1. ADC映射
ADC肯定要外部输入的,通过IO口进行采集信号,IO与ADC通道的关系如下: 2配置 2.1配置步骤
typedef struct (5)ADC转换数据对齐方式选择,ADC_DataAlign,可以左对齐或右对齐 (6)顺序进行规则转换的ADC通道的数目设置,ADC_NbrOfChannel,可以设置1~16个通道
void ADC_DeInit(ADC_TypeDef* ADCx); void ADC_Init(ADC_TypeDef* ADCx, ADC_InitTypeDef* ADC_InitStruct); void ADC_StructInit(ADC_InitTypeDef* ADC_InitStruct); void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState); void ADC_DMACmd(ADC_TypeDef* ADCx, FunctionalState NewState); void ADC_ITConfig(ADC_TypeDef* ADCx, uint16_t ADC_IT, FunctionalState NewState); void ADC_ResetCalibration(ADC_TypeDef* ADCx); FlagStatus ADC_GetResetCalibrationStatus(ADC_TypeDef* ADCx); void ADC_StartCalibration(ADC_TypeDef* ADCx); FlagStatus ADC_GetCalibrationStatus(ADC_TypeDef* ADCx); |
3.使用
void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
void ADC_SoftwareStartConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
FlagStatus ADC_GetFlagStatus(ADC_TypeDef* ADCx, uint8_t ADC_FLAG);
uint16_t ADC_GetConversionValue(ADC_TypeDef* ADCx);所有应用相关的库函数如下: void ADC_SoftwareStartConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState); FlagStatus ADC_GetSoftwareStartConvStatus(ADC_TypeDef* ADCx); void ADC_DiscModeChannelCountConfig(ADC_TypeDef* ADCx, uint8_t Number); void ADC_DiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState); void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime); void ADC_ExternalTrigConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState); uint16_t ADC_GetConversionValue(ADC_TypeDef* ADCx); uint32_t ADC_GetDualModeConversionValue(void); void ADC_AutoInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState); void ADC_InjectedDiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState); void ADC_ExternalTrigInjectedConvConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConv); void ADC_ExternalTrigInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState); void ADC_SoftwareStartInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState); FlagStatus ADC_GetSoftwareStartInjectedConvCmdStatus(ADC_TypeDef* ADCx); void ADC_InjectedChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime); void ADC_InjectedSequencerLengthConfig(ADC_TypeDef* ADCx, uint8_t Length); void ADC_SetInjectedOffset(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel, uint16_t Offset); uint16_t ADC_GetInjectedConversionValue(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel); void ADC_AnalogWatchdogCmd(ADC_TypeDef* ADCx, uint32_t ADC_AnalogWatchdog); void ADC_AnalogWatchdogThresholdsConfig(ADC_TypeDef* ADCx, uint16_t HighThreshold, uint16_t LowThreshold); void ADC_AnalogWatchdogSingleChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel); void ADC_TempSensorVrefintCmd(FunctionalState NewState); FlagStatus ADC_GetFlagStatus(ADC_TypeDef* ADCx, uint8_t ADC_FLAG); void ADC_ClearFlag(ADC_TypeDef* ADCx, uint8_t ADC_FLAG); ITStatus ADC_GetITStatus(ADC_TypeDef* ADCx, uint16_t ADC_IT); void ADC_ClearITPendingBit(ADC_TypeDef* ADCx, uint16_t ADC_IT); 4.源码 配置ADC1的一个通道 void Adc_Init(void) { ADC_InitTypeDef ADC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_ADC1, ENABLE); //使能ADC1通道时钟 RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M //PA1 作为模拟通道输入引脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚 GPIO_Init(GPIOA, &GPIO_InitStructure); ADC_DeInit(ADC1); //复位ADC1 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式 ADC_InitStructure.ADC_ScanConvMode = DISABLE; //模数转换工作在单通道模式 ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //模数转换工作在单次转换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐 ADC_InitStructure.ADC_NbrOfChannel = 1; //顺序进行规则转换的ADC通道的数目 ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器 ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1 ADC_ResetCalibration(ADC1); //使能复位校准 while(ADC_GetResetCalibrationStatus(ADC1)); //等待复位校准结束 ADC_StartCalibration(ADC1); //开启AD校准 while(ADC_GetCalibrationStatus(ADC1)); //等待校准结束 // ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能指定的ADC1的软件转换启动功能 } //获得ADC值 //ch:通道值 0~3 u16 Get_Adc(u8 ch) { //设置指定ADC的规则组通道,一个序列,采样时间 ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 ); //ADC1,ADC通道,采样时间为239.5周期 ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能指定的ADC1的软件转换启动功能 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待转换结束 return ADC_GetConversionValue(ADC1); //返回最近一次ADC1规则组的转换结果 } |
2722 浏览 0 评论
3348 浏览 9 评论
3026 浏览 16 评论
3522 浏览 1 评论
9128 浏览 16 评论
1255浏览 3评论
643浏览 2评论
634浏览 2评论
2381浏览 2评论
1946浏览 2评论
GMT+8, 2025-2-1 05:04 , Processed in 1.105260 second(s), Total 49, Slave 40 queries .
