一,打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1 二,调整原理图大小,适合可视,另存工程文件。(如下图2,3,4所示) 图2 图3 图4 三,点击Source Code标签。(如下图5所示) 图5 四,编辑main.c Proteus8.9 VSM Studio WINAVR编译器仿真ATmega16系列a20_SPI接口TC72 (如下图6所示) 图6 五,Main.c 代码: //----------------------------------------------------------------- // 名称: SPI接口温度传感TC72应用测试 //----------------------------------------------------------------- // 说明: 本例运行时,单片机将持续从TC72传感器读取温度数据并转换为 // 10进制温度值送串口显示. // //----------------------------------------------------------------- //#define F_CPU 4000000UL #include “urt.h” //----------------------------------------------------------------- // 主程序 //----------------------------------------------------------------- int main() { INT8U Temp[2]; int d, f; float Current_Temp= 0.00, Pre_temp= 0.00; char DisplayBuffer[50]; DDRD= 0xFF; Init_USART(); SPI_MasterInit(); Config_TC72(); _delay_ms(300); sprintf(DisplayBuffer, “Manufacture ID: 0x%02Xrn”, Read_Manufacture_ID()); PutStr(DisplayBuffer); PutStr(“Begin Read Temperature from TC72 …rn”); while(1) { Read_TC72_Temperature(Temp); Current_Temp= Convert_Temperature(Temp); Read_TC72_Temperature(Temp); if(Current_Temp!= Convert_Temperature(Temp)) continue; if(Current_Temp== Pre_temp) continue; Pre_temp= Current_Temp; d= (int) Current_Temp; f= (int) (fabs(Current_Temp- d)* 100); sprintf(DisplayBuffer, “T[0]:0x%02X T[1]:0x%02X – > %3d. %02dCn”, Temp[0], Temp[1], d, f); PutStr(DisplayBuffer); _delay_ms(30000); } } urt1.h //****************************************************************************************** #ifndef URT_H #define URT_H #include #include #include #include #define INT8U unsigned char #define INT16U unsigned int //SPI使能与禁用(注意TC72是高电平使能,低电平禁用) #define SPI_EN() PORTB |= _BV(PB4) #define SPI_DI() PORTB &= ~_BV(PB4) //TC72寄存器地址定义 #define TC72_CTRL 0x80 #define TC72_TEMP_LSB 0x01 #define TC72_TEMP_MSB 0x02 #define TC72_MANU_ID 0x03 void SPI_MasterInit(); INT8U SPI_Transmit(INT8U dat); void Write_TC72_Aaddr_Dat(INT8U addr, INT8U dat); void Config_TC72(); void Read_TC72_Temperature(INT8U T[]); INT8U Read_Manufacture_ID(); float Convert_Temperature(INT8U T[]); void Init_USART(); void PutChar(char c); void PutStr(char *s); #endif 六,点击构建工程按钮,编译工程。(如下图7所示) 图7 七,点击窗口左下方仿真按钮,可见虚拟温度在虚拟串口显示屏显示。 (如下图8,9,10所示) 图8 图9 图10 八,选择release,点击构建工程按钮,编译工程生成Hex文件。(如下图11所示) 图11 附件Proteus8.9 VSM Studio WINAVR编译器仿真ATmega16系列a20_SPI接口TC72在已安装Proteus8.9的计算机文件夹中打开即可 |
3406 浏览 0 评论
3381 浏览 9 评论
3067 浏览 16 评论
3556 浏览 1 评论
9198 浏览 16 评论
1316浏览 3评论
677浏览 2评论
670浏览 2评论
2421浏览 2评论
1983浏览 2评论
GMT+8, 2025-3-5 10:21 , Processed in 1.311084 second(s), Total 79, Slave 60 queries .
