扫一扫,分享给好友
终于开始接触网络了,基础不行,这个摸索了有点久,还好网上资料多,有些细节还是没有怎么吃透。哈哈,开始联网了。
ESP8266有三种模式:
根据手册(手册是个好东西呀)总体思路是这样的:
void to_scan(void) { wifi_station_scan(NULL,scan_done); } 上代码 // 头文件引用 //================================================================================== #include "user_config.h" // 用户配置 #include "driver/uart.h" // 串口 #include "c_types.h" // 变量类 #include "eagle_soc.h" // GPIO函数、宏定义 #include "ets_sys.h" // 回调函数 #include "os_type.h" // os_XXX #include "osapi.h" // os_XXX、软件定时器 #include "user_interface.h" // 系统接口、system_param_xxx接口、WIFI、RateContro #include "pwm.h" #include "ip_addr.h" #include "espconn.h" #include "mem.h" #include "smartconfig.h" #include "airkiss.h" //================================================================================== ETSTimer connect_timer; void ICACHE_FLASH_ATTR Wifi_conned(void *arg) { static uint8 count = 0; uint8 status; os_timer_disarm(&connect_timer); count++; status = wifi_station_get_connect_status(); if (status == STATION_GOT_IP) { os_printf("Wifi connect success!"); return; } else { if (count >= 7) { os_printf("Wifi connect fail!"); return; } } os_timer_arm(&connect_timer, 2000, false); } void ICACHE_FLASH_ATTR scan_done(void *arg, STATUS status) { uint8 ssid[33]; char temp[128]; struct station_config stationConf; if (status == OK) { struct bss_info *bss_link = (struct bss_info *)arg; bss_link = bss_link->next.stqe_next; while (bss_link != NULL) { os_memset(ssid, 0, 33); if (os_strlen(bss_link->ssid) <= 32) { os_memcpy(ssid, bss_link->ssid, os_strlen(bss_link->ssid)); } else { os_memcpy(ssid, bss_link->ssid, 32); } os_sprintf(temp, "+CWLAP:(%d,"%s",%d,"" MACSTR "",%d)rn", bss_link->authmode, ssid, bss_link->rssi, MAC2STR(bss_link->bssid), bss_link->channel); os_printf("%s", temp); bss_link = bss_link->next.stqe_next; } //扫描完成以后就开始连接WiFi了 os_memcpy(&stationConf.ssid, "aaaaa", 32); //wifi名 os_memcpy(&stationConf.password, "123456789", 64); //wifi密码 wifi_station_set_config_current(&stationConf); wifi_station_connect(); os_timer_setfn(&connect_timer, (ETSTimerFunc *)(Wifi_conned), NULL); //调用WiFi连接函数 os_timer_arm(&connect_timer, 2000, false); } else { os_printf("connect error!n"); } } void to_scan(void) { wifi_station_scan(NULL, scan_done); } void user_init() { uint8 opmode; uart_init(115200, 115200); wifi_set_opmode(0x03); //设置为soft-AP兼station模式 opmode = wifi_get_opmode_default(); //获取当前工作模式 os_printf("rn当前的工作模式:%drn", opmode); system_init_done_cb(to_scan); //注册系统初始化函数,等待系统初始化完成后扫描wifi } uint32 ICACHE_FLASH_ATTR user_rf_cal_sector_set(void) { enum flash_size_map size_map = system_get_flash_size_map(); uint32 rf_cal_sec = 0; switch (size_map) { case FLASH_SIZE_4M_MAP_256_256: rf_cal_sec = 128 - 5; break; case FLASH_SIZE_8M_MAP_512_512: rf_cal_sec = 256 - 5; break; case FLASH_SIZE_16M_MAP_512_512: case FLASH_SIZE_16M_MAP_1024_1024: rf_cal_sec = 512 - 5; break; case FLASH_SIZE_32M_MAP_512_512: case FLASH_SIZE_32M_MAP_1024_1024: rf_cal_sec = 1024 - 5; break; case FLASH_SIZE_64M_MAP_1024_1024: rf_cal_sec = 2048 - 5; break; case FLASH_SIZE_128M_MAP_1024_1024: rf_cal_sec = 4096 - 5; break; default: rf_cal_sec = 0; break; } return rf_cal_sec; } void ICACHE_FLASH_ATTR user_rf_pre_init(void) {} AP配置 设置模式为station+soft-AP模式 使用wifi_softap_get_config获取当前ap配置 更改配置参数ssid和password,8266的wifi名和密码,看个人喜好设。 使用wifi_softap_set_config设置ap参数 void ICACHE_FLASH_ATTR user_init(void) { struct softap_config config; uint8 opmode; uart_init(115200, 115200); wifi_set_opmode(0x03); //设置为AP模式 opmode = wifi_get_opmode_default(); os_printf("rn当前的工作模式:%drn", opmode); wifi_softap_get_config(&config); os_memcpy(config.ssid, "ESP8266", strlen("ESP8266")); os_memcpy(config.password, "12345678", strlen("12345678")); config.ssid_len = strlen("ESP8266"); wifi_softap_set_config(&config); } 现在就可以搜到“ESP8266”的wifi了。 UDP通信 设置远程ip为“255.255.255.255” 设置远程端口:1234 设置本地端口:2333 注册接受回调函数 注册发送回调函数 建立udp通信 获取mac地址 发数据 配置udp,修改wifi连接的代码即可。 void ICACHE_FLASH_ATTR Wifi_conned(void *arg) { static uint8 count = 0; uint8 status; os_timer_disarm(&connect_timer); count++; status = wifi_station_get_connect_status(); if (status == STATION_GOT_IP) { os_printf("Wifi connect success!"); //连接WiFi成功 wifi_set_broadcast_if(STATIONAP_MODE); //设置UDP广播的发送接口station+soft-AP模式发送 user_udp_espconn.type = ESPCONN_UDP; user_udp_espconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp)); user_udp_espconn.proto.udp->local_port = 2333;//本地端口 user_udp_espconn.proto.udp->remote_port = 1234;//远程端口 const char udp_remote_ip[4] = {255, 255, 255, 255}; //用于存放远程IP地址 os_memcpy(&user_udp_espconn.proto.udp->remote_ip, udp_remote_ip, 4); espconn_regist_recvcb(&user_udp_espconn, user_udp_recv_cb); //接收回调函数 espconn_regist_sentcb(&user_udp_espconn, user_udp_sent_cb); //发送回调函数 espconn_create(&user_udp_espconn); //创建UDP连接 user_udp_send(); //发送出去 return; } else { if (count >= 7) { os_printf("Wifi connect fail!"); return; } } os_timer_arm(&connect_timer, 2000, false); } 配置发送和接收函数 void ICACHE_FLASH_ATTR user_udp_sent_cb(void *arg) //发送回调函数 { os_printf("rnUDP发送成功!rn"); os_timer_disarm(&test_timer); os_timer_setfn(&test_timer, (ETSTimerFunc *)(user_udp_send), NULL); os_timer_arm(&test_timer, 1000, false); //每秒钟发送一次 } void ICACHE_FLASH_ATTR user_udp_recv_cb(void *arg, char *pdata, unsigned short len) //接收回调函数 { os_printf("UDP已经接收数据:%s", pdata); //UDP接收到的数据打印出来 } 注册udp函数,广播本机mac地址 void ICACHE_FLASH_ATTR user_udp_send(void) //UDP发送函数 { char yladdr[6]; char DeviceBuffer[40] = {0}; //将获取的MAC地址格式化输出到一个buffer里面 wifi_get_macaddr(STATION_IF, yladdr); //查询MAC地址 os_sprintf(DeviceBuffer, "设备地址为" MACSTR "!!!rn", MAC2STR(yladdr)); //格式化MAC地址 espconn_sent(&user_udp_espconn, DeviceBuffer, os_strlen(DeviceBuffer)); } 1 2 3 4 5 6 7 8 完整代码 // 头文件引用 //================================================================================== #include "user_config.h" // 用户配置 #include "driver/uart.h" // 串口 #include "c_types.h" // 变量类 #include "eagle_soc.h" // GPIO函数、宏定义 #include "ets_sys.h" // 回调函数 #include "os_type.h" // os_XXX #include "osapi.h" // os_XXX、软件定时器 #include "user_interface.h" // 系统接口、system_param_xxx接口、WIFI、RateContro #include "pwm.h" #include "ip_addr.h" #include "espconn.h" #include "mem.h" #include "smartconfig.h" #include "airkiss.h" //================================================================================== struct espconn user_udp_espconn; ETSTimer connect_timer; ETSTimer test_timer; // 毫秒延时函数 //=========================================== void ICACHE_FLASH_ATTR delay_ms(u32 C_time) { for (; C_time > 0; C_time--) os_delay_us(1000); } //=========================================== void ICACHE_FLASH_ATTR user_udp_send(void) //UDP发送函数 { char yladdr[6]; char DeviceBuffer[40] = {0}; //将获取的MAC地址格式化输出到一个buffer里面 wifi_get_macaddr(STATION_IF, yladdr); //查询MAC地址 os_sprintf(DeviceBuffer, "设备地址为" MACSTR "!!!rn", MAC2STR(yladdr)); //格式化MAC地址 espconn_sent(&user_udp_espconn, DeviceBuffer, os_strlen(DeviceBuffer)); } void ICACHE_FLASH_ATTR user_udp_sent_cb(void *arg) //发送回调函数 { os_printf("rnUDP发送成功!rn"); os_timer_disarm(&test_timer); //定个时发送 os_timer_setfn(&test_timer, (ETSTimerFunc *)(user_udp_send), NULL); os_timer_arm(&test_timer, 1000, false); //定1秒钟发送一次 } void ICACHE_FLASH_ATTR user_udp_recv_cb(void *arg, char *pdata, unsigned short len) //接收回调函数 { os_printf("UDP已经接收数据:%s", pdata); //UDP接收到的数据打印出来 } void ICACHE_FLASH_ATTR Wifi_conned(void *arg) { static uint8 count = 0; uint8 status; os_timer_disarm(&connect_timer); count++; status = wifi_station_get_connect_status(); if (status == STATION_GOT_IP) { os_printf("Wifi connect success!"); //连接WiFi成功 wifi_set_broadcast_if(STATIONAP_MODE); //设置UDP广播的发送接口station+soft-AP模式发送 user_udp_espconn.type = ESPCONN_UDP; user_udp_espconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp)); user_udp_espconn.proto.udp->local_port = 2333; user_udp_espconn.proto.udp->remote_port = 1234; const char udp_remote_ip[4] = {255, 255, 255, 255}; //用于存放远程IP地址 os_memcpy(&user_udp_espconn.proto.udp->remote_ip, udp_remote_ip, 4); espconn_regist_recvcb(&user_udp_espconn, user_udp_recv_cb); //接收回调函数 espconn_regist_sentcb(&user_udp_espconn, user_udp_sent_cb); //发送回调函数 espconn_create(&user_udp_espconn); //创建UDP连接 user_udp_send(); //发送出去 return; } else { if (count >= 7) { os_printf("Wifi connect fail!"); return; } } os_timer_arm(&connect_timer, 2000, false); } void ICACHE_FLASH_ATTR scan_done(void *arg, STATUS status) { uint8 ssid[33]; char temp[128]; struct station_config stationConf; if (status == OK) { struct bss_info *bss_link = (struct bss_info *)arg; bss_link = bss_link->next.stqe_next; //ignore first while (bss_link != NULL) { os_memset(ssid, 0, 33); if (os_strlen(bss_link->ssid) <= 32) { os_memcpy(ssid, bss_link->ssid, os_strlen(bss_link->ssid)); } else { os_memcpy(ssid, bss_link->ssid, 32); } os_sprintf(temp, "+CWLAP:(%d,"%s",%d,"" MACSTR "",%d)rn", bss_link->authmode, ssid, bss_link->rssi, MAC2STR(bss_link->bssid), bss_link->channel); os_printf("%s", temp); bss_link = bss_link->next.stqe_next; } os_memcpy(&stationConf.ssid, "aaaaa", 32); os_memcpy(&stationConf.password, "12345678", 64); wifi_station_set_config_current(&stationConf); wifi_station_connect(); os_timer_setfn(&connect_timer, Wifi_conned, NULL); os_timer_arm(&connect_timer, 2000, false); } else { os_printf("connect error!n"); } } void to_scan(void) { wifi_station_scan(NULL, scan_done); } void ICACHE_FLASH_ATTR user_init(void) { struct softap_config config; uint8 opmode; uart_init(115200, 115200); wifi_set_opmode(0x03); //设置为AP模式 opmode = wifi_get_opmode_default(); os_printf("rn当前的工作模式:%drn", opmode); wifi_softap_get_config(&config); os_memcpy(config.ssid, "ESP8266", strlen("ESP8266")); os_memcpy(config.password, "123456789", strlen("123456789")); config.ssid_len = strlen("ESP8266"); wifi_softap_set_config(&config); system_init_done_cb(to_scan); //扫描WiFi需要系统初始化完成之后 } //================================================================================================= /****************************************************************************** * FunctionName : user_rf_cal_sector_set * Description : SDK just reversed 4 sectors, used for rf init data and paramters. * We add this function to force users to set rf cal sector, since * we don't know which sector is free in user's application. * sector map for last several sectors : ABCCC * A : rf cal * B : rf init data * C : sdk parameters * Parameters : none * Returns : rf cal sector *******************************************************************************/ uint32 ICACHE_FLASH_ATTR user_rf_cal_sector_set(void) { enum flash_size_map size_map = system_get_flash_size_map(); uint32 rf_cal_sec = 0; switch (size_map) { case FLASH_SIZE_4M_MAP_256_256: rf_cal_sec = 128 - 5; break; case FLASH_SIZE_8M_MAP_512_512: rf_cal_sec = 256 - 5; break; case FLASH_SIZE_16M_MAP_512_512: case FLASH_SIZE_16M_MAP_1024_1024: rf_cal_sec = 512 - 5; break; case FLASH_SIZE_32M_MAP_512_512: case FLASH_SIZE_32M_MAP_1024_1024: rf_cal_sec = 1024 - 5; break; case FLASH_SIZE_64M_MAP_1024_1024: rf_cal_sec = 2048 - 5; break; case FLASH_SIZE_128M_MAP_1024_1024: rf_cal_sec = 4096 - 5; break; default: rf_cal_sec = 0; break; } return rf_cal_sec; } void ICACHE_FLASH_ATTR user_rf_pre_init(void) {} |
3748 浏览 0 评论
3546 浏览 9 评论
3199 浏览 16 评论
3712 浏览 1 评论
9500 浏览 16 评论
1624浏览 3评论
2869浏览 2评论
707浏览 1评论
Banana Pi BPI-PicoW 和 BPI-Leaf-S3 创客教育与物联网开发板介绍
10633浏览 0评论
请问SEGGER Embedded Studio for ARM 7.32怎么实现代码自动补全功能
7688浏览 0评论
GMT+8, 2025-7-3 14:44 , Processed in 1.260658 second(s), Total 77, Slave 58 queries .
