1.build@build--machine:~/rk3288/kernel$ make rk3288-tb_8846.img
scripts/kconfig/conf --silentoldconfig Kconfig ^C build@build--machine:~/rk3288/kernel$ make rk3288- tb_8846.img CC scripts/mod/devicetable-offsets.s GEN scripts/mod/devicetable- offsets.h HOSTCC scripts/mod/file2alias.o HOSTLD scripts/mod/modpost CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' 是最新的。 CALL scripts/checksyscalls.sh CHK include/generated/compile.h GEN drivers/video/rockchip/screen/lcd.h Kernel: arch/arm/boot/Image is ready LD arch/arm/boot/compressed/vmlinux OBJCOPY arch/arm/boot/zImage Kernel: arch/arm/boot/zImage is ready make: *** [kernel.img] Error 127 #### make failed to build some targets (18 seconds) #### 解决办法: 安装64位机子对32位程序运行的支持。 #sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 2.make中出现:与Jack server 127通信错误。尝试'jack-diagnose' 解决方法: jack-admin kill-server jack-admin uninstall -server 3 . ./prebuilts/sdk/tools/jack-admin:第 163 行:curl:找不到命令 ./prebuilts/sdk/tools/jack-admin:第 163 行:curl:找不到命令 ./prebuilts/sdk/tools /jack-admin:第 163 行:curl:找不到命令 ./prebuilts/sdk/tools/jack-admin: line 163: curl: command not found 与 Jack 服务器的通信错误 (127),尝试“jack-diagnose”或查看 Jack 服务器日志 安装 curl:sudo apt-get install curl 4. [0% 57/35046] 与 Jack 一起构建:out/target/common/obj/...A_LIBRARIES/framework_intermediates/with-local/classes.dexFAILED:/bin/bash out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/ with-local/classes.dex.rspOut of memory error (version 1.2-rc4 'Carnac' (298900 f95d7bdecfceb327f9d201a1348397ed8a843843 by android-jack-team@google.com )).GC 开销限制超出。尝试使用 java 选项增加堆大小'- Xmx export ./prebuilts/sdk/tools/jack-admin kill-server ./prebuilts/sdk/tools/jack-admin start-server 5. /bin/sh: 1: lzop: not found 安装:sudo apt-get install lzop |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 14:41 , Processed in 0.519994 second(s), Total 42, Slave 36 queries .
