(基于51核的STC12C5A60S2,keil uvision5 mdk 5.25 编译)
KEY1 BIT P3.2 BEEP BIT P1.0 SM_G1 BIT P2.0 SM_G2 BIT P2.1 SM_G3 BIT P2.2 SM_G4 BIT P2.3 ;----------------------------------------------------------------------------------------------------- KEY1_State DATA 69H ; 将地址69H用伪指令命名为KEY1_State DelayTimes_100MS EQU 6FH ; 将地址6FH用伪指令命名为DelayTimes_100MS ;---------------------------------------------------------------------------------------------------- CLR BEEP START: SETB SM_G1 MOV KEY1_State,#0 LOOP: JB KEY1,KEY_OFF MOV DelayTimes_100MS,#2 LCALL Delay100MS KEY_ON: CLR SM_G1 LOOP2: MOV A,KEY1_State MOV DPTR,#TAB MOVC A,@A+DPTR MOV P0,A MOV DelayTimes_100MS,#5 LCALL Delay100MS INC KEY1_State MOV A,KEY1_State CJNE A,#10,CONTINUE AJMP START CONTINUE: AJMP LOOP2 KEY_OFF: AJMP LOOP ;-------------------------------------------------------------------------------------------------------- TAB: DB 0x03,0x9f,0x25,0x0d,0x99,0x49,0x41,0x1f,0x01,0x19,0x03; Delay100MS: MOV R7,DelayTimes_100MS Delay100MS_1: MOV R6,#10 Delay100MS_2: MOV R5,#150 Delay100MS_3: MOV R4,#200 Delay100MS_4: DJNZ R4, Delay100MS_4 DJNZ R5, Delay100MS_3 DJNZ R6, Delay100MS_2 DJNZ R7, Delay100MS_1 RET ;子程序返回 END |
3323 浏览 9 评论
3000 浏览 16 评论
3497 浏览 1 评论
9072 浏览 16 评论
4093 浏览 18 评论
1192浏览 3评论
613浏览 2评论
603浏览 2评论
2341浏览 2评论
1899浏览 2评论
GMT+8, 2024-12-29 03:06 , Processed in 2.784808 second(s), Total 79, Slave 60 queries .
