代码
- tag_uart = "test5_uart"
- id = 1
- len = 1024
- get_gga_time = 2000
- data_time = ""
- data_longitude = "" -- 经度
- data_latitude = "" -- 纬度
- data_GGA = ""
- data_GGA_status = ""
- GGA_list = {}
- GGA_list["time"] = data_time
- GGA_list["x"] = data_longitude
- GGA_list["y"] = data_latitude
- GGA_list["status"]= data_GGA_status
- function init_uart_air551()
- log.info(tag_uart,"init_uart_air551")
- uart.setup(1, 115200)
- uart_air551_NMEA_set()
- -- 定时发送数据
- -- timex = sys.timerLoopStart(uart_air551_send,1000)
- -- log.info(tag_uart,"time:",timex)
- sys.wait(1000)
- -- func1: 接收数据,只要收到就接收
- -- uart.on(id, "receive",uart_air551_receive)
- -- func2: 定时接收
- timex = sys.timerLoopStart(uart_air551_receive,get_gga_time)
- init_air551G_cont()
- end
- function uart_air551_send()
- -- log.info("uart_air551_send")
- uart.write(id, "test")
- end
- -- 下发命令
- function uart_air551_NMEA_set()
- log.info("uart_air551_NMEA_set")
- uart.write(id, "$PGKC242,0,0,0,1*2Arn") --只接收GGA数据。注意需要传入回车符
- end
- -- 获取串口数据
- function uart_air551_receive()
- log.info("uart_air551_receive start---------------")
- local s = ""
- s = uart.read(id, len)
- if #s > 0 then -- #s 是取字符串的长度
- -- 如果传输二进制/十六进制数据, 部分字符不可见, 不代表没收到
- -- 关于收发hex值,请查阅 https://doc.openluat.com/article/583
- -- log.info("uart", "receive", id, #s, s) -- 这句将接收的都打印出来
- log.info("get air551","uart", "receive", id, #s)
- -- log.info("uart", "receive", id, #s, s:toHex())
- end
- data_GGA = get_gga(s)
- log.info("data_GGA",data_GGA)
- get_gga_longitude_latitude(data_GGA)
- log.info("uart_air551_receive end---------------")
- end
- --测试数据提取
- function test_string_get()
- string_temp = "xxxxx$GNGGA,000004.811,XXX,N,XXX,E,0,0,,143.01,M,6.99,M,,*6Dr$GNGGA,000003.811,*6A"
- temp_start = string.find(string_temp,'$GNGGA',1)
- temp_end = string.find(string_temp,'r',1)
- temp_gga = string.sub(string_temp,temp_start,temp_end-1)
- log.info("temp_x:",temp_start,temp_end,temp_gga)
- end
- -- 提取一组数据
- function get_gga(value)
- temp_start = string.find(value,'GGA',1)-3
- temp_end = string.find(value,'r',1)
- temp_gga = string.sub(value,temp_start,temp_end-1)
- -- log.info("temp_value:",temp_start,temp_end,temp_gga)
- return temp_gga
- end
- function get_gga_longitude_latitude(value_gga)
- -- log.info(type(value_gga))
- if value_gga == "" then --数据第一次异常
- return -1
- end
- -- 获取GGA数据
- -- log.info("L2_temp",L2_temp)
- L2_temp = string.sub(value_gga,8) -- +8是因为"$gngga"
- -- 获取时间
- data_time_h = string.sub(L2_temp,1,2)
- data_time_m = string.sub(L2_temp,3,4)
- data_time_s = string.sub(L2_temp,4,5)
- -- data_time_h = string.t(data_time_h)
- data_time_h = math.floor(data_time_h +8)
- -- log.info(type(data_time_h),data_time_h)
- if data_time_h >= 24 then
- data_time_h = data_time_h -24
- end
- -- data_time_h = tostring(data_time_h)
- if data_time_h <10 then
- data_time_h = '0'..data_time_h
- end
- -- data_time_h = string.(8 + string.toValue(data_time_h))
- data_time = data_time_h..":"..data_time_m..":"..data_time_s
- -- 获取纬度
- L2_temp_x_start = string.find(L2_temp,',',1)+1
- L2_temp_x_end = string.find(L2_temp,',N',1)-1
- data_longitude = string.sub(L2_temp,L2_temp_x_start,L2_temp_x_end)
- -- 获取经度
- L2_temp_y_start = L2_temp_x_end+4
- -- +4是因为"time,xxx,N,yyy,E",",N"后面三个才是y开始
- L2_temp_y_end = string.find(L2_temp,',E',1)-1
- data_latitude = string.sub(L2_temp,L2_temp_y_start,L2_temp_y_end)
- -- log.info("L2_temp_gga",data_longitude,data_latitude)
- -- 获取定位指示",E,定位指示,"
- L2_temp_status_start = L2_temp_y_end + 4
- L2_temp_status_end = L2_temp_status_start
- data_GGA_status = string.sub(L2_temp,L2_temp_status_start,L2_temp_status_end)
- -- log.info("data_GGA_status",data_GGA_status)
- if data_GGA_status == "0" then
- log.info("定位指示为0,未定位")
- elseif data_GGA_status == "1" then
- log.info("定位指示为1,SPS 模式,定位有效")
- elseif data_GGA_status == "2" then
- log.info("定位指示为2,差分,SPS 模式,定位有效")
- end
- -- 显示当前状态
- set_air551G_cont()
- return temp_gga
- end
- function init_air551G_cont()
- air551G_cont = lvgl.cont_create(lvgl.scr_act(), nil)
- lvgl.obj_set_size(air551G_cont,128,160)
- lvgl.obj_set_auto_realign(air551G_cont, true)
- lvgl.obj_align_origo(air551G_cont, nil, lvgl.ALIGN_CENTER, 0, 0)
- lvgl.cont_set_fit(air551G_cont, lvgl.FIT_NONE) --此时cont未设置自适应状态,则内容在cont中
- lvgl.cont_set_layout(air551G_cont, lvgl.LAYOUT_COLUMN_LEFT) --布局靠左
- log.info("scr_load",lvgl.scr_load(air551G_cont)) --显示 容器
- --创建标签label
- GGA_label = lvgl.label_create(air551G_cont, nil)
- lvgl.label_set_text(GGA_label, "GGA_data")
- lvgl.obj_set_pos(GGA_label, 2, 5)
- end
- function set_air551G_cont()
- string_GGA = "GGA_data"..'r'.."time: "..GGA_list["time"]..'r'.."x: "..GGA_list["x"]..'r'.."y: "..GGA_list["y"]..'r'.."status: "..GGA_list["status"]
- log.info("string_GGA",string_GGA)
- if string_GGA == "" then
- return -1
- end
- lvgl.label_set_text(GGA_label, string_GGA)
- end
复制代码
结果
