opencv,tensorflow,pytorch的安装
本人rk3399pro 安装系统为ubuntu18.04系统。 1.配置环境依赖项 sudo apt-get update sudo apt-get install build-essential cmake git pkg-config sudo apt-get install libjpeg8-dev libtiff5-dev libpng-dev sudo apt-get install libgtk2.0-dev sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev sudo apt-get install libatlas-base-dev gfortran libhdf5-dev libtbb-dev libeigen3-dev sudo apt-get install gstreamer1.0-tools gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav sudo apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-good1.0-dev libgstreamer-plugins-bad1.0-dev 2.安装pip3,numpy,opencv等 这里opencv采用apt形式安装安装版本为3.2,如需要安装高版本需要源码编译。 sudo apt-get install python3-dev sudo apt-get install python3-pip sudo pip3 install --upgrade pip sudo pip3 config set global.index-url https://pypi.tuna.tsinghua.edu.cn/simple sudo apt-get install python3-numpy sudo apt-get install python3-opencv 3.安装tensorflow,keras,pytorch 下面一些whl包,rk3399的github也有下载 sudo pip3 install h5py 5.添加交换空间 使用结束释放: |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
849 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
999 浏览 0 评论
488 浏览 0 评论
457 浏览 0 评论
776 浏览 0 评论
GMT+8, 2025-2-23 11:43 , Processed in 0.672717 second(s), Total 38, Slave 32 queries .
