扫一扫,分享给好友
在安装包的过程中,如果遇到以下问题:
toybrick@debian10:~/Desktop/yys_project/local_rtsp20191022/build$ sudo apt install rockchip-mpp-dev Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: rockchip-mpp The following NEW packages will be installed: rockchip-mpp rockchip-mpp-dev 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 444 kB of archives. After this operation, 1485 kB of additional disk space will be used. Do you want to continue? [Y/n] y Err:1 http://repo.rock-chips.com/debian buster/main arm64 rockchip-mpp arm64 1.3.7-14 |
1684 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3449 浏览 0 评论
2301 浏览 1 评论
3522 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3794 浏览 1 评论
GMT+8, 2024-9-22 07:40 , Processed in 0.331884 second(s), Total 39, Slave 34 queries .
