stm8l052的lcd模块在使用内部供电时不能使用
PWR_UltraLowPowerCmd(ENABLE); 进入超低功耗模式(屏幕会闪) 建议Vlcd脚接电源并内部软件配置到外部供电 LCD_Init(LCD_Prescaler_1, LCD_Divider_31, LCD_Duty_1_4, LCD_Bias_1_3, LCD_VoltageSource_External); 全部配置如下: void LCD_GLASS_Init(void) { // Enable LCD/RTC clock // CLK_PeripheralClockConfig(CLK_Peripheral_RTC, ENABLE); CLK_PeripheralClockConfig(CLK_Peripheral_LCD, ENABLE); CLK_RTCClockConfig(CLK_RTCCLKSource_LSI, CLK_RTCCLKDiv_1); // Initialize the LCD LCD_Init(LCD_Prescaler_1, LCD_Divider_31, LCD_Duty_1_4, LCD_Bias_1_3, LCD_VoltageSource_External); // Mask register For declare the segements used. In the Discovery we use 0 to 16 segments LCD_PortMaskConfig(LCD_PortMaskRegister_0, 0xFF); //SEG0~SEG7 LCD_PortMaskConfig(LCD_PortMaskRegister_1, 0x07); //SEG8~SEG15 // To set contrast to mean value LCD_ContrastConfig(LCD_Contrast_Level_0); //对比度电压,使用内部电压时调节亮度 LCD_Contrast_3V0 4 LCD_DeadTimeConfig(LCD_DeadTime_0); //debug LCD_PulseOnDurationConfig(LCD_PulseOnDuration_7); //0-7 脉冲持续时间,使用外部电压时调节亮度 // Enable LCD peripheral LCD_Cmd(ENABLE); } |
3413 浏览 0 评论
3383 浏览 9 评论
3069 浏览 16 评论
3558 浏览 1 评论
9206 浏览 16 评论
1320浏览 3评论
678浏览 2评论
674浏览 2评论
2423浏览 2评论
1986浏览 2评论
GMT+8, 2025-3-7 08:11 , Processed in 0.966838 second(s), Total 45, Slave 37 queries .
