1.首先是超声波模块部分
超声波模块的hc-sr04.h文件 #ifndef __HC__SR04_H #define __HC__SR04_H #include "sys.h" #define Trig PFout(1) // HC-SR04 void TIM9_CH1_Cap_Init(u32 arr,u16 psc); void Trig_Init(void); #endif 超声波模块的hc-sr04.c文件 #include "hc-sr04.h" #include "usart.h" //初始化PE9为输入口.并设置定时器中断9.且使能 //Echo IO 和定时器9初始化 void TIM9_CH1_Cap_Init(u32 arr,u16 psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_ICInitTypeDef TIM9_ICInitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM9,ENABLE); //TIM9时钟使能 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE); //使能PORTE时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //GPIOE5 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; //下拉 GPIO_Init(GPIOE,&GPIO_InitStructure); //初始化PE5 GPIO_PinAFConfig(GPIOE,GPIO_PinSource5,GPIO_AF_TIM9); //PE5复用位定时器9 TIM_TimeBaseStructure.TIM_Prescaler=psc; //定时器分频 TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式 TIM_TimeBaseStructure.TIM_Period=arr; //自动重装载值 TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1; TIM_TimeBaseInit(TIM9,&TIM_TimeBaseStructure); //初始化TIM9输入捕获参数 TIM9_ICInitStructure.TIM_Channel = TIM_Channel_1; //CC1S=01 选择输入端 IC1映射到TI1上 TIM9_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获 TIM9_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上 TIM9_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频 TIM9_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置输入滤波器 不滤波 TIM_ICInit(TIM9, &TIM9_ICInitStructure); TIM_ITConfig(TIM9,TIM_IT_Update|TIM_IT_CC1,ENABLE);//允许更新中断 ,允许CC1IE捕获中断 TIM_Cmd(TIM9,ENABLE ); //使能定时器9 NVIC_InitStructure.NVIC_IRQChannel = TIM1_BRK_TIM9_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;//抢占优先级2 NVIC_InitStructure.NVIC_IRQChannelSubPriority =0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器、 } //捕获状态 //[7]:0,没有成功的捕获;1,成功捕获到一次. //[6]:0,还没捕获到低电平;1,已经捕获到低电平了. //[5:0]:捕获低电平后溢出的次数(对于32位定时器来说,1us计数器加1,溢出时间:4294秒) u8 TIM9CH1_CAPTURE_STA=0; //输入捕获状态 u32 TIM9CH1_CAPTURE_VAL; //输入捕获值(TIM9是32位) //定时器9中断服务程序 void TIM1_BRK_TIM9_IRQHandler(void) { if((TIM9CH1_CAPTURE_STA&0X80)==0)//还未成功捕获 { if(TIM_GetITStatus(TIM9, TIM_IT_Update) == SET)//溢出 { if(TIM9CH1_CAPTURE_STA&0X40)//已经捕获到高电平了 { if((TIM9CH1_CAPTURE_STA&0X3F)==0X3F)//高电平太长了 { TIM9CH1_CAPTURE_STA|=0X80; //标记成功捕获了一次 TIM9CH1_CAPTURE_VAL=0XFFFFFFFF; }else TIM9CH1_CAPTURE_STA++; } } if(TIM_GetITStatus(TIM9, TIM_IT_CC1) != RESET)//捕获1发生捕获事件 { if(TIM9CH1_CAPTURE_STA&0X40) //捕获到一个下降沿 { TIM9CH1_CAPTURE_STA|=0X80; //标记成功捕获到一次高电平脉宽 TIM9CH1_CAPTURE_VAL=TIM_GetCapture1(TIM9);//获取当前的捕获值. TIM_OC1PolarityConfig(TIM9,TIM_ICPolarity_Rising); //OC1P=0 设置为上升沿捕获 }else //还未开始,第一次捕获上升沿 { TIM9CH1_CAPTURE_STA=0; //清空 TIM9CH1_CAPTURE_VAL=0; TIM9CH1_CAPTURE_STA|=0X40; //标记捕获到了上升沿 TIM_Cmd(TIM5,DISABLE ); //关闭定时器9 TIM_SetCounter(TIM9,0); TIM_OC1PolarityConfig(TIM9,TIM_ICPolarity_Falling); //OC1P=1 设置为下降沿捕获 TIM_Cmd(TIM9,ENABLE ); //使能定时器9 } } } TIM_ClearITPendingBit(TIM9, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位 } //初始化PF1为输出口.并使能时钟 //Trig IO初始化 void Trig_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE);//使能GPIOF时钟 //GPIOF1初始化设置 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOF, &GPIO_InitStructure);//初始化 GPIO_ResetBits(GPIOF,GPIO_Pin_1);//初始化GPIOF1为低电平 } 配置文件缺少什么就补什么,上篇STM32F407红外避障控制舵机有写。 2.到称重传感器模块 压力传感器的HX711.h文件 #ifndef __HX711_H #define __HX711_H #include "sys.h" #define HX711_SCK PBout(0)// PB0 #define HX711_DOUT PBin(1)// PB1 extern void Init_HX711pin(void); extern u32 HX711_Read(void); extern void Get_Maopi(void); extern void Get_Weight(void); extern u32 HX711_Buffer; extern u32 Weight_Maopi; extern s32 Weight_Shiwu; extern u8 Flag_Error; #endif 压力传感器的HX711.c文件 #include "HX711.h" #include "delay.h" u32 HX711_Buffer=0; u32 Weight_Maopi=0; s32 Weight_Shiwu=0; u8 Flag_Error = 0; //校准参数 //因为不同的传感器特性曲线不是很一致,因此,每一个传感器需要矫正这里这个参数才能使测量值很准确。 //当发现测试出来的重量偏大时,增加该数值。 //如果测试出来的重量偏小时,减小改数值。 //该值可以为小数 #define GapValue 285 void digitalWrite(GPIO_TypeDef * GPIO,int pin,int value) { if(value==1)//set 1 { GPIO_SetBits(GPIO,pin); } if(value==0)//reset 0 { GPIO_ResetBits(GPIO,pin); } } int digitalRead(GPIO_TypeDef * GPIO,int pin) { return GPIO_ReadInputDataBit(GPIO,pin); } void Init_HX711pin(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitTypeDef GPIO_InitStructure1; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); //SCK GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Init(GPIOB, &GPIO_InitStructure); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); //DOUT GPIO_InitStructure1.GPIO_Pin = GPIO_Pin_1 ; GPIO_InitStructure1.GPIO_Mode = GPIO_Mode_IN; //GPIO_InitStructure1.GPIO_OType = GPIO_OType_OD; GPIO_InitStructure1.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure1.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOB, &GPIO_InitStructure1); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//初始化设置为0 } //读取HX711 u32 HX711_Read(void) //增益128 { unsigned long count; unsigned char i=0; // HX711_DOUT=1; while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1)); delay_us(1); HX711_SCK=0; count=0; delay_us(1); // while(HX711_DOUT); while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1)); for(i=0;i<24;i++) { delay_us(100); HX711_SCK=1; count=count<<1; delay_us(1); HX711_SCK=0; if(HX711_DOUT) count++; delay_us(1); } HX711_SCK=1; count=count^0x800000;//第25个脉冲下降沿来时,转换数据 delay_us(1); HX711_SCK=0; delay_us(1); return (count); } //获取毛皮重量 void Get_Maopi(void) { Weight_Maopi = HX711_Read(); } //称重 void Get_Weight(void) { HX711_Buffer = HX711_Read(); if(HX711_Buffer > Weight_Maopi) { Weight_Shiwu = HX711_Buffer; Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //获取实物的AD采样数值。 Weight_Shiwu = (s32)((float)Weight_Shiwu/GapValue); //计算实物的实际重量 //因为不同的传感器特性曲线不一样,因此,每一个传感器需要矫正这里的GapValue这个除数。 //当发现测试出来的重量偏大时,增加该数值。 //如果测试出来的重量偏小时,减小改数值。 } } 到TFT LCD显示模块的lcd.h和lcd.c代码过长,百度下载引入即可用 3.到主程序部分 #include "sys.h" #include "delay.h" #include "usart.h" #include "hc-sr04.h" #include "lcd.h" #include "HX711.h" extern u8 TIM9CH1_CAPTURE_STA; //输入捕获状态 extern u32 TIM9CH1_CAPTURE_VAL; //输入捕获值 int main(void) { float temp=0; u8 complete = 1; //一次采集完成标志 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2 delay_init(168); //初始化延时函数 uart_init(115200);//初始化串口波特率为115200 LCD_Init(); //初始化LCD FSMC接口 Trig_Init(); TIM9_CH1_Cap_Init(0XFFFFFFFF,84-1); //以1Mhz的频率计数 timer9是32位的。 Init_HX711pin(); delay_ms(2000); Get_Maopi(); //称毛皮重量 delay_ms(100); POINT_COLOR=RED; //画笔颜色:红色 while(1) { if(complete == 1) { Trig = 1; delay_us(15); Trig = 0; complete = 0; } while(complete == 0) { if(TIM9CH1_CAPTURE_STA&0X80) //成功捕获到了一次高电平 { temp=TIM9CH1_CAPTURE_STA&0X3F; temp*=0XFFFFFFFF; //溢出时间总和 temp+=TIM9CH1_CAPTURE_VAL; //得到总的高电平时间 temp = temp * 17/1000; //得到距离 printf("HIGH:%f cmrn",temp); //打印距离 delay_ms(1000); LCD_ShowNum(50,10,temp,3,16); //TFT LCD打印距离 TIM9CH1_CAPTURE_STA=0; //开启下一次捕获 complete = 1; } } Get_Weight(); Get_Maopi(); printf("净重量 = %d grn",Weight_Shiwu); //打印 printf("毛坯 = %d grn",Weight_Maopi); //打印 printf("重量 = %d grn",HX711_Buffer); //打印 delay_ms(1000); LCD_ShowNum(50,50,Weight_Shiwu,8,16); //TFT LCD打印输出 LCD_ShowNum(50,100,Weight_Maopi,8,16); LCD_ShowNum(50,150,HX711_Buffer,8,16); } } |
3125 浏览 0 评论
3360 浏览 9 评论
3045 浏览 16 评论
3539 浏览 1 评论
9155 浏览 16 评论
1282浏览 3评论
659浏览 2评论
651浏览 2评论
2397浏览 2评论
1963浏览 2评论
GMT+8, 2025-2-12 02:27 , Processed in 1.095245 second(s), Total 43, Slave 35 queries .
