摘要
本文章主要讲述了CC2530的五种功耗模式,详细介绍了这五种功耗模式的区别,以及每种功耗模式的唤醒方法。最后通过代码,演示了这五种功耗模式(主动模式,空闲模式。PM1,PM2,PM3)之间的切换。 完整的程序源代码 #include //定义控制灯的端口 #define LED1 P1_0 //定义LED1为P1_0口控制 #define LED2 P1_5 //定义LED2为P1_5口控制 #define LED3 P1_3 //定义LED3为P1_3口控制 #define LED4 P1_4 //定义LED4为P1_4口控制 #define SW1 P1_2 //定义SW1为P1_2端口 #define SW2 P0_1 //定义SW2为P0_1端口 /**************************** //延时 *****************************/ char pause = 0; void Delay_mS(unsigned int n) { unsigned int tt,i = 0; for(i = 0; i < n; i ++) for(tt = 0; tt<1040; tt++); while(pause); } void Delay_2uS(unsigned int n) { unsigned int i = 0; for(;i < n; i++); } /**************************** //初始化函数 *****************************/ void Initial(void) { P1DIR = 0xFB;//将P12设为输入,其他设为输出 (0xFB = 11111011) LED1 = 0;//关闭LED1 LED2 = 0;//关闭LED2 LED3 = 1;//关闭LED3 LED4 = 0;//关闭LED4 P0SEL = 0x0C; //大开P0.2,P0.3的外设功能 CLKCONCMD &= 0x80; U0BAUD = 216; //设置波特率115200 U0GCR = 11; U0CSR = 0xC0; //选择UART功能,并使能接收功能 URX0IE = 1; //使能UART0 接收中断 IEN2 = 0x10; //使能P1口中断 P1IEN = 0x04; //使能P1_2口中断 PICTL = 0x03; //P1_3到P1_0口下降沿触发中断 ST2 = 0; //初始化睡眠定时器中断 ST1 = 0x0F; ST0 = 0x0F; STIE = 1; STIF = 0; EA =1; // 使能总中断 } //通郭串口发送字符串 void Uart_Send_Str(char * p) { while(*p != 0) { U0DBUF = *p; p++; while(UTX0IF == 0); UTX0IF = 0; } } //退出低功耗模式,进入主动模式 void Exit_Pm() { PCON = 0; } //进入空闲模式 void Enter_IDEL() { SLEEPCMD &= ~0x03; PCON |= 0x01; } //进入PM1模式 void Enter_PM1() { SLEEPCMD &= ~0x03; SLEEPCMD |= 0x01; PCON |= 0x01; } //进入PM2模式 void Enter_PM2() { SLEEPCMD &= ~0x03; SLEEPCMD |= 0x02; PCON |= 0x01; } //进入PM3模式 void Enter_PM3() { SLEEPCMD &= ~0x03; SLEEPCMD |= 0x03; PCON |= 0x01; } //设置睡眠定时唤醒时间 void Set_ST_Time(unsigned short time) { unsigned long sleepTime = 0; sleepTime |= ST0; sleepTime |= (unsigned long)ST1 << 8; sleepTime |= (unsigned long)ST2 << 16; sleepTime += (unsigned long)time * (unsigned long)32768; ST2 = (unsigned char )(sleepTime >> 16); ST1 = (unsigned char )(sleepTime >> 8); ST0 = (unsigned char )(sleepTime); } /*************************** //主函数 ***************************/ void main(void) { Initial(); //调用初始化函数 while(1) { Delay_mS(100);//等待系统时钟稳定 Uart_Send_Str("Hello World!rn"); Uart_Send_Str("Enter IDEL Mode ... rn"); Enter_IDEL(); Uart_Send_Str("Enter PM1 Mode ... rn"); Set_ST_Time(5); Enter_PM1(); Delay_mS(100);//等待系统时钟稳定 Uart_Send_Str("Enter PM2 Mode ... rn"); Set_ST_Time(5); Enter_PM2(); Delay_mS(100);//等待系统时钟稳定 Uart_Send_Str("Enter PM3 Mode ... rn"); Enter_PM3(); Delay_mS(100);//等待系统时钟稳定 Uart_Send_Str("Wake Up From PM3 ! rn"); } } #pragma vector = P1INT_VECTOR __interrupt void P1_INT(void) { if (P1IFG & 0x04) //如果P1_2口中断标志位置位 { Exit_Pm();//退出低功耗模式,进入主动模式 P1IFG &= ~0x04; //清除P1_2口中断标志位 } P1IF=0; //清除P1口中断标志位 } #pragma vector = URX0_VECTOR __interrupt void URX0_INT(void) { if(U0DBUF == 'a') { Exit_Pm();//退出低功耗模式,进入主动模式 } } #pragma vector = ST_VECTOR __interrupt void ST_INT(void) { STIF = 0; Exit_Pm(); } |
3188 浏览 9 评论
2878 浏览 16 评论
3383 浏览 1 评论
8815 浏览 16 评论
3979 浏览 18 评论
9611浏览 3评论
982浏览 3评论
502浏览 2评论
505浏览 2评论
2227浏览 2评论
GMT+8, 2024-9-20 17:29 , Processed in 0.766509 second(s), Total 45, Slave 37 queries .
