先上代码
volatile unsigned long g_timer0_delay_conut = 0; void main(void) { DISI(); //Disable all unmasked interrupts Ny8b072a_Gpio_Init(); //Ny8b072a_Timer1_Init(); //Ny8b072a_Timer2_Init(); Ny8b072a_Timer3_Init(); ENI(); // Enable all unmasked interrupts while(1) { //CLRWDT(); // Clear WatchDog /* LED1 = ~LED1; LED2 = ~LED2; LED3 = ~LED3; LED4 = ~LED4; */ App_Delay_Ms(1000); } } //10bit count down , max 0x3FF void Ny8b072a_Timer1_Init(void) { //1MS TMRH = 0x30; // TIMER1 higt 2bit in TMRH bit4~5 m*** TMR1 = 0xE8; // Load 0xFF to TMR1 (Initial Timer1 register) low 8bit T1CR1 = C_TMR1_Reload | C_TMR1_En; // Enable Timer1, Initial value reloaded from TMR1, Non-stop mode T1CR2 = C_TMR1_ClkSrc_Inst | C_PS1_Div2; // Enable Prescaler1, Prescaler1 dividing rate = 1:2 // Timer1 clock source is instruction clock INTE |= C_INT_TMR1; // Enable Timer1 overflow interrupt } //10bit count down , max 0x3FF void Ny8b072a_Timer2_Init(void) { //500us TMRH = 0x40; //TIMER2 higt 2bit in TMRH bit6~7 m*** TMR2 = 0xF4; // Load 0xFF to TMR2 (Initial Timer2 register) low 8bit T2CR1 = C_TMR2_Reload | C_TMR2_En; // Enable Timer2, Initial value reloaded from TMR2, Non-stop mode T2CR2 = C_TMR2_ClkSrc_Inst | C_PS2_Div2; // Enable Prescaler2, Prescaler2 dividing rate = 1:2 // Timer2 clock source is instruction clock INTE |= C_INT_TMR2; // Enable Timer2 overflow interrupt } //10bit count down , max 0x3FF void Ny8b072a_Timer3_Init(void) { //50us TM3RH = 0; //TIMER3 higt 2bit in TM3RH bit4~5 m*** TMR3 = 50; // Load 0xFF to TMR3 (Initial Timer3 register) low 8bit T3CR1 = C_TMR3_Reload | C_TMR3_En; // Enable Timer3, Initial value reloaded from TMR3, Non-stop mode T3CR2 = C_TMR3_ClkSrc_Inst | C_PS3_Div2; // Enable Prescaler3, Prescaler3 dividing rate = 1:2 // Timer3 clock source is instruction clock //这里用 |= 会报错:如果其他中断讯号刚好在此时产生的话,使用 'BSR' 指令清除中断旗标有机会误清其他的中断旗标。 (201) INTE2 = C_INE_TMR3; // Enable Timer3 overflow interrupt } //! interrupt service routine void isr(void) __interrupt(0) { if(INTFbits.T1IF) { g_timer0_delay_conut ++; if(500 == g_timer0_delay_conut ) //1MS * 500 = 500ms { LED1 ^= 1; g_timer0_delay_conut= 0; } INTF= (unsigned char)~(C_INT_TMR1); // Clear T1IF flag bit } if(INTFbits.T2IF) { g_timer0_delay_conut ++; if(1000 == g_timer0_delay_conut ) //500us * 1000 = 500ms { LED1 ^= 1; g_timer0_delay_conut = 0; } INTF= (unsigned char)~(C_INT_TMR2); // Clear T2IF flag bit } if(INTE2bits.T3IF) { g_timer0_delay_conut ++; if(10000 == g_timer0_delay_conut )//50us * 10000 = 500ms { LED1 ^= 1; g_timer0_delay_conut = 0; } INTE2= (unsigned char)~(C_INF_TMR3); // Clear T3IF flag bit } }
800 000 / 4 / 2 = 50us 1 / 0001 / 4 / 2 = 50us 1 / 0000 = 1us 1 这计算000005 55 需要00000000000每一次的中断时间; 中断中1000 ==频率时间0_delay_需要的时间50 * 10 000000000000000000000000000000000000000000000000000000000000000000 美元个人不建议使用简单的时间 来说明自己的价值设置(我们),非常真实的 G 很容易显示出BU的真实价值。 |
3363 浏览 0 评论
3370 浏览 9 评论
3061 浏览 16 评论
3551 浏览 1 评论
9182 浏览 16 评论
1305浏览 3评论
671浏览 2评论
663浏览 2评论
2411浏览 2评论
1978浏览 2评论
GMT+8, 2025-2-24 08:27 , Processed in 0.875476 second(s), Total 45, Slave 37 queries .
