STM32在单片机领域因性价比高受到广大工程师的青睐,笔者最近做了一个STM32 M3内核的BootLoader现在把威廉希尔官方网站 的要点梳理如下: 1、首先是对ROM分区的规划,把ROM划分为BOOT区和APP区,划分在KEIL的sct文件完成。 Boot分区 ; ************************************************************* ; *** Scatter-Loading Description File generated by uVision *** ; ************************************************************* LR_IROM1 0x08000000 0x00005800 { ; load region size_region ER_IROM1 0x08000000 0x00005800 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY ;(+RO) } IRAM1 0x20000000 0x00004000 { ; RW data .ANY (+RW +ZI) *.o (RAMCODE) ac78xx_eflash.o (+RO +RW) } IRAM2 0x20004000 0x00002000 { ; RW data .ANY (pg_data1) } IRAM3 0x20006000 0x00002000 { ; RW data (+RW +ZI) .ANY (pg_data2) } } APP分区 ; ************************************************************* ; *** Scatter-Loading Description File generated by uVision *** ; ************************************************************* LR_IROM1 0x08006000 0x00019000 { ; load region size_region ER_IROM1 0x08006000 0x00019000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY ;(+RO) } DATA_FLASH 0x0801f000 0x00001000 { ; load address = execution address * (flash_data) } IRAM1 0x20000000 0x00004000 { ; RW data .ANY (+RW +ZI) } IRAM2 0x20004000 0x00002000 { ; RW data .ANY (pg_data1) } IRAM3 0x20006000 0x00002000 { ; RW data (+RW +ZI) .ANY (pg_data2) } } KEIL工程选择对应的文件 2、BOOT工作完成后向APP跳转,跳转前要关闭中断,避免单片机跑飞。 void JumpApp(uint32_t ApplicationAddress) { uint32_t JumpAddress; pFunction Jump_To_Application; __set_FAULTMASK(1); if (((*(__IO uint32_t *)ApplicationAddress) & 0x2FFE0000 ) == 0x20000000) { /* Jump to user application */ JumpAddress = *(__IO uint32_t *) (ApplicationAddress + 4); Jump_To_Application = (pFunction) JumpAddress; /* Initialize user application's Stack Pointer */ __set_MSP(*(__IO uint32_t*) ApplicationAddress); Jump_To_Application(); } } 3、APP中要调整中断向量表的位置,接收到升级指令时复位进入Bootloader SCB->VTOR = APP_START_ADDR; mdelay(20); __set_FAULTMASK(1); mdelay(5); NVIC_SystemReset(); 4、在进行擦除、编程FLASH时,要关闭中断和看门狗,避免进入非法中断。 5、在进行BootLoader自身更新时需要将相关代码放入RAM中。 __attribute__((section("RAMCODE"))) void * UserMemCpy(uint8_t * dest, const uint8_t * src, int count) { uint8_t * tmp = (uint8_t *) dest; uint8_t * s = (uint8_t *)src; while (count--) *tmp++ = *s++; return dest; } 在sct文件中对应 IRAM1 0x20000000 0x00004000 { ; RW data .ANY (+RW +ZI) *.o (RAMCODE) ac78xx_eflash.o (+RO +RW) } 6、用CAPL编程完成上位机 完成效果如下 |
3188 浏览 9 评论
2878 浏览 16 评论
3383 浏览 1 评论
8815 浏览 16 评论
3979 浏览 18 评论
9613浏览 3评论
984浏览 3评论
503浏览 2评论
506浏览 2评论
2228浏览 2评论
GMT+8, 2024-9-21 13:47 , Processed in 1.052287 second(s), Total 79, Slave 60 queries .
