查看CPU频率实时运行情况:
/sys/devices/system/cpu/cpufreq all_time_in_state root@x1:/sys/devices/system/cpu/cpufreq # cat all_time_in_state freq cpu0 cpu1 cpu2 cpu3 cpu4 cpu5 cpu6 cpu7 216000 1721 1721 1721 1721 49511 49511 49511 49511 312000 971 971 971 971 4484 4484 4484 4484 408000 1347 1347 1347 1347 1992 1992 1992 1992 600000 12634 12634 12634 12634 76367 76367 76367 76367 696000 8952 8952 8952 8952 1957 1957 1957 1957 816000 27567 27567 27567 27567 24661 24661 24661 24661 1008000 130097 130097 130097 130097 8202 8202 8202 8202 1200000 N/A N/A N/A N/A 12071 12071 12071 12071 1296000 N/A N/A N/A N/A 4044 4044 4044 4044 root@x1:/d/clk # pwd -P /sys/kernel/debug/clk clk_summary root@x1:/ # ls -al d lrwxrwxrwx root root 2017-08-18 08:00 d -> /sys/kernel/debug root@x1:/d/clk # ls clk_dump clk_summary clkin_hsadc_tsp dummy gmac_clkin i2s_clkin jtag_clkin orphans pclkin_isp pclkin_vip pvtm_clkout xin24m xin32k dvfs: root@x1:/sys/dvfs # ls cpu_temp_enable cpu_temp_target dvfs_tree root@x1:/sys/dvfs # cat cpu_temp_enable cpu_b:1 cpu_l:1 root@x1:/sys/dvfs # cat cp cpu_temp_enable cpu_temp_target root@x1:/sys/dvfs # cat cpu_temp_target cpu_b:80 cpu_l:80 root@x1:/sys/dvfs # cat dvfs_tree // 结果会在串口打印出来 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
3097 浏览 0 评论
3023 浏览 1 评论
2503 浏览 1 评论
3843 浏览 1 评论
4579 浏览 1 评论
GMT+8, 2025-2-1 06:38 , Processed in 0.429098 second(s), Total 40, Slave 33 queries .
