tinyriscv软核是一个基于riscv指令集的cpu,作者在该cpu中加入了串口下载的功能,基于作者提供的下载脚本,编写了该图形界面,简化了一些下载的难度,软件存在很多不足,只供简单调试使用。 cpu开源地址:tinyriscv: 一个从零开始写的极简、非常易懂的RISC-V处理器核。 软件源代码: import tkinter from tkinter import filedialog from tkinter import ttk import serial.tools.list_ports import os import serial top = tkinter.Tk() file_text = None file_get = None com_list = None status = None file_status = False file_path = '' com_str = '' ACK = bytes([0x6]) FIRST_PACKET_LEN = 131 FILE_NAME_INDEX = 1 FILE_SIZE_INDEX = 61 FIRST_PACKET_CRC0_INDEX = 129 FIRST_PACKET_CRC1_INDEX = 130 OTHER_PACKET_LEN = 131 serial_com = serial.Serial() def serial_init(): serial_com.port = com_str serial_com.baudrate = 115200 serial_com.bytesize = serial.EIGHTBITS serial_com.parity = serial.PARITY_NONE serial_com.stopbits = serial.STOPBITS_ONE serial_com.xonxoff = False serial_com.rtscts = False serial_com.dsrdtr = False if serial_com.is_open == False: try: serial_com.open() if serial_com.is_open: return 0 except: tkinter.messagebox.showerror(title='错误', message='请检查端口是否被占用') return -1 def serial_deinit(): if serial_com.is_open == True: serial_com.close() def serial_write(b): if serial_com.is_open == True: serial_com.write(b) return len(b) else: return 0 def serial_read(length, timeout): if (timeout > 0): serial_com.timeout = timeout if serial_com.is_open == True: data = serial_com.read(length) if len(data) > 0: return data else: return -1 else: return -1 def calc_crc16(data): crc = 0xFFFF for pos in data: crc ^= pos for i in range(8): if ((crc & 1) != 0): crc >>= 1 crc ^= 0xA001 else: crc >>= 1 return crc def program_flash(bin_file): if serial_init() == 0: bin_file_size = os.path.getsize(bin_file) status.insert('end',f'bin文件大小: {bin_file_size}字节n') bin_file_name = os.path.basename(bin_file) status.insert('end','bin文件名: n' + bin_file_name) status.insert('end', '一共有%d个数据包需要发送n' % (int(bin_file_size / 128) + 1)) status.insert('end','发送第1个数据包n') packet = [0] * FIRST_PACKET_LEN packet[0] = 0 i = FILE_NAME_INDEX for c in bin_file_name: packet = ord(c) i = i + 1 packet[FILE_SIZE_INDEX] = (bin_file_size >> 24) & 0xff packet[FILE_SIZE_INDEX + 1] = (bin_file_size >> 16) & 0xff packet[FILE_SIZE_INDEX + 2] = (bin_file_size >> 8) & 0xff packet[FILE_SIZE_INDEX + 3] = (bin_file_size >> 0) & 0xff crc = calc_crc16(packet[1:129]) packet[FIRST_PACKET_CRC0_INDEX] = (crc >> 0) & 0xff packet[FIRST_PACKET_CRC1_INDEX] = (crc >> 8) & 0xff serial_write(bytes(packet)) ack = serial_read(1, 3) if (ack != ACK): status.insert('end','请检查是否打开串口下载模式n') return bin_file = open(bin_file, 'rb') data = bin_file.read(bin_file_size) remain_data_len = bin_file_size remain_data_index = 0 for i in range(int(bin_file_size / 128) + 1): status.insert('end','发送第%d个数据包n' % (i + 1)) packet = [0] * OTHER_PACKET_LEN packet[0] = i + 1 j = 1 k = remain_data_index if (remain_data_len >= 128): for r in range(128): packet[j] = data[k] j = j + 1 k = k + 1 crc = calc_crc16(packet[1:129]) packet[FIRST_PACKET_CRC0_INDEX] = (crc >> 0) & 0xff packet[FIRST_PACKET_CRC1_INDEX] = (crc >> 8) & 0xff serial_write(bytes(packet)) ack = serial_read(1, 3) if (ack != ACK): status.insert('end','NACK1应答错误n') return remain_data_len = remain_data_len - 128 remain_data_index = remain_data_index + 128 else: for r in range(remain_data_len): packet[j] = data[k] j = j + 1 k = k + 1 crc = calc_crc16(packet[1:129]) packet[FIRST_PACKET_CRC0_INDEX] = (crc >> 0) & 0xff packet[FIRST_PACKET_CRC1_INDEX] = (crc >> 8) & 0xff serial_write(bytes(packet)) ack = serial_read(1, 3) if (ack != ACK): status.insert('end','NACK2应答错误n') return bin_file.close() status.insert('end','下载成功n') else: status.insert('end','串口初始化失败n') serial_deinit() def refresh_comlist(event): port_list = list(serial.tools.list_ports.comports()) port_list = list(port_list) com_list['value'] = port_list def pro_bin(event): global com_str com_str = com_list.get() com_str = com_str[0:com_str.find('-') - 1] if file_status and com_str != '': program_flash(file_path) else: tkinter.messagebox.showerror(title='错误', message='请选择文件或者端口') def set_button(event): global file_status global file_path file_path = filedialog.askopenfilename(filetypes=[('binary', '*.bin')]) file_text.delete(0, "end") file_text.insert('insert', file_path) file_get['text'] = '文件名:' + file_path[file_path.rfind("/") + 1 : len(file_path)] file_status = True def clear_status(event): status.delete(1.0, 'end') def init_window(): global file_text global file_get global com_list global status frame_file = tkinter.LabelFrame(top, text='文件', height=100, width=400) frame_file.pack() top.title('tiny risc-v串口下载工具') top.geometry('410x350+10+10') top.resizable(0, 0) file_label = tkinter.Label(frame_file, text='文件路径:', height=2) file_label.grid(row=0, column=0) file_text = tkinter.Entry(frame_file, width=40) file_text.grid(row=0, column=1) file_button = tkinter.Label(frame_file, text='选择文件', height=2) file_button.bind(' file_button.grid(row=0, column=2) file_get = tkinter.Label(frame_file, text='文件名:', height=2) file_get.grid(row=1, column=1) frame_com = tkinter.LabelFrame(top, text='下载', height=100, width=400) frame_com.pack() com_label = tkinter.Label(frame_com, text='端口:') com_label.grid(row=0, column=0) com_list = ttk.Combobox(frame_com, height=1, width=10) com_list.grid(row=0, column=1, ipadx=40, padx=60) com_refresh = tkinter.Label(frame_com, text='刷新端口', height=1) com_refresh.grid(row=0, column=2) com_refresh.bind(' pro_button = tkinter.Label(frame_com, text='开始下载', height=1) pro_button.grid(row=1, column=1) pro_button.bind(' frame_status = tkinter.LabelFrame(top, text='状态', height=100, width=400) frame_status.pack() status = tkinter.Text(frame_status, height=10) status.pack() status.config(wrap=tkinter.WORD) clear_button = tkinter.Label(frame_status, text='清空所有状态信息') clear_button.pack() clear_button.bind(' if __name__ == '__main__': init_window() top.mainloop() 使用方法: |
3363 浏览 0 评论
3370 浏览 9 评论
3061 浏览 16 评论
3551 浏览 1 评论
9182 浏览 16 评论
1304浏览 3评论
669浏览 2评论
663浏览 2评论
2411浏览 2评论
1978浏览 2评论
GMT+8, 2025-2-23 23:14 , Processed in 1.050108 second(s), Total 46, Slave 37 queries .
