因项目本身要求,在RK3399pro上实现RTSP的程序流,Live555程序功能已经实现了本地的服务端视频,本文主要是基于瑞芯微的MPP解码+live555实现RTSP的服务端基本完成了,怕忘记所以一下记录。
准备
编译MPP
./make-Makefiles.bash -- cmake version 3.5.1 -- The C compiler identification is GNU 6.3.1 -- The CXX compiler identification is GNU 6.3.1 -- Check for working C compiler: /opt/gcc-aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -- Check for working C compiler: /opt/gcc-aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /opt/gcc-aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -- Check for working CXX compiler: /opt/gcc-aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- CMAKE_SYSTEM_PROCESSOR value `armv8-a` is unknown -- Please add this value near 源码位置/mpp/CMakeLists.txt:102 -- Performing Test GCC_HAS_NO_NARROWING -- Performing Test GCC_HAS_NO_NARROWING - Success -- Performing Test GCC_HAS_STACK_REALIGN -- Performing Test GCC_HAS_STACK_REALIGN - Failed -- Found PkgConfig: /usr/bin/pkg-config (found version "0.28") -- Checking for one of the modules 'pthread' -- Looking for pthread.h -- Looking for pthread.h - found -- Looking for pthread_create -- Looking for pthread_create - not found -- Looking for pthread_create in pthreads -- Looking for pthread_create in pthreads - not found -- Looking for pthread_create in pthread -- Looking for pthread_create in pthread - found -- Found Threads: TRUE -- compile with drm support -- Configuring done -- Generating done CMake Warning: Manually-specified variables were not used by the project: RKPLATFORM -- Build files have been written to: 源码位置/mpp/build/linux/aarch64
./make Scanning dependencies of target osal [ 0%] Building CXX object osal/CMakeFiles/osal.dir/mpp_platform.cpp.o [ 0%] Building CXX object osal/CMakeFiles/osal.dir/mpp_runtime.cpp.o [ 1%] Building CXX object osal/CMakeFiles/osal.dir/mpp_allocator.cpp.o [ 1%] Building CXX object osal/CMakeFiles/osal.dir/mpp_thread.cpp.o [ 1%] Building CXX object osal/CMakeFiles/osal.dir/mpp_common.cpp.o [ 2%] Building CXX object osal/CMakeFiles/osal.dir/mpp_queue.cpp.o [ 2%] Building CXX object osal/CMakeFiles/osal.dir/mpp_time.cpp.o [ 2%] Building CXX object osal/CMakeFiles/osal.dir/mpp_list.cpp.o [ 3%] Building CXX object osal/CMakeFiles/osal.dir/mpp_mem.cpp.o [ 3%] Building CXX object osal/CMakeFiles/osal.dir/mpp_env.cpp.o [ 3%] Building CXX object osal/CMakeFiles/osal.dir/mpp_log.cpp.o [ 4%] Building C object osal/CMakeFiles/osal.dir/android/os_allocator.c.o [ 4%] Building C object osal/CMakeFiles/osal.dir/android/os_mem.c.o [ 4%] Building C object osal/CMakeFiles/osal.dir/android/os_env.c.o ... Scanning dependencies of target mpi_enc_multi_test [ 99%] Building C object test/CMakeFiles/mpi_enc_multi_test.dir/mpi_enc_multi_test.c.o [100%] Building C object test/CMakeFiles/mpi_enc_multi_test.dir/mpp_event_trigger.c.o [100%] Building C object test/CMakeFiles/mpi_enc_multi_test.dir/mpp_parse_cfg.c.o [100%] Linking CXX executable mpi_enc_multi_test [100%] Built target mpi_enc_multi_test
make install [ 9%] Built target osal [ 10%] Built target mpp_device [ 14%] Built target mpp_base [ 14%] Built target vproc_iep [ 15%] Built target mpp_rc [ 16%] Built target codec_dummy_dec [ 16%] Built target codec_avsd ... [ 96%] Built target mpi_enc_test [ 97%] Built target mpp_info_test [ 98%] Built target mpi_test [ 99%] Built target mpi_rc_test [100%] Built target mpi_enc_multi_test Install the project... -- Install configuration: "Release"
tree . ├── bin │ ├── mpi_dec_mt_test │ ├── mpi_dec_multi_test │ ├── mpi_dec_test │ ├── mpi_enc_multi_test │ ├── mpi_enc_test │ ├── mpi_rc2_test │ ├── mpi_rc_test │ ├── mpi_test │ ├── mpp_info_test │ └── vpu_api_test ├── include │ └── rockchip │ ├── mpp_buffer.h │ ├── mpp_err.h │ ├── mpp_frame.h │ ├── mpp_meta.h │ ├── mpp_packet.h │ ├── mpp_task.h │ ├── rk_mpi_cmd.h │ ├── rk_mpi.h │ ├── rk_type.h │ ├── rk_venc_cmd.h │ ├── vpu_api.h │ └── vpu.h └── lib ├── librockchip_mpp.so -> librockchip_mpp.so.1 ├── librockchip_mpp.so.0 ├── librockchip_mpp.so.1 -> librockchip_mpp.so.0 ├── librockchip_mpp_static.a ├── librockchip_vpu.so -> librockchip_vpu.so.1 ├── librockchip_vpu.so.0 ├── librockchip_vpu.so.1 -> librockchip_vpu.so.0 ├── librockchip_vpu_static.a └── pkgconfig ├── rockchip_mpp.pc └── rockchip_vpu.pc 5 directories, 32 files
编译live555
CROSS_COMPILE?= aarch64-linux-gnu- COMPILE_OPTS = $(INCLUDES) -I. -O2 -DSOCKLEN_T=socklen_t -DNO_SSTREAM=1 -D_LARGEFILE_SOURCE=1 -D_FILE_OFFSET_BITS=64 C = c C_COMPILER = $(CROSS_COMPILE)gcc C_FLAGS = $(COMPILE_OPTS) CPP = cpp CPLUSPLUS_COMPILER = $(CROSS_COMPILE)g++ CPLUSPLUS_FLAGS = $(COMPILE_OPTS) -Wall -DBSD=1 OBJ = o LINK = $(CROSS_COMPILE)g++ -o LINK_OPTS = CONSOLE_LINK_OPTS = $(LINK_OPTS) LIBRARY_LINK = $(CROSS_COMPILE)ar cr LIBRARY_LINK_OPTS = $(LINK_OPTS) LIB_SUFFIX = a LIBS_FOR_CONSOLE_APPLICATION = LIBS_FOR_GUI_APPLICATION = EXE = #个人安装目录,自己修改 PREFIX = /home/xzm/3-CSDN_Test_Project/2-live555/install
#/home/xzm/3-CSDN_Test_Project/2-live555/live/BasicUsageEnvironment/Makefile #其他几个文件夹也类似,修改之后进行make
make cd liveMedia ; make make[1]: Entering directory '/home/xzm/3-CSDN_Test_Project/2-live555/live/liveMedia' ... make[1]: Leaving directory '/home/xzm/3-CSDN_Test_Project/2-live555/live/proxyServer' For more information about this source code (including your obligations under the LGPL), please see our FAQ at http://live555.com/liveMedia/faq.html make install make[1]: Entering directory '/home/xzm/3-CSDN_Test_Project/2-live555/live/liveMedia' install -d /home/xzm/3-CSDN_Test_Project/2-live555/install/include/liveMedia /home/xzm/3-CSDN_Test_Project/2-live555/install/lib install -m 644 include/*.hh /home/xzm/3-CSDN_Test_Project/2-live555/install/include/liveMedia install -m 644 libliveMedia.a /home/xzm/3-CSDN_Test_Project/2-live555/install/lib ... cd proxyServer ; make install make[1]: Entering directory '/home/xzm/3-CSDN_Test_Project/2-live555/live/proxyServer' install -d /home/xzm/3-CSDN_Test_Project/2-live555/install/bin install -m 755 live555ProxyServer /home/xzm/3-CSDN_Test_Project/2-live555/install/bin make[1]: Leaving directory '/home/xzm/3-CSDN_Test_Project/2-live555/live/proxyServer'
tree . ├── bin ├── include │ ├── BasicUsageEnvironment │ ├── groupsock │ ├── liveMedia │ └── UsageEnvironment └── lib ├── libBasicUsageEnvironment.a ├── libgroupsock.a ├── libliveMedia.a └── libUsageEnvironment.a 7 directories, 213 files 部分demo源码记录 MPP 解码 具体详细的源码可以查看MPP官方文档的mpi_dec_test.c、mpi_dec_mt_test.c、mpi_dec_multi_test.c。 MPP_RET ret = mpi->decode_put_packet(ctx, packet); //put 很多次得到一个frame 输入h264的packet数据 MPP_RET ret = mpi->decode_get_frame(ctx, &frame); //得到解码的yuv数据 MPP 编码 具体详细的源码可以查看MPP官方文档的mpi_enc_test.c、mpi_enc_multi_test.c。 ret = mpi->encode_put_frame(ctx, frame); //阻塞函数,直到输入图像使用完成 输入yuv图像数据 ret = mpi->encode_get_packet(ctx, &packet_g);//得到编码的h264格式数据 // write packet to file here void *ptr = mpp_packet_get_pos(packet_g); //得到数据指针位置 size_t len = mpp_packet_get_length(packet_g);//得到数据长度 p->pkt_eos = mpp_packet_get_eos(packet_g); //copy数据并写至管道,供live555服务端使用 void *cpy = malloc(len); memcpy(cpy, ptr, len); if(mpp_packet_write_to_fifo(cpy, len) < 0)//阻塞 { // goto RET; printf(" mpp_packet_write_to_fifo err n"); } live555利用管道实现h264实时视频RTSP推流 上面得到了h264编码后的文件后,写至管道,利用函数写入管道。 int mpp_packet_write_to_fifo(void *ptr, size_t len) { int ret = 0; if(!isOpen) { printf("start open the fifo filen"); pipe_fd = open(fifo_name, O_WRONLY); //阻塞至读端打开 if(pipe_fd != -1) { printf("open fifo successn"); printf("thread mpp_packet_write_to_fifo, pipe_fd = %dn", pipe_fd); isOpen = true; //return pipe_fd; } else { printf("pipe file open error %sn", strerror(errno)); return -1; // pthread_exit(NULL); } } ret = write(pipe_fd, ptr, len); if(ret != len) { printf("=======Write fifo Err======n"); return -1; } return 0; } //live555 接口 OutPacketBuffer::maxSize = 500000;//防止单帧数据过大 char const* streamName = "stream"; //char const* inputFileName = "my_fifo"; char const* inputFileName = fifo_name; ServerMediaSession* sms = ServerMediaSession::createNew(*env, streamName, streamName, descriptionString); sms->addSubsession(H264VideoFileServerMediaSubsession::createNew(*env, inputFileName, reuseFirstSource)); rtspServer->addServerMediaSession(sms); |
live555源码分析
1.针对官方测试程序live/testProgs/testOnDemandRTSPServer.cpp进行部分分析。
// A H.264 video elementary stream: //创建h264RTSP服务端,播放的视频是out.h264 { char const* streamName = "h264ESVideoTest"; char const* inputFileName = "out.h264";//xzm0114 ServerMediaSession* sms = ServerMediaSession::createNew(*env, streamName, streamName, descriptionString); sms->addSubsession(H264VideoFileServerMediaSubsession ::createNew(*env, inputFileName, reuseFirstSource));//根据文件名创建新的H264VideoFileServerMediaSubsession rtspServer->addServerMediaSession(sms); announceStream(rtspServer, sms, streamName, inputFileName); }
H264VideoFileServerMediaSubsession* H264VideoFileServerMediaSubsession::createNew(UsageEnvironment& env, char const* fileName, Boolean reuseFirstSource) { return new H264VideoFileServerMediaSubsession(env, fileName, reuseFirstSource); } H264VideoFileServerMediaSubsession::H264VideoFileServerMediaSubsession(UsageEnvironment& env, char const* fileName, Boolean reuseFirstSource) : FileServerMediaSubsession(env, fileName, reuseFirstSource), fAuxSDPLine(NULL), fDoneFlag(0), fDummyRTPSink(NULL) { }
FileServerMediaSubsession ::FileServerMediaSubsession(UsageEnvironment& env, char const* fileName, Boolean reuseFirstSource) : OnDemandServerMediaSubsession(env, reuseFirstSource), fFileSize(0) { //头文件中定义 char const* fFileName; 子类可以通过继承得到文件名 fFileName = strDup(fileName); } FileServerMediaSubsession::~FileServerMediaSubsession() { delete[] (char*)fFileName; }
//createNewStreamSource 为虚函数 父类中进行使用 FramedSource* H264VideoFileServerMediaSubsession::createNewStreamSource(unsigned /*clientSessionId*/, unsigned& estBitrate) { estBitrate = 500; // kbps, estimate // Create the video source: //xzm0114 通过继承得到的fFilename 创建ByteStreamFileSource ByteStreamFileSource* fileSource = ByteStreamFileSource::createNew(envir(), fFileName); if (fileSource == NULL) return NULL; fFileSize = fileSource->fileSize(); // Create a framer for the Video Elementary Stream: return H264VideoStreamFramer::createNew(envir(), fileSource); }
OnDemandServerMediaSubsession::sdpLines() { if (fSDPLines == NULL) { // We need to construct a set of SDP lines that describe this // subsession (as a unicast stream). To do so, we first create // dummy (unused) source and "RTPSink" objects, // whose parameters we use for the SDP lines: unsigned estBitrate; //调用子类实现的createNewStreamSource /* 头文件中定义虚函数 protected: // new virtual functions, defined by all subclasses virtual FramedSource* createNewStreamSource(unsigned clientSessionId, unsigned& estBitrate) = 0; */ FramedSource* inputSource = createNewStreamSource(0, estBitrate); printf("=====xzm %s:%d:%s=======nn",__FILE__, __LINE__, __func__); //xzm0114 if (inputSource == NULL) return NULL; // file not found struct in_addr dummyAddr; dummyAddr.s_addr = 0; Groupsock* dummyGroupsock = createGroupsock(dummyAddr, 0); unsigned char rtpPayloadType = 96 + trackNumber()-1; // if dynamic RTPSink* dummyRTPSink = createNewRTPSink(dummyGroupsock, rtpPayloadType, inputSource); if (dummyRTPSink != NULL && dummyRTPSink->estimatedBitrate() > 0) estBitrate = dummyRTPSink->estimatedBitrate(); setSDPLinesFromRTPSink(dummyRTPSink, inputSource, estBitrate); Medium::close(dummyRTPSink); delete dummyGroupsock; closeStreamSource(inputSource); printf("=====xzm %s:%d:%s=======nn",__FILE__, __LINE__, __func__); //xzm0114 } return fSDPLines; } //void OnDemandServerMediaSubsession::getStreamParameters函数中 FramedSource* mediaSource = createNewStreamSource(clientSessionId, streamBitrate); // Create 'groupsock' and 'sink' objects for the destination, // using previously unused server port numbers:
FILE* OpenInputFile(UsageEnvironment& env, char const* fileName) { FILE* fid; // Check for a special case file name: "stdin" if (strcmp(fileName, "stdin") == 0) { fid = stdin; #if (defined(__WIN32__) || defined(_WIN32)) && !defined(_WIN32_WCE) _setmode(_fileno(stdin), _O_BINARY); // convert to binary mode #endif } else { fid = fopen(fileName, "rb"); if (fid == NULL) { env.setResultMsg("unable to open file "",fileName, """); } printf("nnnnn======xzm Open file:%s========nnnnnn", fileName); //xzm0113 } return fid; } void CloseInputFile(FILE* fid) { // Don't close 'stdin', in case we want to use it again later. if (fid != NULL && fid != stdin) fclose(fid); printf("nnnnn======xzm Close file ========nnnnnn");//xzm0113 }
void ByteStreamFileSource::doReadFromFile() { // Try to read as many bytes as will fit in the buffer provided (or "fPreferredFrameSize" if less) if (fLimitNumBytesToStream && fNumBytesToStream < (u_int64_t)fMaxSize) { fMaxSize = (unsigned)fNumBytesToStream; } if (fPreferredFrameSize > 0 && fPreferredFrameSize < fMaxSize) { fMaxSize = fPreferredFrameSize; } #ifdef READ_FROM_FILES_SYNCHRONOUSLY fFrameSize = fread(fTo, 1, fMaxSize, fFid); #else //xzm0113 if (fFidIsSeekable) { printf("======Use fread=======nn");//xzm0113 fFrameSize = fread(fTo, 1, fMaxSize, fFid); } else { // For non-seekable files (e.g., pipes), call "read()" rather than "fread()", to ensure that the read doesn't block: fFrameSize = read(fileno(fFid), fTo, fMaxSize); printf("======Use read,fFrameSize:%d ,fMaxSize:%d =======nn", fFrameSize, fMaxSize);//xzm0113 } #endif if (fFrameSize == 0) { handleClosure(); return; } fNumBytesToStream -= fFrameSize; // Set the 'presentation time': if (fPlayTimePerFrame > 0 && fPreferredFrameSize > 0) { if (fPresentationTime.tv_sec == 0 && fPresentationTime.tv_usec == 0) { // This is the first frame, so use the current time: gettimeofday(&fPresentationTime, NULL); } else { // Increment by the play time of the previous data: unsigned uSeconds = fPresentationTime.tv_usec + fLastPlayTime; fPresentationTime.tv_sec += uSeconds/1000000; fPresentationTime.tv_usec = uSeconds%1000000; } // Remember the play time of this data: fLastPlayTime = (fPlayTimePerFrame*fFrameSize)/fPreferredFrameSize; fDurationInMicroseconds = fLastPlayTime; } else { // We don't know a specific play time duration for this data, // so just record the current time as being the 'presentation time': gettimeofday(&fPresentationTime, NULL); } // Inform the reader that he has data: #ifdef READ_FROM_FILES_SYNCHRONOUSLY // To avoid possible infinite recursion, we need to return to the event loop to do this: nextTask() = envir().taskScheduler().scheduleDelayedTask(0, (TaskFunc*)FramedSource::afterGetting, this); #else // Because the file read was done from the event loop, we can call the // 'after getting' function directly, without risk of infinite recursion: FramedSource::afterGetting(this); #endif }
// live/liveMedia/StreamParser.cpp // #define BANK_SIZE 150000 #define BANK_SIZE 3000000 //xzm0113 OutPacketBuffer::maxSize = 500000;//1229xzm live555初始化时执行 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
626 浏览 0 评论
887 浏览 1 评论
784 浏览 1 评论
1997 浏览 1 评论
3242 浏览 1 评论
GMT+8, 2024-12-24 00:45 , Processed in 0.481870 second(s), Total 44, Slave 38 queries .
