 31 23 3f 81 0a a0 37 18 00 80 01 00 00 00 00 80 01 00 00 00 48 f8 86 42 08 88 88 80 88 88 88 58 f8 87 53 18 88 88 81 88 88 88 00 00 00 01 00 00 00 00 00 00 00 00 00 39 00 3e ea 00 1a 00 00 00 00 02 00 00 00 00 00 1f 88 81 35 78 88 88 85 88 88 88 0f 88 80 24 68 88 88 84 88 88 88 23 10 00 00 1c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 05 a0 00 00 00 00 39 00 23 e0 00 06 08 2a 31 3f 38 36 07 0c 0d 11 13 12 13 11 18 00 06 08 2a 31 3f 38 36 07 0c 0d 11 13 12 13 11 18 05 32 01 29 ]; panel-exit-sequence = [ 05 00 01 28 05 00 01 10 ]; }; 上面是rk1808中不完整的panel节点,主要是包括了屏幕上电时序:panel-init-sequence; 这个上电时序我们是在panel-simple.c中处理的,处理过程如下: 1、获取上电时序 static int panel_simple_get_cmds(struct panel_simple *panel) { const void *data; int len; int err; data = of_get_property(panel->dev->of_node, "panel-init-sequence", &len); if (data) { panel->on_cmds = devm_kzalloc(panel->dev, sizeof(*panel->on_cmds), GFP_KERNEL); if (!panel->on_cmds) return -ENOMEM; err = panel_simple_parse_cmds(panel->dev, data, len, panel->on_cmds); if (err) { dev_err(panel->dev, "failed to parse panel init sequencen"); return err; } } 首先我们调用of_get_property 通过“panel-init-sequence ”获取了上电时序cmd在内存中首地址赋值给data; 第二步通过panel_simple_parse_cmds函数解析这个cmd(知道了首地址以及长度) while (len > sizeof(*dchdr)) { dchdr = (struct cmd_ctrl_hdr *)bp; if (dchdr->dlen > len) { dev_err(dev, "%s: error, len=%d", __func__, dchdr->dlen); return -EINVAL; } bp += sizeof(*dchdr); len -= sizeof(*dchdr); bp += dchdr->dlen; len -= dchdr->dlen; cnt++; } 该部分将上电时序按照struct cmd_ctrl_hdr 结构体为基本单位进行了遍历,得到了总的cmd数目记为cnt。 for (i = 0; i < cnt; i++) { dchdr = (struct cmd_ctrl_hdr *)bp; len -= sizeof(*dchdr); bp += sizeof(*dchdr); pcmds->cmds.dchdr = *dchdr; pcmds->cmds.payload = bp; bp += dchdr->dlen; len -= dchdr->dlen; }//将一个个命令放入cmd中 再通过这段代码,将一个cmd命令放入pcmd->cmds数组中。 至此我们获取了上电时序了,接下来我们需要通过mipi将其写入lcd中: 当定义了config-drm-mipi-dsi后,我们通过panel_simple_dsi_send_cmds 函数实现cmd命令的发送。 这个函数就是根据mipi dsi协议完成cmd的发送,第一步是区分数据的格式,以调用不同发送接口。 mipi_dsi_generic_write 实现了generic packet 的传送 mipi_dsi_generic_write 实现了DCS command 的发送 如果cmd中有sleep要求时调用mipi_dsi_generic_write 实现。 以上就实现了对dts 中mipi屏幕上电时序的获取、分析、发送着三个过程。 |
482 浏览 0 评论
1529 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1087 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1752 浏览 1 评论
856 浏览 0 评论
GMT+8, 2025-3-7 09:08 , Processed in 0.858427 second(s), Total 72, Slave 56 queries .
